BPI-R64 Thermal
I activated all that stuff in -devices-generic_thermal_sysfs_drivers (specially the MTK things). After reboot I find the expected file /sys/class/thermal/thermal_zone0/temp. But alas - it is empty! Zero degrees!
Am I doing something wrong or should it be true that there is no temperature measuring device? That would be a pity as I wanted to automatically start a Fan when appropriate.
maybe some related modules: Lm-sensors support
which kernel do you use?
here with 5.5-merged:
root@bpi-r2:~# cat /sys/class/thermal/thermal_zone0/temp
48727
root@bpi-r2:~# lsmod
ath10k_pci             57344  0
ath10k_core           454656  1 ath10k_pci
ath                    32768  1 ath10k_core
spi_mt65xx             20480  0
mtk_thermal            16384  0
pwm_mediatek           16384  0
mt6577_auxadc          16384  0
mtk_pmic_keys          16384  0
nvmem_mtk_efuse        16384  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
Edit: oh sorry,you talking about r64…not r2
BPI-R64(MT7622) has temperature measuring device.
However, it is found that there are some issues causing cpu-temp read error.
I’ve prepared two sketch patches based on kernel 5.5 rc-1 to solve the known MT7622 thermal issues.
These will be sent to upstream mainline ASAP.
Please apply the following two patches in order.
[1st patch]: modify the common code in order to prepare for adding correct MT7622 thermal support.
 diff --git a/drivers/thermal/mtk_thermal.c b/drivers/thermal/mtk_thermal.c
index acf4854..31dd1b4 100644
--- a/drivers/thermal/mtk_thermal.c
+++ b/drivers/thermal/mtk_thermal.c
@@ -120,18 +120,18 @@
  * MT2701 has 3 sensors and needs 3 VTS calibration data.
  * MT2712 has 4 sensors and needs 4 VTS calibration data.
-#define CALIB_BUF0_VALID		BIT(0)
-#define CALIB_BUF1_ADC_GE(x)		(((x) >> 22) & 0x3ff)
-#define CALIB_BUF0_VTS_TS1(x)		(((x) >> 17) & 0x1ff)
-#define CALIB_BUF0_VTS_TS2(x)		(((x) >> 8) & 0x1ff)
-#define CALIB_BUF1_VTS_TS3(x)		(((x) >> 0) & 0x1ff)
-#define CALIB_BUF2_VTS_TS4(x)		(((x) >> 23) & 0x1ff)
-#define CALIB_BUF2_VTS_TS5(x)		(((x) >> 5) & 0x1ff)
-#define CALIB_BUF2_VTS_TSABB(x)		(((x) >> 14) & 0x1ff)
-#define CALIB_BUF0_DEGC_CALI(x)		(((x) >> 1) & 0x3f)
-#define CALIB_BUF0_O_SLOPE(x)		(((x) >> 26) & 0x3f)
-#define CALIB_BUF0_O_SLOPE_SIGN(x)	(((x) >> 7) & 0x1)
-#define CALIB_BUF1_ID(x)		(((x) >> 9) & 0x1)
+#define CALIB_BUF0_VALID_V1		BIT(0)
+#define CALIB_BUF1_ADC_GE_V1(x)		(((x) >> 22) & 0x3ff)
+#define CALIB_BUF0_VTS_TS1_V1(x)	(((x) >> 17) & 0x1ff)
+#define CALIB_BUF0_VTS_TS2_V1(x)	(((x) >> 8) & 0x1ff)
+#define CALIB_BUF1_VTS_TS3_V1(x)	(((x) >> 0) & 0x1ff)
+#define CALIB_BUF2_VTS_TS4_V1(x)	(((x) >> 23) & 0x1ff)
+#define CALIB_BUF2_VTS_TS5_V1(x)	(((x) >> 5) & 0x1ff)
+#define CALIB_BUF2_VTS_TSABB_V1(x)	(((x) >> 14) & 0x1ff)
+#define CALIB_BUF0_DEGC_CALI_V1(x)	(((x) >> 1) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_V1(x)	(((x) >> 26) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_SIGN_V1(x)	(((x) >> 7) & 0x1)
+#define CALIB_BUF1_ID_V1(x)		(((x) >> 9) & 0x1)
 enum {
 	VTS1,
@@ -143,6 +143,11 @@
 	MAX_NUM_VTS,
+enum mtk_thermal_version {
+	MTK_THERMAL_V1 = 1,
+	MTK_THERMAL_V2,
 /* MT2701 thermal sensors */
 #define MT2701_TS1	0
 #define MT2701_TS2	1
@@ -245,6 +250,9 @@
 	const int *controller_offset;
 	bool need_switch_bank;
 	struct thermal_bank_cfg bank_data[MAX_NUM_ZONES];
+	enum mtk_thermal_version version;
+	int (*extract)(struct mtk_thermal *mt, u32 *buf);
+	int (*convert)(struct mtk_thermal *mt, int sensno, s32 raw);
 struct mtk_thermal {
@@ -358,6 +366,9 @@
 static const int mt7622_vts_index[MT7622_NUM_SENSORS] = { VTS1 };
 static const int mt7622_tc_offset[MT7622_NUM_CONTROLLER] = { 0x0, };
+static int mtk_thermal_extract_efuse_v1(struct mtk_thermal *mt, u32 *buf);
+static int raw_to_mcelsius_v1(struct mtk_thermal *mt, int sensno, s32 raw);
  * The MT8173 thermal controller has four banks. Each bank can read up to
  * four temperature sensors simultaneously. The MT8173 has a total of 5
@@ -398,6 +409,9 @@
 	.msr = mt8173_msr,
 	.adcpnp = mt8173_adcpnp,
 	.sensor_mux_values = mt8173_mux_values,
+	.version = MTK_THERMAL_V1,
+	.extract = mtk_thermal_extract_efuse_v1,
+	.convert = raw_to_mcelsius_v1,
@@ -428,6 +442,9 @@
 	.msr = mt2701_msr,
 	.adcpnp = mt2701_adcpnp,
 	.sensor_mux_values = mt2701_mux_values,
@@ -458,6 +475,9 @@
 	.msr = mt2712_msr,
 	.adcpnp = mt2712_adcpnp,
 	.sensor_mux_values = mt2712_mux_values,
@@ -482,6 +502,9 @@
 	.msr = mt7622_msr,
 	.adcpnp = mt7622_adcpnp,
 	.sensor_mux_values = mt7622_mux_values,
+	.version = MTK_THERMAL_V2,
@@ -515,6 +538,9 @@
 	.msr = mt8183_msr,
 	.adcpnp = mt8183_adcpnp,
 	.sensor_mux_values = mt8183_mux_values,
@@ -525,7 +551,7 @@
  * This converts the raw ADC value to mcelsius using the SoC specific
  * calibration constants
-static int raw_to_mcelsius(struct mtk_thermal *mt, int sensno, s32 raw)
 	s32 tmp;
@@ -594,9 +620,9 @@
 		raw = readl(mt->thermal_base +
 			    conf->msr[conf->bank_data[bank->id].sensors[i]]);
-		temp = raw_to_mcelsius(mt,
-				       conf->bank_data[bank->id].sensors[i],
-				       raw);
+		temp = conf->convert(mt,
+				     conf->bank_data[bank->id].sensors[i],
+				     raw);
 		 * The first read of a sensor often contains very high bogus
@@ -698,9 +724,11 @@
 	writel(auxadc_phys_base + AUXADC_CON1_CLR_V,
 	       controller_base + TEMP_ADCMUXADDR);
-	/* AHB address for pnp sensor mux selection */
-	writel(apmixed_phys_base + APMIXED_SYS_TS_CON1,
-	       controller_base + TEMP_PNPMUXADDR);
+	if (mt->conf->version == MTK_THERMAL_V1) {
+		/* AHB address for pnp sensor mux selection */
+		writel(apmixed_phys_base + APMIXED_SYS_TS_CON1,
+		       controller_base + TEMP_PNPMUXADDR);
 	/* AHB value for auxadc enable */
 	writel(BIT(conf->auxadc_channel), controller_base + TEMP_ADCEN);
@@ -758,6 +786,51 @@
 	return of_translate_address(np, regaddr_p);
+	int i;
+	if (!(buf[0] & CALIB_BUF0_VALID_V1))
+		return -EINVAL;
+	mt->adc_ge = CALIB_BUF1_ADC_GE_V1(buf[1]);
+	for (i = 0; i < mt->conf->num_sensors; i++) {
+		switch (mt->conf->vts_index[i]) {
+		case VTS1:
+			mt->vts[VTS1] = CALIB_BUF0_VTS_TS1_V1(buf[0]);
+			break;
+		case VTS2:
+			mt->vts[VTS2] = CALIB_BUF0_VTS_TS2_V1(buf[0]);
+			break;
+		case VTS3:
+			mt->vts[VTS3] = CALIB_BUF1_VTS_TS3_V1(buf[1]);
+			break;
+		case VTS4:
+			mt->vts[VTS4] = CALIB_BUF2_VTS_TS4_V1(buf[2]);
+			break;
+		case VTS5:
+			mt->vts[VTS5] = CALIB_BUF2_VTS_TS5_V1(buf[2]);
+			break;
+		case VTSABB:
+			mt->vts[VTSABB] =
+				CALIB_BUF2_VTS_TSABB_V1(buf[2]);
+			break;
+		default:
+			break;
+	mt->degc_cali = CALIB_BUF0_DEGC_CALI_V1(buf[0]);
+	if (CALIB_BUF1_ID_V1(buf[1]) &
+	    CALIB_BUF0_O_SLOPE_SIGN_V1(buf[0]))
+		mt->o_slope = -CALIB_BUF0_O_SLOPE_V1(buf[0]);
+	else
+		mt->o_slope = CALIB_BUF0_O_SLOPE_V1(buf[0]);
+	return 0;
 static int mtk_thermal_get_calibration_data(struct device *dev,
 					    struct mtk_thermal *mt)
@@ -793,42 +866,9 @@
 		goto out;
-	if (buf[0] & CALIB_BUF0_VALID) {
-		mt->adc_ge = CALIB_BUF1_ADC_GE(buf[1]);
-		for (i = 0; i < mt->conf->num_sensors; i++) {
-			switch (mt->conf->vts_index[i]) {
-			case VTS1:
-				mt->vts[VTS1] = CALIB_BUF0_VTS_TS1(buf[0]);
-				break;
-			case VTS2:
-				mt->vts[VTS2] = CALIB_BUF0_VTS_TS2(buf[0]);
-				break;
-			case VTS3:
-				mt->vts[VTS3] = CALIB_BUF1_VTS_TS3(buf[1]);
-				break;
-			case VTS4:
-				mt->vts[VTS4] = CALIB_BUF2_VTS_TS4(buf[2]);
-				break;
-			case VTS5:
-				mt->vts[VTS5] = CALIB_BUF2_VTS_TS5(buf[2]);
-				break;
-			case VTSABB:
-				mt->vts[VTSABB] = CALIB_BUF2_VTS_TSABB(buf[2]);
-				break;
-			default:
-				break;
-		mt->degc_cali = CALIB_BUF0_DEGC_CALI(buf[0]);
-		if (CALIB_BUF1_ID(buf[1]) &
-		    CALIB_BUF0_O_SLOPE_SIGN(buf[0]))
-			mt->o_slope = -CALIB_BUF0_O_SLOPE(buf[0]);
-		else
-			mt->o_slope = CALIB_BUF0_O_SLOPE(buf[0]);
-	} else {
+	if (mt->conf->extract(mt, buf)) {
 		dev_info(dev, "Device not calibrated, using default calibration values\n");
+		ret = -EINVAL;
 out:
[2nd patch]: refine MT7622-specific settings to fix cpu-temp read error
  • hardware init flow
  • efuse layout
  • raw_to_mcelsius formula
index 31dd1b4..65a86af 100644
@@ -38,6 +38,7 @@
 #define TEMP_MONIDET0		0x014
 #define TEMP_MONIDET1		0x018
 #define TEMP_MSRCTL0		0x038
+#define TEMP_MSRCTL1		0x03c
 #define TEMP_AHBPOLL		0x040
 #define TEMP_AHBTO		0x044
 #define TEMP_ADCPNP0		0x048
@@ -133,6 +134,20 @@
+ * Layout of the fuses providing the calibration data
+ * These macros could be used for MT7622.
+#define CALIB_BUF0_ADC_OE_V2(x)		(((x) >> 22) & 0x3ff)
+#define CALIB_BUF0_ADC_GE_V2(x)		(((x) >> 12) & 0x3ff)
+#define CALIB_BUF0_DEGC_CALI_V2(x)	(((x) >> 6) & 0x3f)
+#define CALIB_BUF0_O_SLOPE_V2(x)	(((x) >> 0) & 0x3f)
+#define CALIB_BUF1_VTS_TS1_V2(x)	(((x) >> 23) & 0x1ff)
+#define CALIB_BUF1_VTS_TS2_V2(x)	(((x) >> 14) & 0x1ff)
+#define CALIB_BUF1_VTS_TSABB_V2(x)	(((x) >> 5) & 0x1ff)
+#define CALIB_BUF1_VALID_V2(x)		(((x) >> 4) & 0x1)
+#define CALIB_BUF1_O_SLOPE_SIGN_V2(x)	(((x) >> 3) & 0x1)
 enum {
 	VTS1,
 	VTS2,
@@ -266,8 +281,10 @@
 	/* Calibration values */
 	s32 adc_ge;
+	s32 adc_oe;
 	s32 degc_cali;
 	s32 o_slope;
+	s32 o_slope_sign;
 	s32 vts[MAX_NUM_VTS];
 	const struct mtk_thermal_data *conf;
@@ -367,7 +384,9 @@
+static int mtk_thermal_extract_efuse_v2(struct mtk_thermal *mt, u32 *buf);
+static int raw_to_mcelsius_v2(struct mtk_thermal *mt, int sensno, s32 raw);
@@ -503,8 +522,8 @@
-	.extract = mtk_thermal_extract_efuse_v1,
-	.convert = raw_to_mcelsius_v1,
+	.extract = mtk_thermal_extract_efuse_v2,
+	.convert = raw_to_mcelsius_v2,
@@ -566,6 +585,36 @@
 	return mt->degc_cali * 500 - tmp;
+	s32 format_1 = 0;
+	s32 format_2 = 0;
+	s32 g_oe = 1;
+	s32 g_gain = 1;
+	s32 g_x_roomt = 0;
+	s32 tmp = 0;
+	if (raw == 0)
+		return 0;
+	raw &= 0xfff;
+	g_gain = 10000 + (((mt->adc_ge - 512) * 10000) >> 12);
+	g_oe = mt->adc_oe - 512;
+	format_1 = mt->vts[VTS2] + 3105 - g_oe;
+	format_2 = (mt->degc_cali * 10) >> 1;
+	g_x_roomt = (((format_1 * 10000) >> 12) * 10000) / g_gain;
+	tmp = (((((raw - g_oe) * 10000) >> 12) * 10000) / g_gain) - g_x_roomt;
+	tmp = tmp * 10 * 100 / 11;
+	if (mt->o_slope_sign == 0)
+		tmp = tmp / (165 - mt->o_slope);
+	else
+		tmp = tmp / (165 + mt->o_slope);
+	return (format_2 - tmp) * 100;
  * mtk_thermal_get_bank - get bank
  * @bank:	The bank
@@ -831,6 +880,23 @@
 	return 0;
+	if (!CALIB_BUF1_VALID_V2(buf[1]))
+		return -EINVAL;
+	mt->adc_oe = CALIB_BUF0_ADC_OE_V2(buf[0]);
+	mt->adc_ge = CALIB_BUF0_ADC_GE_V2(buf[0]);
+	mt->degc_cali = CALIB_BUF0_DEGC_CALI_V2(buf[0]);
+	mt->o_slope = CALIB_BUF0_O_SLOPE_V2(buf[0]);
+	mt->vts[VTS1] = CALIB_BUF1_VTS_TS1_V2(buf[1]);
+	mt->vts[VTS2] = CALIB_BUF1_VTS_TS2_V2(buf[1]);
+	mt->vts[VTSABB] = CALIB_BUF1_VTS_TSABB_V2(buf[1]);
+	mt->o_slope_sign = CALIB_BUF1_O_SLOPE_SIGN_V2(buf[1]);
+	return 0;
@@ -902,6 +968,28 @@
 MODULE_DEVICE_TABLE(of, mtk_thermal_of_match);
+static void mtk_thermal_turn_on_buffer(void __iomem *apmixed_base)
+	int tmp;
+	tmp = readl(apmixed_base + APMIXED_SYS_TS_CON1);
+	tmp &= ~(0x37);
+	tmp |= 0x1;
+	writel(tmp, apmixed_base + APMIXED_SYS_TS_CON1);
+	udelay(200);
+static void mtk_thermal_release_periodic_ts(struct mtk_thermal *mt,
+					    void __iomem *auxadc_base)
+	int tmp;
+	writel(0x800, auxadc_base + AUXADC_CON1_SET_V);
+	writel(0x1, mt->thermal_base + TEMP_MONCTL0);
+	tmp = readl(mt->thermal_base + TEMP_MSRCTL1);
+	writel((tmp & (~0x10e)), mt->thermal_base + TEMP_MSRCTL1);
 static int mtk_thermal_probe(struct platform_device *pdev)
 	int ret, i, ctrl_id;
@@ -910,6 +998,7 @@
 	struct resource *res;
 	u64 auxadc_phys_base, apmixed_phys_base;
 	struct thermal_zone_device *tzdev;
+	void __iomem *apmixed_base, *auxadc_base;
 	mt = devm_kzalloc(&pdev->dev, sizeof(*mt), GFP_KERNEL);
 	if (!mt)
@@ -944,6 +1033,7 @@
 		return -ENODEV;
+	auxadc_base = of_iomap(auxadc, 0);
 	auxadc_phys_base = of_get_phys_base(auxadc);
 	of_node_put(auxadc);
@@ -959,6 +1049,7 @@
 		return -ENODEV;
+	apmixed_base = of_iomap(apmixedsys, 0);
 	apmixed_phys_base = of_get_phys_base(apmixedsys);
 	of_node_put(apmixedsys);
@@ -984,6 +1075,11 @@
 		goto err_disable_clk_auxadc;
+	if (mt->conf->version == MTK_THERMAL_V2) {
+		mtk_thermal_turn_on_buffer(apmixed_base);
+		mtk_thermal_release_periodic_ts(mt, auxadc_base);
 	for (ctrl_id = 0; ctrl_id < mt->conf->num_controller ; ctrl_id++)
 		for (i = 0; i < mt->conf->num_banks; i++)
 			mtk_thermal_init_bank(mt, i, apmixed_phys_base,
thank you henry
have added your patches to my 5.4-r64-main branch, but not yet tested
edit: seems working:
root@bpi-r64:~# cat /sys/class/thermal/thermal_zone0/temp
36700
root@bpi-r64:~#
Thanks much, Henry and Frank!
I’ll give it a try.
@ntech does it work for you?
@henry Maybe you can send me your fullname+email via pm so i can set author-information in git.
Sorry, couldn’t test it by now. I hope I can test it next weekend.
hi @henry seems mt7622 thermal patches breaking mt7623 thermal…
on my old 5.4-main branch thermal was working…on new (where i merged r64 patches) it gives invalid argument
dmesg shows this:
mtk-thermal: probe of 1100b000.thermal failed with error -22
see [BPI-R2] Kernel Development
error is generated here:
 838 static int mtk_thermal_extract_efuse_v1(struct mtk_thermal *mt, u32 *buf)
 839 {
 840         int i;
 841 printk(KERN_ALERT "DEBUG: Passed %s %d \n",__FUNCTION__,__LINE__);
 842         if (!(buf[0] & CALIB_BUF0_VALID_V1))
 843                 return -EINVAL;
 844 printk(KERN_ALERT "DEBUG: Passed %s %d \n",__FUNCTION__,__LINE__);
dmesg (line 844 is not printed):
root@bpi-r2:~# modprobe mtk_thermal
[  619.150578] DEBUG: Passed mtk_thermal_get_calibration_data 929
[  619.156518] DEBUG: Passed mtk_thermal_get_calibration_data 935
[  619.162478] DEBUG: Passed mtk_thermal_extract_efuse_v1 841
[  619.168091] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[  619.176959] DEBUG: Passed mtk_thermal_get_calibration_data 941
[  619.182949] mtk-thermal: probe of 1100b000.thermal failed with error -22
values checked:
0x7a254000 0x1 0x0 = buf[0],CALIB_BUF0_VALID_V1,(buf[0] & CALIB_BUF0_VALID_V1)
before BUF0_VALID was only used in mtk_thermal_get_calibration_data but code was moved to extract-function which is called in get-calibration-data…
i guess this is the problem:
+		ret = -EINVAL;
before data is only read if valid and if not only message is printed…now mtk_thermal_get_calibration_data is exited with EINVAL in this case…
i disabled only this “ret=-EINVAL” and have same behaviour as without Patch…so better as reverting full Patches
@frank-w
Thanks for your report !
Indeed “ret=-EINVAL” is an unnecessary action. So I revised my patches as follows.
Thanks.
index acf4854cbb8b..2d122a11d524 100644
 enum {
    VTS1,
@@ -143,6 +143,11 @@ enum {
    MAX_NUM_VTS,
+   MTK_THERMAL_V2,
@@ -245,6 +250,9 @@ struct mtk_thermal_data {
@@ -358,6 +366,9 @@ static const int mt7622_mux_values[MT7622_NUM_SENSORS] = { 0, };
@@ -398,6 +409,9 @@ static const struct mtk_thermal_data mt8173_thermal_data = {
    .msr = mt8173_msr,
@@ -428,6 +442,9 @@ static const struct mtk_thermal_data mt2701_thermal_data = {
    .msr = mt2701_msr,
@@ -458,6 +475,9 @@ static const struct mtk_thermal_data mt2712_thermal_data = {
    .msr = mt2712_msr,
@@ -482,6 +502,9 @@ static const struct mtk_thermal_data mt7622_thermal_data = {
    .msr = mt7622_msr,
@@ -515,6 +538,9 @@ static const struct mtk_thermal_data mt8183_thermal_data = {
    .msr = mt8183_msr,
@@ -525,7 +551,7 @@ static const struct mtk_thermal_data mt8183_thermal_data = {
    s32 tmp;
@@ -594,9 +620,9 @@ static int mtk_thermal_bank_temperature(struct mtk_thermal_bank *bank)
-                      raw);
+                    raw);
@@ -698,9 +724,11 @@ static void mtk_thermal_init_bank(struct mtk_thermal *mt, int num,
@@ -758,6 +786,51 @@ static u64 of_get_phys_base(struct device_node *np)
+   int i;
+       return -EINVAL;
+       case VTS1:
+           break;
+       case VTS2:
+           break;
+       case VTS3:
+           break;
+       case VTS4:
+           break;
+       case VTS5:
+           break;
+       case VTSABB:
+           mt->vts[VTSABB] =
+           break;
+       default:
+           break;
+   else
+   return 0;
@@ -793,43 +866,8 @@ static int mtk_thermal_get_calibration_data(struct device *dev,
        goto out;
-           case VTS1:
-               break;
-           case VTS2:
-               break;
-           case VTS3:
-               break;
-           case VTS4:
-               break;
-           case VTS5:
-               break;
-           case VTSABB:
-               break;
-           default:
-               break;
-       else
-   } else {
 out:
    kfree(buf);
  • efuse layout
index 2d122a11d524..dbee5c0792b0 100644
@@ -38,6 +38,7 @@
 enum {
    VTS1,
    VTS2,
@@ -266,8 +281,10 @@ struct mtk_thermal {
    s32 adc_ge;
+   s32 adc_oe;
    s32 degc_cali;
    s32 o_slope;
+   s32 o_slope_sign;
@@ -367,7 +384,9 @@ static const int mt7622_vts_index[MT7622_NUM_SENSORS] = { VTS1 };
@@ -503,8 +522,8 @@ static const struct mtk_thermal_data mt7622_thermal_data = {
@@ -566,6 +585,36 @@ static int raw_to_mcelsius_v1(struct mtk_thermal *mt, int sensno, s32 raw)
+   s32 format_1 = 0;
+   s32 format_2 = 0;
+   s32 g_oe = 1;
+   s32 g_gain = 1;
+   s32 tmp = 0;
+   if (raw == 0)
+       return 0;
+   raw &= 0xfff;
+   else
  * @bank:  The bank
@@ -831,6 +880,23 @@ static int mtk_thermal_extract_efuse_v1(struct mtk_thermal *mt, u32 *buf)
    return 0;
+       return -EINVAL;
+   return 0;
@@ -900,6 +966,28 @@ static const struct of_device_id mtk_thermal_of_match[] = {
+   int tmp;
+   tmp &= ~(0x37);
+   tmp |= 0x1;
+   udelay(200);
+   int tmp;
@@ -908,6 +996,7 @@ static int mtk_thermal_probe(struct platform_device *pdev)
    if (!mt)
@@ -942,6 +1031,7 @@ static int mtk_thermal_probe(struct platform_device *pdev)
        return -ENODEV;
@@ -957,6 +1047,7 @@ static int mtk_thermal_probe(struct platform_device *pdev)
        return -ENODEV;
@@ -982,6 +1073,11 @@ static int mtk_thermal_probe(struct platform_device *pdev)
Thank you. Have you changed anything else?
Currently don’t want to revert if this is the only change.
I can test on 5.5, but want to leave 5.4 now clean so far :slight_smile: Still wondering about the no calibration data on r2
I don’t change anything else.
Will take some time to look into the no calibration data issue on r2.
Thanks
