Tell me please! How to make the hard drive (sata) work on BPI-R64 OpenWrt? which modules to add to the assembly?
Afaik you need to enable sata in dts and disable pcie1,because they share same pcie-port on soc
status=“ok”
Also on sata-phy
status=“disable”
maybe asm_sel needs to be set to output-low, have done all 3 and see my connected hdd
sata.patch (635 Bytes)
root@bpi-r64:~# cat /proc/partitions
major minor #blocks name
179 0 7634944 mmcblk0
179 1 262144 mmcblk0p1
179 2 7105536 mmcblk0p2
179 24 31166976 mmcblk1
179 25 262144 mmcblk1p1
179 26 7105536 mmcblk1p2
8 0 732574584 sda
8 1 307200 sda1
8 2 614400 sda2
8 3 131072 sda3
8 4 52068289 sda4
8 5 358400 sda5
8 6 15728640 sda6
8 7 227866624 sda7
8 8 414515200 sda8
8 9 20981760 sda9
Thanks !!! done!!! here is a link to the assembly with a working image OpenWrt with support for HDD. https://drive.google.com/drive/folders/1VQ7e4uyw4oTB1whDGXAPrhgnJZW3fM3U?usp=sharing
Hello again and a happy new year!
Found a R64 under the christmas tree and obviously there’s something missing. I applied the patch and activated sata in the config, but alas: no disk showing up!
Can you help?
Just try my sata patch modifying dts (enable sata node and change asm_sel)
see my previous posting. Imho i have already enabled it in 5.4-r64-main
https://github.com/frank-w/BPI-R2-4.14/commits/5.4-r64-main
A happy new year to you too
That’s what I did - with only one difference: In mt7622-bananapi-bpi-r64.dts it is always spelled “okay” instead of “ok”, so I chose okay. Is that the problem possibly?
Tried “ok” - no change, seems to work - or better “not work” anyway.
By the way: my plan is to make it a backup-storage, found a couple of 1TB disks in the workshop and got myself a SATA-multiplexer and a nice 4-disk-hotplug-housing from aliexpress. This setup works fine for the R2, now let’s see for the R64.
Oh,you’re right…it should be “okay”. But Both are checked: https://github.com/frank-w/BPI-R2-4.14/blob/4da7b54690665353f469799733d689e23d5b7407/drivers/of/base.c#L568
Maybe a power issue? Have you set gpio90?
I will rebase 5.4 again after some other things fixed/tested
You loaded the right dtb?
What should I do about GPIO 90? Set to output-low? Yeah, did that.
In fact, I consider myself as silly/stupid … I think I just missed something. Remember I had the same problem with the R2.
Oh you know sometimes I hate myself for ordering things which I can’t really comprehend. A couple of days ago my wife gave me an oscilloscope for birthday … still no idea how to use
So I found my silly mistake:
Your tree / your scripts generate BPI-BOOT in ./linux-4.19 and I always kept fiddling in ./linux. So there could be no change whatever I did
Maybe it’s time for an appointment with my optometrist for some new glasses.
Anyway, everything runs like a charm. By now it’s only a tabletop-setup with a SSD rudely plugged upright into the board. Next task is mounting it into the good old SCSI-case (100w power-supply, 4 inch Power-Fan, two 5.25 drive-slots for the HDD cradle an maybe a Tapedrive one fine day)
Thanks much for your help!
And now I got my things running I checked the Disk-Performance with Samba-Shares:
- Synology DS218+…: 112 MB/s
- R64…: 112 MB/s
Looks like 1 GBit
Quite fine!
