Hello guys,
I’m trying to compile uboot by myself, I use the code from
https://github.com/BPI-SINOVOIP/BPI-R2-bsp.git/u-boot-mt
ARCH=arm make menuconfig
#modify Makefile a little.
git diff Makefile
diff --git a/u-boot-mt/Makefile b/u-boot-mt/Makefile
index b3b206e46..446ebc2ac 100755
--- a/u-boot-mt/Makefile
+++ b/u-boot-mt/Makefile
@@ -206,7 +206,7 @@ CROSS_COMPILE ?=
 endif
 CROSS_COMPILE_PATH = /opt/buildroot-gcc463_arm/usr/bin
-CROSS_COMPILE = $(CROSS_COMPILE_PATH)/arm-buildroot-linux-uclibcgnueabi-
+CROSS_COMPILE = arm-linux-gnueabihf-
 # SHELL used by kbuild
 CONFIG_SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH; \
make
  GEN     include/autoconf.mk.dep
In file included from /home/weiqi/u-boot-mt/include/linux/compiler.h:40:0,
                 from /home/weiqi/u-boot-mt/include/linux/byteorder/little_endian.h:12,
                 from /home/weiqi/u-boot-mt/arch/arm/include/asm/byteorder.h:29,
                 from /home/weiqi/u-boot-mt/include/compiler.h:112,
                 from /home/weiqi/u-boot-mt/include/image.h:19,
                 from /home/weiqi/u-boot-mt/include/common.h:97:
/home/weiqi/u-boot-mt/include/linux/compiler-gcc.h:95:1: fatal error: linux/compiler-gcc7.h: No such file or directory
 #include gcc_header(__GNUC__)
compilation terminated.
  CHK     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  UPD     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CC      lib/asm-offsets.s
                 from /home/weiqi/u-boot-mt/include/common.h:97,
                 from lib/asm-offsets.c:15:
/home/weiqi/u-boot-mt/./Kbuild:34: recipe for target 'lib/asm-offsets.s' failed
make[1]: *** [lib/asm-offsets.s] Error 1
Makefile:1040: recipe for target 'prepare0' failed
make: *** [prepare0] Error 2
The version of gcc
arm-linux-gnueabihf-gcc --version
arm-linux-gnueabihf-gcc (Ubuntu/Linaro 7.2.0-6ubuntu1) 7.2.0
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Anybody know what is happening?
