Do anyone know how to install Doker in our board?
i try to install Docker by this instraction, but get an error when installalling docker-ce. Who managed to install Docker on our board?
you need to rebuild kernel with some options
Can you give more information? What kind options?
this image for BPI-W2 have support docker.
Thanks for the answer. But i don’t want to use the image with Mate. This is a list of kernel optins. Seems like all gonna be ok, but it is not. What kind options i need to enable?
info: reading kernel config from kernel.config … Generally Necessary:
  • cgroup hierarchy: properly mounted [/sys/fs/cgroup]
  • CONFIG_NAMESPACES: enabled
  • CONFIG_NET_NS: enabled
  • CONFIG_PID_NS: enabled
  • CONFIG_IPC_NS: enabled
  • CONFIG_UTS_NS: enabled
  • CONFIG_CGROUPS: enabled
  • CONFIG_CGROUP_CPUACCT: enabled
  • CONFIG_CGROUP_DEVICE: enabled
  • CONFIG_CGROUP_FREEZER: enabled
  • CONFIG_CGROUP_SCHED: enabled
  • CONFIG_CPUSETS: enabled
  • CONFIG_MEMCG: enabled
  • CONFIG_KEYS: enabled
  • CONFIG_VETH: enabled (as module)
  • CONFIG_BRIDGE: enabled (as module)
  • CONFIG_BRIDGE_NETFILTER: enabled (as module)
  • CONFIG_NF_NAT_IPV4: enabled
  • CONFIG_IP_NF_FILTER: enabled
  • CONFIG_IP_NF_TARGET_MASQUERADE: enabled
  • CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled
  • CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled
  • CONFIG_NETFILTER_XT_MATCH_IPVS: missing
  • CONFIG_IP_NF_NAT: enabled
  • CONFIG_NF_NAT: enabled
  • CONFIG_NF_NAT_NEEDED: enabled
  • CONFIG_POSIX_MQUEUE: enabled
Optional Features:
  • CONFIG_USER_NS: enabled
  • CONFIG_SECCOMP: enabled
  • CONFIG_CGROUP_PIDS: enabled
  • CONFIG_MEMCG_SWAP: enabled
  • CONFIG_MEMCG_SWAP_ENABLED: enabled (cgroup swap accounting is currently enabled)
  • CONFIG_BLK_CGROUP: enabled
  • CONFIG_BLK_DEV_THROTTLING: enabled
  • CONFIG_IOSCHED_CFQ: enabled
  • CONFIG_CFQ_GROUP_IOSCHED: enabled
  • CONFIG_CGROUP_PERF: enabled
  • CONFIG_CGROUP_HUGETLB: missing
  • CONFIG_NET_CLS_CGROUP: enabled
  • CONFIG_CGROUP_NET_PRIO: enabled
  • CONFIG_CFS_BANDWIDTH: enabled
  • CONFIG_FAIR_GROUP_SCHED: enabled
  • CONFIG_RT_GROUP_SCHED: enabled
  • CONFIG_IP_NF_TARGET_REDIRECT: enabled
  • CONFIG_IP_VS: enabled
  • CONFIG_IP_VS_NFCT: enabled
  • CONFIG_IP_VS_PROTO_TCP: enabled
  • CONFIG_IP_VS_PROTO_UDP: enabled
  • CONFIG_IP_VS_RR: enabled
  • CONFIG_EXT3_FS: enabled
  • CONFIG_EXT3_FS_XATTR: missing
  • CONFIG_EXT3_FS_POSIX_ACL: enabled
  • CONFIG_EXT3_FS_SECURITY: enabled (enable these ext3 configs if you are using ext3 as backing filesystem)
  • CONFIG_EXT4_FS: enabled
  • CONFIG_EXT4_FS_POSIX_ACL: enabled
  • CONFIG_EXT4_FS_SECURITY: enabled
  • Network Drivers:
    • “overlay”:
      • CONFIG_VXLAN: enabled (as module)
      • CONFIG_BRIDGE_VLAN_FILTERING: enabled Optional (for encrypted networks):
        • CONFIG_CRYPTO: enabled
        • CONFIG_CRYPTO_AEAD: enabled
        • CONFIG_CRYPTO_GCM: enabled (as module)
        • CONFIG_CRYPTO_SEQIV: enabled
        • CONFIG_CRYPTO_GHASH: enabled (as module)
        • CONFIG_XFRM: enabled
        • CONFIG_XFRM_USER: enabled
        • CONFIG_XFRM_ALGO: enabled
        • CONFIG_INET_ESP: enabled
        • CONFIG_INET_XFRM_MODE_TRANSPORT: enabled
    • “ipvlan”:
      • CONFIG_IPVLAN: enabled (as module)
    • “macvlan”:
      • CONFIG_MACVLAN: enabled (as module)
      • CONFIG_DUMMY: enabled (as module)
    • “ftp,tftp client in container”:
      • CONFIG_NF_NAT_FTP: enabled
      • CONFIG_NF_CONNTRACK_FTP: enabled
      • CONFIG_NF_NAT_TFTP: enabled
      • CONFIG_NF_CONNTRACK_TFTP: enabled
  • Storage Drivers:
    • “aufs”:
      • CONFIG_AUFS_FS: missing
    • “btrfs”:
      • CONFIG_BTRFS_FS: enabled
      • CONFIG_BTRFS_FS_POSIX_ACL: enabled
    • “devicemapper”:
      • CONFIG_BLK_DEV_DM: enabled
      • CONFIG_DM_THIN_PROVISIONING: enabled
    • “overlay”:
      • CONFIG_OVERLAY_FS: enabled
    • “zfs”:
      • /dev/zfs: missing
      • zfs command: missing
      • zpool command: missing
Limits:
  • /proc/sys/kernel/keys/root_maxkeys: 1000000
BPI Image: Banana Pi BPI-M4/BPI-W2 Debian 10 Buster Lite Demo Image Release 20190806
If you don’t want to use MATE then just remove all the MATE apps and it will work as headless server.
I think this is the easiest way for you, without the need to compile the kernel yourself.
maybe the easy way is download https://drive.google.com/file/d/1qhRH_2I6-o1ZaysgMvkqfpZwmOVQvtdL/view?usp=drivesdk image , then copy the kernel file to your image. so that you don’t need to recompile the kernel by yourself
Hello,
docker hast got a problem with nf_/iptables. The solution is simple. :slight_smile:
update-alternatives --set iptables /usr/sbin/iptables-legacy
And you can install docker again. :slight_smile:
