Compile swconfig for r64
(Frank W.) #1
i’m trying to compile swconfig for r64, but i’m stuck
i take source from openwrt (seems the only source for it): https://github.com/openwrt-mirror/openwrt/tree/master/package/network/config/swconfig
and rewrote makefile
there are many type-mismatches and still some missing files…
is it compatible with kernel 4.19 or is it kernel-independed and needs only additional sources e.g. from https://github.com/openwrt-mirror/openwrt/tree/master/package/libs/libnl-tiny/src
tried also to clone openwrt directly and build only swconfig/src
frank@frank-N56VZ:/media/data_ext/openwrt/package/network/config/swconfig
[16:26:47]$ make
Makefile:8: /rules.mk: No such file or directory
Makefile:16: /package.mk: No such file or directory
Makefile:17: /kernel.mk: No such file or directory
make: *** No rule to make target '/kernel.mk'.  Stop.
[16:26:50]$ cd src
frank@frank-N56VZ:/media/data_ext/openwrt/package/network/config/swconfig/src
[16:27:06]$ make
cc -O2 -g -I ../src -fPIC -c -o swlib.o swlib.c
swlib.c:26:10: fatal error: linux/switch.h: No such file or directory
 #include <linux/switch.h>
compilation terminated.
Makefile:9: recipe for target 'swlib.o' failed
make: *** [swlib.o] Error 1
anyone has an idea?
(August) #2
Copy https://github.com/openwrt-mirror/openwrt/blob/master/target/linux/generic/files/include/uapi/linux/switch.h to /usr/include/linux/ on the build machine
(Frank W.) #3
same as after i copied id to local source:
In file included from swlib.c:26:0:
/usr/include/linux/switch.h:25:10: fatal error: netlink/netlink.h: No such file or directory
 #include <netlink/netlink.h>
seems it requires libnl
./package/libs/libnl-tiny/src/include/netlink/netlink.h
i created include-dir in src and copied libnl-tiny/src/include/netlink to it…
[16:53:14]$ CFLAGS=-Iinclude make
cc -Iinclude -fPIC -c -o swlib.o swlib.c
In file included from include/netlink/genl/genl.h:16:0,
                 from /usr/include/linux/switch.h:26,
                 from swlib.c:26:
include/netlink/msg.h:52:16: error: field 'nm_creds' has incomplete type
  struct ucred  nm_creds;
include/netlink/msg.h: In function 'nlmsg_set_creds':
include/netlink/msg.h:207:39: error: dereferencing pointer to incomplete type 'struct ucred'
  memcpy(&msg->nm_creds, creds, sizeof(*creds));
it seems that “struct ucred;” is only forward-declared in msg.h but nowhere declared with fields
tried to build it like this (only with crosscompiler, currently arm-linux-gnueabihf-gcc):
but make in swconfig failes on
make: libsw.a: Command not found
libsw.a exists in swconfig/src
currently hang here:
cli.c:26:10: fatal error: uci.h: No such file or directory
 #include <uci.h>
i don’t find an uci.h in openwrt-source
(moore liu) #4
I’ll suggest …
  1. download openwrt 18.06 stable branch, and build image (it can boot to shell without network support) https://github.com/openwrt/openwrt/tree/openwrt-18.06 https://downloads.openwrt.org/releases/18.06.0/targets/mediatek/mt7622/
  2. refer to below github to add missing network parts and enable swconfig in menuconfig https://github.com/objelf/linux/commits/linux-4.14.y-mediatek
(Frank W.) #5
Isn’t there a way to compile sw-config outside openwrt? I want to use it in debian…
(moore liu) #6
swconfig / uci are openwrt proprietary way to configure device, it needs patch kernel and prepare related library/app as well. I will suggest you use normal way to configure network in debian.
https://github.com/openwrt-mirror/openwrt/blob/master/target/linux/generic/patches-4.4/700-swconfig.patch
(Frank W.) #7
I only know dsa to configure separate ports and switchconfig…as there is no dsa-driver for r64 i tried to get swconfig working
(moore liu) #8
there is no need to enable DSA or swconfig tool, just use below code base with ifconfig command to enable ethernet, thanks.
notes: swconfig is advanced feature to help hou set vlan member, pvid…etc easily.
(Frank W.) #9
I have ethernet working, but lan-ports are 1 nic so i cannot configure them separately…currently it works like r2 with kernel 4.4
(moore liu) #10
I will suggest you can verify other parts first, and wait until new switch ic with DSA driver to meet your requirement. :wink:
(Frank W.) #11
wifi-driver is actually not compilable with gcc >6 so i’m stuck here (tried to compile full r64-bsp-repo on ubuntu 18.4 with all available gcc cross-compilers, on ubuntu 14.4 it works)
