BPI-R2 new image :ubuntu-16.04-mate-desktop-docker-preview2-bpi-r2-sd-emmc.img-2017-08-01
(bpi team) #1
2017-08-01-ubuntu-16.04-mate-desktop-docker-preview2-bpi-r2-sd-emmc.img.zip
  1. based on ubuntu 16.04.2 LTS Mate Desktop
  2. support BPI-R2 kernel 4.4.70
  3. username & password: pi/bananapi , root/bananapi
  4. support HDMI
  5. support GMAC * 5 (2 real GE ports, 1 is WAN port, another is connected to 4 LAN ports)
  6. support SATA * 2
  7. support eMMC (support boot from eMMC)
  8. support IR
  9. support OTG
  10. support PWM (PWM1/PWM2/PWM3, PWM4 and PWM5 are not supported)
  11. support USB 3.0 * 2
  12. support mPCIe
  13. support uEnv.txt to fatload uImage
  14. support bpi-bootsel
  15. support bpi-copy to write SD/eMMC with img.zip file
  16. support docker
  17. ref. https://github.com/BPI-SINOVOIP/BPI-R2-bsp
  18. ref. https://github.com/BPI-SINOVOIP/BPI-files
How to boot from eMMC:
  1. boot from SD
  2. sudo su
  3. echo 0 > /sys/block/mmcblk1boot0/force_ro #enable /dev/mmcblk1boot0 write mode
  4. bpi-bootsel BPI-R2-EMMC-boot0-0k.img.gz /dev/mmcblk1boot0 #write once
  5. bpi-copy /path_to_your_image/xxx.img.zip
  6. poweroff
  7. remove SD & power on
Known limitations:
  1. WIFI/BT isn’t supported
  2. MIPI interface doesn’t work
Google Drive:
https://drive.google.com/file/d/0B_YnvHgh2rwjS1Z1OFRRZlpQNDg/view?usp=sharing
baidu cloud:
http://pan.baidu.com/s/1bpElcf1
MD5: 021e2e5a627f9e60742c6bbb6b4e8dc8
FILESIZE: 1774241037 (~1692MB)
UNPACK: 7456MB (eMMC size)
Basic firmware for debian
Banana pi BPI-R2 LEDE OpenWRT development in progress
(bpi team) #4
i have let Gary to test it ,
(gary) #5
I think the PCIe device is not found yet on R2 board, can you please confirm if the model supports PCIe?
#6
I’m using the 3160HMW (first one in the list).
#7
Does this device need extra power supply? As I know, some PCIe devices need that (e.g., Intel® 82575/82576 4 port ethernet card). Or, could you test other devices?
#8
It’s a half size mini PCIe card so no extra power supply is needed. According to the product brief ( https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/dual-band-wireless-ac-3160-bluetooth-brief.pdf ) it supports PCIe and USB. On the BPI-R2 schematic that is available currently, the USB lines on the mPCIe socket are not connected (so USB-only mPCIe cards are not supported like most of the 3G mPCIe as far as I know) but the 3160HMW should (?) be visible in the lspci output.
#9
More console log could be helpful. We need to know what happened when PCIe linkup.
(gary) #10
Can you please share us the linux kernel booting log while this card is installed?
#11
Has anyone actually tested this? I followed the instructions, and the board doesn’t boot from emmc.
#12
I need to build a new card in order to do so (I’ve overwritten the previous one), I hope I’ll find some time to do it soon.
(gary) #13
Can you please try the following steps: How to boot from eMMC:
  1. boot from SD
  2. sudo su
  4. To write preloader to EMMC by running command:
       bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0
  5. To copy ubuntu image to EMMC:
       unzip -p <XXX.img.zip> | pv | dd of=<device> bs=10M status=noxfer
       or
       bpi-copy  <XXX.img.zip> <device>
       where the XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html, and where <device> should be /dev/mmcblk1.
  6. poweroff
(gary) #14
@kanastas
I’ve got a Intel 3160 HMW mode, also see this problem, will debug it,
(Rene Hegewald) #15
Hello @ all,
i read the thread and follow the instruction:
boot from SD
sudo su
bpi-copy 2017-09-04-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc-v1.2.0.img.zip
poweroff
but does not work. After Power on, ther is Nothing to see in the Debug Console … what´s going wrong ?
Best regards, René
(Frank W.) #16
Does any error come up while calling bpi-copy? Any ubuntu-image was bigger than emmc and fails there…then image must be resized first
(Rene Hegewald) #17
nope, but uboot does not known the command “emmc” …
“emmc ecsd” or “emmc pconf 0x48”
BPI-IoT> emmc ecsd
Unknown command 'emmc' - try 'help'
BPI-IoT> emmc pconf 0x48
BPI-IoT> version
U-Boot  (Aug 01 2017 - 09:59:52)
arm-linux-gnueabihf-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
GNU ld (GNU Binutils for Ubuntu) 2.26.1
Is there a Firmware update ?
(Frank W.) #18
then you have to update uboot first to actual version…
you can use my compiled version: https://drive.google.com/open?id=11XQ4n6WYSj7gGPtMwug4SITtYn0GZxOb
and install like this http://www.fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:uboot#update_uboot or using bpi-update
but last ubuntu should be have actual uboot, too… :thinking:
The emmc-command is integrated in uboot since September 29th 2017 (version: “U-Boot 2014.04-rc1 (Oct 16 2017 - 19:33:23)”)
(Rene Hegewald) #19
i’ll check you wiki.
But /dev/sdx ? do you mean /dev/mmcblk ?
(Frank W.) #20
you must flash the image on host-pc to sd-card (where you boot first you bpi) not from the bpi itself…
(Rene Hegewald) #21
:slight_smile: i used the bpi-r2 … and it works :slight_smile:
(Frank W.) #22
you’ve wrote image direct to emmc (which partition)? or to your sd-card?
ubuntu boots from emmc without sd-card?
@garywang: is it possible to load uboot from emmc, boot from SD if inserted and if not using emmc-boot?
