Compilation Error for U-boot and kernel
Hello everyone, I have cloned bsp code for banana pi BPI-M3 from https://github.com/BPI-SINOVOIP/BPI-M3-bsp.git . When I am trying to built the kernel using ./build.sh command it gives me error. Error log file is available in attachment. Please help me.
Thanks In Advance. error_logs_kernel (109.6 KB)
Try to build it with the bpi-build docker image, and avoiding the environment issue. https://cloud.docker.com/u/sinovoip/repository/docker/sinovoip/bpi-build
Hi August, Thanks for your reply. The link which you mentioned is not working. I searched for bpi-build on docker official website. I found following docker https://hub.docker.com/r/sinovoip/bpi-build . Is it right docker image? If yes , can you please provide me the steps to compilation of kernel using docker.
Thanks In Advance.
The docker image is correct, did you follow the readme to open a ssh client to run the build script? If it’s still not work, apply this patch to linux-sunxi/drivers/net/wireless/rtl8723bu/include/ieee80211.h image
Hi August,
Thanks for your early reply. I am trying to use hardware codec for Banana PI M3. I am using https://github.com/allwinner-zh/media-codec . But the demo application provided in repository is giving segmentation fault. I am using Ubuntu mate 16.04 pre-built image of Banana PI. Is something is missing in my setup? can you please help me with hardware codec with banana PI?
Thanks in Advance
Hello, you could try here to complie the M3 bsp code:
http://wiki.banana-pi.org/Getting_Started_with_M3#How_to_buld_M3_Bsp_code
