BPI-W2 Linux Kernel 5.9-rc4 [rebased mainline]
Hello,
I compiled and stiched together the latest kernel for W2, based on the work from Andreas Faerber [source: kernel/git/afaerber/linux-realtek.git - Realtek ARM SoC kernel tree by Andreas Faerber]
I stitched together with the help of bpi-migrate the latest Arch Arm rootfs, and this boots out of the box after going through the instructions. The bpi-package is a good way - it needs a lot of polishing.
Until few days ago I didn’t knew s**t about U-Boot, so I dont expected much, but, surprisingly the Kernel is loading and doing something to HDMI because it initialized but then I guess It crashes/panics but neither UART or the screen shows anything (which is strange, since it should spill things to UART)
I still dont know s**t about uboot - its an WIP effort. What I read so far is well … its twisted then watching the latest presidential debate in reverse… I probably will figure stuff as I go once I read it 2303 times, however, If you, dear reader, have a tip or my logic is wrong: WRITE TO ME! :slight_smile:
current UART uboot log:
30000000000:"Synchronous Abort" handler, esr 0x96000002
ELR:     62cd0
LR:      62c4c
x0 : 000000000000000c x1 : 000000000000003a
x2 : 0000000000000020 x3 : 0000030000000000
x4 : 0000000000000020 x5 : 000000000007668e
x6 : 0000000000000004 x7 : 000000000000000f
x8 : 00000000000ffae0 x9 : 000000000000000c
x10: 00000000000ff94c x11: 0000000000000008
x12: 00000000ffffffff x13: 0000000007880c3a
x14: 0000000000000000 x15: 0000000000000001
x16: 0000000000000440 x17: 0000000000000004
x18: 000000007feefea8 x19: 0000000000000040
x20: 0000030000000000 x21: 0000030000000000
x22: 000000000007c9e0 x23: 0000000000000008
x24: 0000000000000004 x25: 0000000000000004
x26: 0000000000000004 x27: 00000000000ffd28
x28: 0000000000000000 x29: 00000000000ffca0
Resetting CPU ...
resetting ...
        Banana Pi BPI-W2(SPI ROM:20180907)
C1:80000000
C2
C3h
SD card is detected !!
C4
BPI: try bootcode_from_sdcard !!
        BPI: support boot from sdcard
Command 0x00000000
        interrupt 0x98010424 = 0x00000002
        Command pass
        response 0x98010589 = 0x000000A0
        response 0x9801058A = 0x00000000
        response 0x9801058B = 0x00000000
        response 0x9801058C = 0x00000000
        response 0x9801058D = 0x00000000
        response 0x9801058E = 0x00000000
Command 0x00000008
        Command pass
        response 0x98010589 = 0x00000008
        response 0x9801058C = 0x00000001
        response 0x9801058D = 0x000000AA
        response 0x9801058E = 0x00000013
Command 0x00000037
        Command pass
        response 0x98010589 = 0x00000037
        response 0x9801058D = 0x00000020
        response 0x9801058E = 0x00000083
AppCommand 0x00000029
        Command pass
        response 0x98010589 = 0x0000003F
        response 0x9801058B = 0x000000FF
        response 0x9801058C = 0x00000080
        response 0x9801058E = 0x000000FF
Command 0x00000037
        Command pass
        Command pass
Command 0x00000037
        Command pass
        Command pass
        response 0x9801058A = 0x000000C1
card powerup status = 0x000000C1
card capacity status = 0x00000001
can switch to 1.8V = 0x00000001
Command 0x0000000B
        Command pass
        response 0x98010589 = 0x0000000B
        response 0x9801058C = 0x00000003
        response 0x9801058E = 0x000000D9
wait 0x98010585[4:0] 0
wait 0x98010585[4:0] done
wait 0x98010585[4:0] 1
Command 0x00000002
        interrupt 0x98010424 = 0x00000012
        Command pass
        response 0x98010589 = 0x00000029
        response 0x9801058A = 0x00000005
        response 0x9801058B = 0x00000018
        response 0x9801058D = 0x00000039
        response 0x9801058E = 0x000000CD
        CID 0xA0000 = 0x%x
4D54023F
        CID 0xA0004 = 0x%x
32334153
        CID 0xA0008 = 0x%x
29315047
        CID 0xA000C = 0x%x
39011805
Command 0x00000003
        Command pass
        response 0x98010589 = 0x00000003
        response 0x9801058A = 0x00000012
        response 0x9801058B = 0x00000034
        response 0x9801058C = 0x00000005
        response 0x9801058E = 0x00000021
RCA = 0x00001234
Command 0x00000007
        Command pass
        response 0x98010589 = 0x00000007
        response 0x9801058C = 0x00000007
        response 0x9801058E = 0x00000075
SD card has been initialized.
Command 0x00000037
        Command pass
        response 0x9801058C = 0x00000009
        response 0x9801058E = 0x00000033
AppCommand 0x00000006
        Command pass
        response 0x98010589 = 0x00000006
        response 0x9801058E = 0x000000B9
4-bit bus width
SDR12/normal mode.
Command 0x00000006
        Command pass
        response 0x9801058E = 0x000000DD
DMA finished
cr_auto_Read_Write_1, cmd_idx = 0x00000012
        Command pass
        response 0x98010589 = 0x0000000C
        response 0x9801058C = 0x0000000B
        response 0x9801058E = 0x0000007F
Command 0x0000000D
        Command pass
        response 0x98010589 = 0x0000000D
        response 0x9801058E = 0x0000003F
64b
U-Boot 2015.07 (Apr 01 2019 - 08:48:21 +0800)
CPU  : Cortex-A53 Quad Core - AARCH64
Board: Banana Pi BPI-W2 (RTD1296)
DRAM:  2 GiB
Watchdog: Disabled
mapping memory 0x20000000-0x40000000 non-cached
flushing dcache successfully.
MMC:   Initialize eMMC in traditional mmc flow.
RTD1295 eMMC: 0
rsp[0]=0x15010038,
                       rsp[1]=0x474d4534,
                       rsp[2]=0x5201f681,
                       rsp[3]=0xb84d7469
The cid_val is 15.
rsp[0]=0xd0270132,
                       rsp[1]=0x0f5903ff,
                       rsp[2]=0xf6dbffef,
                       rsp[3]=0x8e40400d
mmc->version=0x40000000
version=0x00000004
[LY] cardtype=57, mmc->card_caps=0f
[LY] freq = 00464388, clk diver = 00000080
[LY] speed up emmc at HS-200
[LY] HS-200 bus width=2
[LY] mmc->boot_caps = 20b
TEMP TX_WINDOW=0x7ffffffe, TX_best=0xf
RX_WINDOW=0xffffff03, RX_best=0x14
TX1_WINDOW=0x7fffff80, TX_best=0x12
[LY] hs200 : 0
[HC] ERASE Unit Size = 524288 bytes
[HC] WPG_SIZE = 8388608 bytes
Device: RTD1295 eMMC
Manufacturer ID: 15
OEM: 100
Tran Speed: 200000000
Rd Block Len: 512
MMC version 4.0
High Capacity: No
Capacity: 7.3 GiB
User Capacity: 7.3 GiB
Boot Capacity: 4 MiB
RPMB Capacity: 512 KiB
Bus Width: 8-bit
Speed: HS200
SD:
SD device index# 0
mmc->scr[0]=2358043,mmc->scr[1]=1000000
SD: init done, no error
SD: capacity 60506112 sectors(0x39b4000), (29544 MB)
Factory: SD
Factory: pp:0, seq#:0x2, size:0x200
------------can't find tmp/factory/000BootParam.h
Set up default values
[logo]src w/h=1920/1080 dst w/h=3840/2160
[ENV] read_env from factory failed
Using default environment
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
vid=31,19,18,16,4,3,
------------can't find tmp/factory/video_rpc.bin
tv_system=25 mode=1
Net:   Realtek PCIe GBE Family Controller mcfg = 0024
dev->name=r8168#0
Checking default environment
Hit Esc or Tab key to enter console mode or rescue linux:  3
------------can't find tmp/factory/recovery
======== Checking into android recovery ====        0
Interface:  SD
  Device 0: Vendor: Man 02544d Snr 31290518 Rev: 5.0 Prod: SA32G
            Type: Removable Hard Disk
            Capacity: 29544.0 MB = 28.8 GB (60506112 x 512)
Filesystem: FAT32 "BPI-BOOT   "
Boot from SD
reading bananapi/bpi-w2/linux/uEnv.txt
1364 bytes read in 6 ms (221.7 KiB/s)
Loaded environment from uEnv.txt
[console:earlycon=uart8250,mmio32,0x98007800 fbcon=map:0 console=ttyS0,460800] [root:/dev/mmcblk0p2 rw rootfstype=ext4 rootwait ] [kernel:] [fdt:]
Banana Pi bpi-w2 chip: RTD1296 Service: linux
==== boot_from_sd (boot from SD mode; secure_mode 0)=====
reading bananapi/bpi-w2/linux/bpi-w2.dtb
46741 bytes read in 8 ms (5.6 MiB/s)
Loading "bananapi/bpi-w2/linux/bpi-w2.dtb" to 0x02100000 is OK.
reading bananapi/bpi-w2/linux/uInitrd
9471906 bytes read in 474 ms (19.1 MiB/s)
Loading "bananapi/bpi-w2/linux/uInitrd" to 0x31400000 is OK.
reading bananapi/bpi-w2/linux/uImage
24185408 bytes read in 1168 ms (19.7 MiB/s)
Loading "bananapi/bpi-w2/linux/uImage" to 0x03000000 is OK.
reading bananapi/bpi-w2/linux/bluecore.audio
3969840 bytes read in 192 ms (19.7 MiB/s)
Loading "bananapi/bpi-w2/linux/bluecore.audio" to 0x0f900000 is OK.
Start Audio Firmware ...
[bonding] 1295 chip
ClassifyBonding  0x00000800, num =  0x00000001 PB (PA)
[AUDIO][WARNING]power saving config, magic  0xffffffff !=  0x80838665
[FW]kylin_bring up hwsetting
Finish kylin_bring_temp hwsetting
[+][AO][aio_HWEnable]
[AO]aio_CRTOn:
SYS_CLOCK_ENABLE1 [ 0x9800000c]: 0x93fe8561
[AO]aio_PowerControlHDMIOn:
set SYS_CLOCK_ENABLE2 [ 0x98000010]: 0xd851e416
[AO]aio_PowerControlDACOn_clk:
SYS_CLOCK_ENABLE2 [ 0x98000010]: 0xd85fe416
[AO]aio_PowerControlSPDIFOn:
set SYS_CLOCK_ENABLE2 [ 0x98000010]: 0xd87fe416
[AO]aio_PowerControlI2SOn:
set SYS_CLOCK_ENABLE2 [ 0x98000010]: 0xd8ffe416
SYS_SOFT_RESET1 [ 0x98000000]: 0xbfd21001
SYS_SOFT_RESET4 [ 0x98000050]: 0x0000801f
[AO]ao_SetDACAnalogOff:
set AIO_O_ACANA_GCTL1 [ 0x98006604]: 0x000a2aac
get AIO_O_ACANA_GCTL1 [ 0x98006604]: 0x24900004
set AIO_I_ACANA_ADC_GCTL2 [ 0x98006610]: 0x880a2a00
[-][AO][aio_HWEnable]
[Audio]SetTickRate  0x000000c8
HDMI Raw Enable: AC3 DTS MPEG2 AAC DDP MLP
SPDIF Raw Enable: AC3 DTS MPEG2 AAC MLP
Force 2ch Format: DTS DTSHD AC3 DDP MLP AAC WMAPRO
[AO][InitHDMIVideoType]HDMI Frequecny 148, resolution 25
@@@@@@@One Step TV System magic number = 0xc0de0bee, addr = 0xa001f800@@@@@@@
@@@@@@@@@ boot_info->tv_sys.interfaceType 0
HDMIOff = 0
[VO]vo->is_hdmi_off_clock_on:0
[VO_SetVideoStandard]st 25 p 1 1 0
[VO_SetVideoStandard]dp_standard:1 data0  0x00000004 data1  0x00000000
[VO_SetVideoStandard]HDMIoff 0 is_tve_on 0 user_cvbs_off 1
lvds.format 0 port_setting  0x00000381 lvds_wb 0
vo->mixer_call_dsr: 0x00000000
[VO setTVStandard 25 3D 0 0]
(TVE) TVE_DAC_mode 0,cmd->enProg 1!!
~~comp 0, ch2 0, mode_3D 0!!
SetVideoStandard return!
(VO_ConfigHDMI_InfoFrame) L:272, is_hdmi_plugin 1, hdmiMode 1!!Mode 1 dataByte1  0x00000040  0x000000a8  0x00000000
dataByte4  0x00000000  0x00000000 int0  0x00000001
(HDMI_3D) mode 1, HDMI_gen 1, En_3D 0, Format_3D 0 scramble:0!!RGB_or_YCbCr:2 Pixel_Colocrt:2 Deep_Color:0 Deep_Depth:0 xvycc:0
@@not hdr tv.  clearDynamicRangeMasteringPkt
 go back SET_HDMI!!
boot_info  0xa0000000 magic  0xffffffff en 255
[AO][_AO_if_video_HDMI_mode]HDMI not enabled
[AO][+]_AO_setup_default_audio_infoframe
[AO][--]_AO_hdmi_disable(0)
[AUDIO WARNING]
[AO][_AO_hdmi_disable]do nothing, HDMI not enable  0x00000000  0x00000001
Audio_Channel_Count 1 :2CH, audio_layout:0
HDMI_Frequency 148 :1080p50,1080p60
Sampling_Frequency 3 :48K
CTS = 148500, N = 6144
[+][HDMI_gen_audio_infoframe]
CA:2CH: L,R
[-][HDMI_gen_audio_infoframe]
SYS_PLL_PSAUDA1 [ 0x98000130]: 0x0050022d
[AO][++]_AO_hdmi_enable(0)
[AUDIO WARNING]
[AO][_AO_hdmi_enable]do nothing, HDMI not enable  0x00000000  0x00000001
[AO][-]_AO_setup_default_audio_infoframe
CONFIG_WAIT_AFW_1_SECOND on
booti_argv ={ booti,0x03000000,0x31400000,0x02100000,}
[Info] convert some env variable to fdt:factory node
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
Info: Try to add new node /factory...
libfdt fdt_add_subnode(): FDT_ERR_NOSPACE
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:
   Image Type:   AArch64 Linux Kernel Image (uncompressed)
   Data Size:    24185344 Bytes = 23.1 MiB
   Load Address: 03000000
   Entry Point:  03000000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
## Loading init Ramdisk from Legacy Image at 31400000 ...
   Image Name:
   Image Type:   AArch64 Linux RAMDisk Image (uncompressed)
   Data Size:    9471842 Bytes = 9 MiB
   Load Address: 00000000
   Entry Point:  00000000
## Flattened Device Tree blob at 02100000
   Booting using the fdt blob at 0x2100000
   reserving fdt memory region: addr=0 size=100000
   reserving fdt memory region: addr=1f000 size=1000
   reserving fdt memory region: addr=1ffe000 size=4000
   reserving fdt memory region: addr=2200000 size=400000
   reserving fdt memory region: addr=2600000 size=c00000
   reserving fdt memory region: addr=3200000 size=b800000
   reserving fdt memory region: addr=10000000 size=14000
   reserving fdt memory region: addr=14200000 size=9200000
   Using Device Tree in place at 0000000002100000, end 000000000210e694
[FDT] mac = 00:10:20:30:40:50
Unable to update property /gmac@0x98060000:local-mac-address, err=FDT_ERR_NOTFOUND
[FDT] update MAC address
Bring UP slave CPUs
Starting Kernel ...
What I did
After building the Image (with the very same make args you used for 4.9.11x) I put the Image and Image.gz files into the root of mmcblk1p1 partition, including System.map (guess not much use for it), that didn’t worked, obviously, since the uboot config loads bananapi/bpi-w2/linux/uImage and bananapi/bpi-w2/linux/uInitrd insted, so I made mkimage uImage files out of the Image including some guesswork on what exact args I need to use.
Question: which flags are the one to be used? Are the memory adresses listed fixed for all files or deterministic? What I mean is: booti_argv ={ booti,0x03000000,0x31400000,0x02100000,}
0x03000000 → kernel → uImage, Image, Image.gz, uImage.gz ? 0x31400000 → ramdisk → uInitird, Initrd? ?
bananapi/bpi-w2/linux/uInitrd and bananapi/bpi-w2/linux/uImage were replaced witk mkimage made files including dtb from the very same directory.
Question 1: Do I need a new properly made .dtb from current sources or can I simply re-use your dtb files released with the 4.9.11x W2 kernel?
Question 2: How do I figure/read/findout which loadadrr where to load the kernel/initrd files to and how to build a proper uImage with mkimage? After the last line nothing happens.
Booting I replaced the files on mmcblk1p1 partition within the /bananapi/…/tree with my own mkimage packs, BUT, I’m not sure I properly packed those, I assume I did since the kernel is loading.
TAKEAWAYS
0) Read the docs, read the docs again…
1) I tried to build from source package under (directory /linux-rtk from BPI-W2-BP package) but it does not compute well on Archlinux, which I run as my usual distro.
I guess that building with Linearo proofed tool-chain made sense 5 years ago, but today GCC 10.x works wonders on arm so using pre 10.x tool-chain does not sense for mainline kernel, a lot of work was done by Andreas for RTD1295/96 board. The goal is to build a kernel with distro-mainted GCC, which is (almost always) the latest GCC release on arch without any headaches. I might be wrong, if you please drop me a line why Linearo is the better thing to use.
@BPI: Could you please push re-based 4.9.xxx latest working kernel source with your pataches/additions on a separate stand-alone GitHub repository? This would be a lot of easier to fiddle/fork and especially diff things. *Please, be so kind, this shouldn’t be of any hustle/effort at all since you already “released” the source there, it just sits in a repo I dont really can efficiently fork. Thanks in advance.
2) Building with ccache and/or distcc with a x86/64 and Aarch64 mixed hosts is a pain so I ended up compiling natively on the board with GCC 10.2 including a dumpload of modules (BPI-W2 4.9.11 has a very small amount available with the bin release, any particular reason? Some initrd/kernel size contrains to consider?)
Any tip for distcc/ccache config that would work with mixed architectures?
I got a 16 cores intel machine that cant help out. The board, is a speedy beast but I takes ~1.5h to chomp the sources with ccached files. I would like to use distcc where my x86 machine is slaved to the W2 and works as a CROSS_COMPILE worker.
@BPI: bpi-tools are a good effort, but it is not (well enough) documented, implemented almost completely without any regard for failures or error handling. I certainly don’t want to judge, uboot seems to be a yet another complexity on top but if you guys release things into the wild, please, at least put some effort to docs, you cant?
Here’s an Idea: give some free hardware in exchange for documenting and they will do it for you. Without it you are pissing on your own business and your sales. Period. I won’t comment on your work (or lack of it) any further.
HARDWARE:
I put some extra m.2 cards and want them to work, they are already present within the current mainline sources, and are reported to be working, so I got big hopes for the W2 beast :]
– UPDATES
FINDINGS/ERRORS/MISTAKES
1) I just spotted my own first wrongdoing, I changed the kernel bootargs see line
The baud rate 460800 for ttyS0 won’t do. I forgot to revert to the working settings of 115200, will retry.
were you able to get both ethernet ports working? the 4.9.119 kernel could only get one working what config file did you use? r8196soc is missing from 5.5rc1 so far banana pi has been a waste of money! @sinovoip are useless in support!
This looks promissing: https://lwn.net/Articles/1034789/
I think we can stitch relatively modern kernel image. and along with ubuntu rootfs, it should work.
Can you share files/repos you’ve used? I ended up native-building my kernel image on BPi-R2 as well. So I expect no less from W2. Something newer than offered 4.9 which came with the board would be really welcome. And I can also participate to include/patch-in certain features, in my case mostly relevant to wireless and ZFS, which I rely on. On R2, I was successful.
