When i compile u-boot from https://github.com/BPI-SINOVOIP/BPI-R2-bsp
CC v6
$ cc -v
Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/6/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 6.3.0-18' --with-bugurl=file:///usr/share/doc/gcc-6/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-6 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-6-amd64/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-6-amd64 --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-6-amd64 --with-arch-directory=amd64 --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 6.3.0 20170516 (Debian 6.3.0-18)
Build log.
$ ./build.sh
NOTICE:
new build.sh default select BPI-R2-720P and pack all boards
supported boards:
BPI-R2-720P
BPI-R2-720P configured. Now run `make`
This tool support following building mode(s):
1. Build all, uboot and kernel and pack to download images.
2. Build uboot only.
3. Build kernel only.
4. kernel configure.
5. Pack the builds to target download image, this step must execute after u-boot,
kernel and rootfs build out
6. update files for SD
7. Clean all build.
Please choose a mode(1-7): 2
Now building...
make -C u-boot-mt mt7623_evb_config CROSS_COMPILE=arm-linux-gnueabihf- -j2
make[1]: Entering directory '/home/francois/BPI-R2-bsp/u-boot-mt'
Configuring for mt7623_evb board...
make[1]: Leaving directory '/home/francois/BPI-R2-bsp/u-boot-mt'
make -C u-boot-mt all CROSS_COMPILE=arm-linux-gnueabihf- -j2
GEN include/autoconf.mk.dep
CHK include/config/uboot.release
CHK include/generated/version_autogenerated.h
UPD include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/version_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
HOSTCC scripts/basic/fixdep
CC lib/asm-offsets.s
GEN include/generated/generic-asm-offsets.h
LDS u-boot.lds
HOSTCC tools/img2srec
HOSTCC tools/gen_eth_addr
HOSTCC tools/aisimage.o
HOSTCC tools/crc32.o
HOSTCC tools/default_image.o
HOSTCC tools/dumpimage.o
HOSTCC tools/fdt.o
HOSTCC tools/fdt_ro.o
HOSTCC tools/fdt_rw.o
HOSTCC tools/fdt_strerror.o
HOSTCC tools/fdt_wip.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-fit.o
HOSTCC tools/image-host.o
HOSTCC tools/image.o
HOSTCC tools/imagetool.o
HOSTCC tools/imximage.o
HOSTCC tools/kwbimage.o
HOSTCC tools/md5.o
HOSTCC tools/mkenvimage.o
HOSTCC tools/mkimage.o
HOSTCC tools/mxsimage.o
HOSTCC tools/omapimage.o
HOSTCC tools/os_support.o
HOSTCC tools/pblimage.o
HOSTCC tools/sha1.o
HOSTCC tools/ublimage.o
HOSTCC tools/proftool
HOSTLD tools/mkenvimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
LD arch/arm/cpu/built-in.o
CC arch/arm/cpu/armv7/cache_v7.o
AS arch/arm/cpu/armv7/mt7623/lowlevel_init.o
CC arch/arm/cpu/armv7/cpu.o
CC arch/arm/cpu/armv7/mt7623/init.o
CC arch/arm/cpu/armv7/syslib.o
CC arch/arm/cpu/armv7/mt7623/reset.o
LD arch/arm/cpu/armv7/mt7623/built-in.o
AS arch/arm/cpu/armv7/start.o
LD arch/arm/cpu/armv7/built-in.o
AS arch/arm/lib/crt0.o
CC board/mediatek/common/mtk_cmd.o
board/mediatek/common/mtk_cmd.c: In function ‘do_read_mtk_image_blks’:
board/mediatek/common/mtk_cmd.c:162:40: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
printf("[%s]Bad Magic Number = 0x%x\n",
board/mediatek/common/mtk_cmd.c:172:40: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
printf("[%s]Good Magic Number = 0x%x\n",
board/mediatek/common/mtk_cmd.c:174:37: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
printf("[%s]Good Data size = 0x%x\n",
board/mediatek/common/mtk_cmd.c:176:30: warning: format ‘%s’ expects argument of type ‘char *’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
printf("[%s]Good name = %s\n",
board/mediatek/common/mtk_cmd.c:180:31: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
printf("[%s]img_size = 0x%x\n", __func__, img_size);
board/mediatek/common/mtk_cmd.c:140:21: warning: unused variable ‘img_hdr’ [-Wunused-variable]
image_header_t *img_hdr = (image_header_t *)load_addr;
board/mediatek/common/mtk_cmd.c: In function ‘do_serious_image_check’:
board/mediatek/common/mtk_cmd.c:225:33: warning: unused variable ‘len’ [-Wunused-variable]
__u32 chksum = 0, chksum2 = 0, len = 0;
board/mediatek/common/mtk_cmd.c:225:20: warning: unused variable ‘chksum2’ [-Wunused-variable]
board/mediatek/common/mtk_cmd.c:225:8: warning: unused variable ‘chksum’ [-Wunused-variable]
board/mediatek/common/mtk_cmd.c:223:17: warning: unused variable ‘header’ [-Wunused-variable]
image_header_t header;
board/mediatek/common/mtk_cmd.c: In function ‘do_backup_message’:
board/mediatek/common/mtk_cmd.c:262:1: warning: control reaches end of non-void function [-Wreturn-type]
board/mediatek/common/mtk_cmd.c: In function ‘do_reco_message’:
board/mediatek/common/mtk_cmd.c:268:1: warning: control reaches end of non-void function [-Wreturn-type]
LD board/mediatek/common/built-in.o
AS arch/arm/lib/relocate.o
CC arch/arm/lib/board.o
arch/arm/lib/board.c:517:0: warning: "MCUSYS_CFGREG_BASE" redefined
#define MCUSYS_CFGREG_BASE 0x10200000
In file included from /home/francois/BPI-R2-bsp/u-boot-mt/include/configs/mt7623_evb.h:22:0,
from /home/francois/BPI-R2-bsp/u-boot-mt/include/config.h:10,
from /home/francois/BPI-R2-bsp/u-boot-mt/include/common.h:18,
from arch/arm/lib/board.c:25:
/home/francois/BPI-R2-bsp/u-boot-mt/arch/arm/include/asm/arch/mt_reg_base.h:21:0: note: this is the location of the previous definition
#define MCUSYS_CFGREG_BASE (IO_PHYS + 0x00200000)
