Build BPI-M2Z-bsp bsp fail for P2 zero
Hi all,
I want to make an image for P2 zero, so I downloaded the “BPI-M2Z-bsp” project from git hub to build, but something went wrong!
But another download BPI-M2P-bsp-4.4 is a build success.
Build environment:
  1. Use docker for sinovoip/bpi-build-linux-4.4 https://hub.docker.com/r/sinovoip/bpi-build-linux-4.4
  2. ./build.sh BPI-M2Z-720P
Could you teach me how to solve it? Thanks a lot.
Hello, I just tried to build the latest code BPI-M2Z-bsp, I could build successfully.
In your log, there is something wrong with Makefile at line 150 and line 53. But it should not have error.
Did you use the latest code?
Hi ZB,
Yes, I use “git clone https://github.com/BPI-SINOVOIP/BPI-M2Z-bsp.git” get lastest code, and use docker build environment for “sinovoip/bpi-build-linux-4.4”.
Message:
For Linux bsp kernel 3.4 and kernel 3.10, build with docker image bpi-build.
For Linux bsp kernel 4.4, build with docker image bpi-build-4.4
Hi August,
I downloaded the docker image bpi-build according to your suggestion, but the result is still the same failure. :sob:
I have the same problem!
The kernel is successfully compiled, the error appears only when building u-boot. The same situation for 3 and 4 cores.
apt-get -y install net-tools && apt-get -y install iputils-ping
apt-get -y install gcc-arm-linux-gnueabi
apt-get -y install gcc-arm-linux-gnueabihf
apt-get -y install gcc-aarch64-linux-gnu
apt-get -y install device-tree-compiler
apt-get -y install git && apt-get -y install make && apt-get -y install gcc
apt-get -y install bc && apt-get -y install cpio
apt-get -y install libncurses5-dev && apt-get -y install libncursesw5-dev && apt-get -y install lib32ncurses5
apt-get -y install lib32stdc++6 && apt-get -y install lib32z1 && apt-get -y install bzip2
apt-get -y install u-boot-tools && apt-get -y install lzma && apt-get -y install busybox
or you could use my docker image:
https://cloud.docker.com/repository/docker/jackzengcn/bpiboardbuild
docker pull jackzengcn/bpiboardbuild:latest
Same error but can resolved with
apt install python swig libpython-dev
these resolve all errors images
