Build Kernel 5.10
How I can build Kernel 5.10?
is your device (m5/m2pro) supported by mainline kernel?
if yes you have to do these things:
  1. set ARCH (armhf/arm64) and your crossompiler
    export ARCH=arm64;export CROSS_COMPILE=‘ccache aarch64-linux-gnu-’
  2. import a defconfig matching your device (on arm64 there is only 1 defconfig for all devices). only filename located in arch/$ARCH/configs
    make defconfig
  3. adjust via menuconfig
    make menuconfig
  4. build (maybe need additional params like dtbs,LOAD_ADDRESS or similar)
    make -j8
  5. sometimes you need to call mkimage (for uImage) or other commands (e.g. for itb) to build the image you want
Hi Frank, thanks for the instructions but I already build the kernel. I used menuconfig to avoid compile some things tha BPI-M5 don’t need, but I don’t know how to make or get the uInitrd file from the builded files. ¿There is some specific commando to do it o is created when I compile the kernel?
This is the commands that I use to compile the kernel:
make -j4 Image dtbs modules -C linux
INSTALL_MOD_PATH=$PWD/output make -j4 modules modules_install -C linux
make headers_install INSTALL_HDR_PATH=$PWD/output -C linux
I’m not sure which imagetype is used on your board and where the kernel/dtb needs to be placed and if uboot config needs to be changed.
Initrd is not part of linux…it is a basic linux userspace system like busybox,buildroot or similar. If you have system on your card,mostly you do not need initrd
