BPI-W2 Kernel 5.9.0-rc5-next
Things are getting more clear, after digging through tons of docs I managed to boot up the self compiled mainline Linux, needed to hack around some stuff but at least it finally loads and boots.
The Kernel craps out because I didn’t preloaded any valid intird in uboot, but this is easily mitigated. Initialization of this board is quite complicated (at least from my perspective)
@bpi: Where can I get some real RTD1295/96 pdf documentation on device initialisation, especially parts of tee/audio firmware, audio/gpu blobs, if any?
More info soon. Anyone any tips?
0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.9.0-rc5-next-20200915-BPI-W2-Kernel (root@rearm) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #4 SMP PREEMPT Sat Oct 10 18:48:07 UTC 2020
[    0.000000] Machine model: Realtek_RTD1296
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000098007800 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] cma: Reserved 32 MiB at 0x000000007e000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000]   Normal   empty
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] On node 0 totalpages: 524288
[    0.000000]   DMA zone: 4096 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 262144 pages, LIFO batch:63
[    0.000000]   DMA32 zone: 4096 pages used for memmap
[    0.000000]   DMA32 zone: 262144 pages, LIFO batch:63
[    0.000000] Unsupported enable-method: rtk-spin-table
[    0.000000] percpu: Embedded 30 pages/cpu s85208 r8192 d29480 u122880
[    0.000000] pcpu-alloc: s85208 r8192 d29480 u122880 alloc=30*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x98007800 fbcon=map:0 console=ttyS0,115200 loglevel=7 root=/dev/mmcblk1p2 rw debug memblock-debug console=ttyS0,115200 earlycon=uwart8250,mmio32,0x98007800 fbcon=0
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
[    0.000000] Memory: 1551008K/2097152K available (17724K kernel code, 2420K rwdata, 4648K rodata, 5696K init, 681K bss, 513376K reserved, 32768K cma-reserved)
[    0.000000] ftrace: allocating 54942 entries in 215 pages
[    0.000000] ftrace: allocated 215 pages with 6 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] rcu:     Offload RCU callbacks from CPUs: (none).
[    0.000000] random: get_random_bytes called from start_kernel+0x610/0x834 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 27.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x63a1e71a3, max_idle_ns: 440795203123 ns
[    0.000005] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 4398046511093ns
[    0.009603] Console: colour dummy device 80x25
[    0.014637] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=108000)
[    0.026302] pid_max: default: 32768 minimum: 301
[    0.031663] LSM: Security Framework initializing
[    0.036909] SELinux:  Initializing.
[    0.040949] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.049291] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.060048] rcu: Hierarchical SRCU implementation.
[    0.066862] EFI services will not be available.
[    0.072134] smp: Bringing up secondary CPUs ...
[    0.077266] smp: Brought up 1 node, 1 CPU
[    0.081786] SMP: Total of 1 processors activated.
[    0.087092] CPU features: detected: 32-bit EL0 Support
[    0.092885] CPU features: detected: CRC32 instructions
[    0.098722] CPU: All CPU(s) started at EL2
[    0.103352] alternatives: patching kernel code
[    0.109791] devtmpfs: initialized
[    0.123961] Registered cp15_barrier emulation handler
[    0.129684] Registered setend emulation handler
[    0.135619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.146860] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.155905] xor: measuring software checksum speed
[    0.201465]    8regs     :  1531.000 MB/sec
[    0.246275]    32regs    :  1811.000 MB/sec
[    0.291086]    arm64_neon:  1336.000 MB/sec
[    0.295826] xor: using function: 32regs (1811.000 MB/sec)
[    0.302052] pinctrl core: initialized pinctrl subsystem
[    0.309625] DMI not present or invalid.
[    0.315521] NET: Registered protocol family 16
[    0.323045] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.331099] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.340171] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.349185] audit: initializing netlink subsys (disabled)
[    0.356509] thermal_sys: Registered thermal governor 'fair_share'
[    0.356518] thermal_sys: Registered thermal governor 'bang_bang'
[    0.364425] audit: type=2000 audit(0.264:1): state=initialized audit_enabled=0 res=1
[    0.382910] thermal_sys: Registered thermal governor 'step_wise'
[    0.382917] thermal_sys: Registered thermal governor 'user_space'
[    0.389765] thermal_sys: Registered thermal governor 'power_allocator'
[    0.397611] cpuidle: using governor ladder
[    0.410314] cpuidle: using governor menu
[    0.415227] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.423310] ASID allocator initialised with 65536 entries
[    0.485529] OF: /pcie2@9803B000: could not get #phy-cells for /efuse@98017000/etn_phy@1B9
[    0.647626] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.655291] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.663181] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.670770] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.680943] cryptd: max_cpu_qlen set to 1000
[    0.758584] raid6: neonx8   gen()  1398 MB/s
[    0.831582] raid6: neonx8   xor()  1027 MB/s
[    0.904569] raid6: neonx4   gen()  1432 MB/s
[    0.977536] raid6: neonx4   xor()  1009 MB/s
[    1.050546] raid6: neonx2   gen()  1342 MB/s
[    1.123494] raid6: neonx2   xor()   926 MB/s
[    1.196504] raid6: neonx1   gen()  1157 MB/s
[    1.269461] raid6: neonx1   xor()   791 MB/s
[    1.342420] raid6: int64x8  gen()   958 MB/s
[    1.415383] raid6: int64x8  xor()   514 MB/s
[    1.488365] raid6: int64x4  gen()  1066 MB/s
[    1.561304] raid6: int64x4  xor()   545 MB/s
[    1.634285] raid6: int64x2  gen()   932 MB/s
[    1.707249] raid6: int64x2  xor()   499 MB/s
[    1.780232] raid6: int64x1  gen()   688 MB/s
[    1.853193] raid6: int64x1  xor()   344 MB/s
[    1.858005] raid6: using algorithm neonx4 gen() 1432 MB/s
[    1.864087] raid6: .... xor() 1009 MB/s, rmw enabled
[    1.869680] raid6: using neon recovery algorithm
[    1.876309] ACPI: Interpreter disabled.
[    1.882699] iommu: Default domain type: Translated
[    1.889442] vgaarb: loaded
[    1.894069] SCSI subsystem initialized
[    1.900105] libata version 3.00 loaded.
[    1.905730] usbcore: registered new interface driver usbfs
[    1.913062] usbcore: registered new interface driver hub
[    1.919731] usbcore: registered new device driver usb
[    1.926270] mc: Linux media interface: v0.10
[    1.932213] videodev: Linux video capture interface: v2.00
[    1.942827] Advanced Linux Sound Architecture Driver Initialized.
[    1.952053] Bluetooth: Core ver 2.22
[    1.956779] NET: Registered protocol family 31
[    1.962224] Bluetooth: HCI device and connection manager initialized
[    1.969451] Bluetooth: HCI socket layer initialized
[    1.975015] Bluetooth: L2CAP socket layer initialized
[    1.980775] Bluetooth: SCO socket layer initialized
[    1.987490] clocksource: Switched to clocksource arch_sys_counter
[    3.360368] VFS: Disk quotas dquot_6.6.0
[    3.364875] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.373577] pnp: PnP ACPI: disabled
[    3.408305] NET: Registered protocol family 2
[    3.414015] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    3.424227] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    3.433313] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    3.441854] TCP: Hash tables configured (established 16384 bind 16384)
[    3.449328] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    3.456969] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    3.465264] NET: Registered protocol family 1
[    3.470696] RPC: Registered named UNIX socket transport module.
[    3.477407] RPC: Registered udp transport module.
[    3.482712] RPC: Registered tcp transport module.
[    3.488015] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.495930] PCI: CLS 0 bytes, default 64
[    3.501334] Trying to unpack rootfs image as initramfs...
[    3.507745] rootfs image is not initramfs (invalid magic at start of compressed archive); looks like an initrd
[    3.531973] Freeing initrd memory: 4096K
[    3.537438] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    3.555335] Initialise system trusted keyrings
[    3.563085] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    3.571869] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.578877] NFS: Registering the id_resolver key type
[    3.584724] Key type id_resolver registered
[    3.589494] Key type id_legacy registered
[    3.594096] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.602346] Key type cifs.idmap registered
[    3.607285] fuse: init (API version 7.31)
[    3.668016] async_tx: api initialized (async)
[    3.672978] Key type asymmetric registered
[    3.677627] Asymmetric key parser 'x509' registered
[    3.683256] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    3.691869] io scheduler mq-deadline registered
[    3.697027] io scheduler kyber registered
[    3.701630] io scheduler bfq registered
[    3.914612] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.954702] brd: module loaded
[    3.972844] loop: module loaded
[    3.977572] zram: Added device: zram0
[    3.982766] usbcore: registered new interface driver rtsx_usb
[    3.994991] libphy: Fixed MDIO Bus: probed
[    4.002730] tun: Universal TUN/TAP device driver, 1.6
[    4.008768] PPP generic driver version 2.4.2
[    4.014045] PPP BSD Compression module registered
[    4.019900] PPP Deflate Compression module registered
[    4.025661] PPP MPPE Compression module registered
[    4.031248] usbcore: registered new interface driver r8152
[    4.037769] usbcore: registered new interface driver asix
[    4.044169] usbcore: registered new interface driver ax88179_178a
[    4.051311] usbcore: registered new interface driver cdc_ether
[    4.058214] usbcore: registered new interface driver cdc_eem
[    4.064897] usbcore: registered new interface driver net1080
[    4.071634] usbcore: registered new interface driver cdc_subset
[    4.078594] usbcore: registered new interface driver zaurus
[    4.085193] usbcore: registered new interface driver cdc_ncm
[    4.094010] mousedev: PS/2 mouse device common for all mice
[    4.102100] usbcore: registered new interface driver xpad
[    4.110364] i2c /dev entries driver
[    4.116926] IR NEC protocol handler initialized
[    4.122427] IR RC5(x/sz) protocol handler initialized
[    4.128232] IR RC6 protocol handler initialized
[    4.133460] IR JVC protocol handler initialized
[    4.138597] IR Sony protocol handler initialized
[    4.143831] IR SANYO protocol handler initialized
[    4.149143] IR Sharp protocol handler initialized
[    4.154446] IR MCE Keyboard/mouse protocol handler initialized
[    4.161019] IR XMP protocol handler initialized
[    4.166574] usbcore: registered new interface driver uvcvideo
[    4.173312] USB Video Class driver (1.1.1)
[    4.184040] device-mapper: uevent: version 1.0.3
[    4.189942] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: [email protected]
[    4.199929] usbcore: registered new interface driver bcm203x
[    4.208750] sdhci: Secure Digital Host Controller Interface driver
[    4.217007] sdhci: Copyright(c) Pierre Ossman
[    4.223037] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.230070] ledtrig-cpu: registered to indicate activity on CPUs
[    4.237924] hid: raw HID events driver (C) Jiri Kosina
[    4.272069] usbcore: registered new interface driver usbhid
[    4.280940] usbhid: USB HID core driver
[    4.285927] ashmem: initialized
[    4.291312] usbcore: registered new interface driver snd-usb-audio
[    4.300444] u32 classifier
[    4.304241]     input device check on
[    4.308406]     Actions configured
[    4.313077] xt_time: kernel timezone is -0000
[    4.318389] IPVS: Registered protocols (TCP, UDP)
[    4.323774] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[    4.332196] IPVS: ipvs loaded.
[    4.335739] IPVS: [rr] scheduler registered.
[    4.340905] Initializing XFRM netlink socket
[    4.345882] NET: Registered protocol family 10
[    4.351723] Segment Routing with IPv6
[    4.355973] mip6: Mobile IPv6
[    4.359460] NET: Registered protocol family 17
[    4.364521] NET: Registered protocol family 15
[    4.369653] Bluetooth: RFCOMM TTY layer initialized
[    4.375273] Bluetooth: RFCOMM socket layer initialized
[    4.381129] Bluetooth: RFCOMM ver 1.11
[    4.385406] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.391396] Bluetooth: BNEP filters: protocol multicast
[    4.397293] Bluetooth: BNEP socket layer initialized
[    4.402890] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.409606] Bluetooth: HIDP socket layer initialized
[    4.415291] Key type dns_resolver registered
[    4.420705] registered taskstats version 1
[    4.425464] Loading compiled-in X.509 certificates
[    4.431114] Key type ._fscrypt registered
[    4.435689] Key type .fscrypt registered
[    4.440152] Key type fscrypt-provisioning registered
[    4.446495] Btrfs loaded, crc32c=crc32c-generic
[    4.453114] psci_checker: Missing PSCI operations, aborting tests
[    4.460487] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.471203] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.478868] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    4.488810] ALSA device list:
[    4.492190]   No soundcards found.
[    4.496060] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    4.504837] Warning: unable to open an initial console.
[    4.510774] md: Waiting for all devices to be available before autodetect
[    4.518873] md: If you don't use raid, use raid=noautodetect
[    4.525294] md: Autodetecting RAID arrays.
[    4.529940] md: autorun ...
[    4.533113] md: ... autorun DONE.
[    4.537088] RAMDISK: Couldn't find valid RAM disk image starting at 0.
[    4.544641] VFS: Cannot open root device "mmcblk1p2" or unknown-block(0,0): error -6
[    4.557425] Please append a correct "root=" boot option; here are the available partitions:
[    4.566880] 0100            4096 ram0
[    4.566886]  (driver?)
[    4.573836] 0101            4096 ram1
[    4.573842]  (driver?)
[    4.580729] 0102            4096 ram2
[    4.580735]  (driver?)
[    4.587619] 0103            4096 ram3
[    4.587625]  (driver?)
[    4.594498] 0104            4096 ram4
[    4.594504]  (driver?)
[    4.601387] 0105            4096 ram5
[    4.601392]  (driver?)
[    4.608275] 0106            4096 ram6
[    4.608281]  (driver?)
[    4.615154] 0107            4096 ram7
[    4.615160]  (driver?)
[    4.622043] 0108            4096 ram8
[    4.622048]  (driver?)
[    4.628932] 0109            4096 ram9
[    4.628937]  (driver?)
[    4.635822] 010a            4096 ram10
[    4.635827]  (driver?)
[    4.642798] 010b            4096 ram11
[    4.642803]  (driver?)
[    4.649784] 010c            4096 ram12
[    4.649790]  (driver?)
[    4.656771] 010d            4096 ram13
[    4.656776]  (driver?)
[    4.663758] 010e            4096 ram14
[    4.663763]  (driver?)
[    4.670734] 010f            4096 ram15
[    4.670740]  (driver?)
[    4.677730] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    4.687033] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.9.0-rc5-next-20200915-BPI-W2-Kernel #4
[    4.696721] Hardware name: Realtek_RTD1296 (DT)
[    4.701814] Call trace:
[    4.704569]  dump_backtrace+0x0/0x1dc
[    4.708688]  show_stack+0x24/0x30
[    4.712417]  dump_stack+0xcc/0x108
[    4.716241]  panic+0x178/0x344
[    4.719676]  mount_block_root+0x2c4/0x358
[    4.724185]  mount_root+0x7c/0x8c
[    4.727913]  prepare_namespace+0x140/0x180
[    4.732520]  kernel_init_freeable+0x230/0x25c
[    4.737422]  kernel_init+0x20/0x124
[    4.741345]  ret_from_fork+0x10/0x18
[    4.745367] Kernel Offset: disabled
[    4.749288] CPU features: 0x0040002,20002004
[    4.754086] Memory Limit: none
[    4.757523] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
It seems like rtk-emmc driver not loaded
I have ported emmc driver to 5.9.0, check my github repo: https://github.com/jjm2473/rtd1295-next
Could you please share your hacks/fixes/changes as a patchset ? Did you manage to try with the current 5.16 branch?
Source is here. But this source is lack for many drivers.
Hi, could you please shed some light on how you got your custom kernel to boot ? I am struggeling to get my custom kernel started. After fatloading/tftp-ing the dtb, kernel and initrd, the “go all” at least starts but no further output compared to ootb-kernel.
TIA -Markus
were you able to get the 2nd network port working? what config file are you using?
