Cannot identify '/dev/video0': 2, No such file or directory
Hi all, I just start with BPI-D1, but it has a problem with the capture camera, when the original firmware as well as the rebuild firmware from lamobo github is also cannot identify ‘/dev/video0’. How could I fix this problem?
Hello, can you provide more information please? Like can you personally not find the directory? and how where u looking etc.
thanks
It is just the display when I log in the terminal, it has a warning like this below figure
Hello, I have the same problem. You have a solution? Thank you
have a try like this: press “Function button” when plug into your PC
Hello. Thank you for your feedback. I discovered that the problem is in the flat cable from the camera. I changed the camera and the problem solved. Thank you.
