BPI-R2 integrated WiFi trouble
I try to start BPI-R2 work as router with integrated card + frank-w kernel 4.14, and after iperf3 tests, my speed at wifi link is down to 0. After more manipulations, I detect what this trouble only at kernels > 4.14-main-20190125150733 from (https://github.com/frank-w/BPI-R2-4.14/releases/tag/CI-BUILD-20190125150730-1089b6c7a609) And I think “troubles” with [defconfig] added options for Traffic Shaping at next kernel versions. P.S. Thanks frank-w for big work! Anybody known how to, disable traffic shaping?
I don’t think adding traffic shaping causes wifi-problems but you can revert this commit.
git revert commitid
And rebuild…if you run iperf you should limit traffic by tc (the functions you want to disable). see commands in wifi.sh. these are taken from offfical wiki.
Hi, Pavel, If you changed config - pls check CONFIG_NET_SCH_FQ option. It should be disabled for an internal wifi. At least it helped me with similar problem on 5.5-kernel.
Good day, Alex. I don’t change config. State of this option in config: CONFIG_NET_SCH_FQ is not set
After your speed drops to 0 is it works at all? I mean ping, ssh, etc? If not could you tcpdump ap0? In my case there were only incoming traffic.
[BPI-R2] internal Wifi/BT (MT6625L) - Kernel there is my discussion at the eno of the thread. How similar are your symptoms?
All not work. But yes, ap0 tcpdump incoming traffic I see too. Now I recompile latest 4.14 kernel from frank-w github with: CONFIG_IFB=n CONFIG_NET_SCH_FQ_CODEL=n CONFIG_NET_ACT_MIRRED=n My symptoms are similar of you.
P.S. After recompile with this modifications, WIN! :laughing:
i wonder why my ap0 is working (but i did not do iperf on it)…i’m currently using 4.14.131-bpi-r2-main and my default config like it’s on github…i know time for an update, but want to move to 5.4 soon :slight_smile:
[13:27] root@bpi-r2-e:~ (500)# tc qdisc show dev ap0
qdisc mq 0: root
qdisc pfifo_fast 0: parent :4 bands 3 priomap  1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent :3 bands 3 priomap  1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent :2 bands 3 priomap  1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
qdisc pfifo_fast 0: parent :1 bands 3 priomap  1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
[13:27] root@bpi-r2-e:~ (501)# uname -a
Linux bpi-r2-e 4.14.131-bpi-r2-main #259 SMP Mon Jul 1 19:20:17 CEST 2019 armv7l GNU/Linux
what is your tc qdisc show dev ap0?
mine working is:
bpi-r2-gentoo ~ # tc qdisc show dev ap0
qdisc mq 0: root
I’m not sure that it’a s root but could you check it?
At work frank-w kernel 4.14.158 with changes in .config: qdisc mq 0: root qdisc pfifo_fast 0: parent :4 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 qdisc pfifo_fast 0: parent :3 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 qdisc pfifo_fast 0: parent :2 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1 qdisc pfifo_fast 0: parent :1 bands 3 priomap 1 2 2 2 1 2 0 0 1 1 1 1 1 1 1 1
At standart frank-w kernel 4.14.158 from git: qdisc mq 0: root qdisc fq_codel 0: parent :4 limit 3069009476p flows 3069009476 quantum 3069009476 target 5.0ms interval 100.0ms memory_limit 32Mb ecn qdisc fq_codel 0: parent :3 limit 3069009476p flows 3069009476 quantum 3069009476 target 5.0ms interval 100.0ms memory_limit 32Mb ecn qdisc fq_codel 0: parent :2 limit 3069009476p flows 3069009476 quantum 3069009476 target 5.0ms interval 100.0ms memory_limit 32Mb ecn qdisc fq_codel 0: parent :1 limit 3069009476p flows 3069009476 quantum 3069009476 target 5.0ms interval 100.0ms memory_limit 32Mb ecn
Could you put output in codeblock (select code and click on <> button
It looks like on standart you have defined any trafficshaping…where do you have the problems?
Btw. 5.14 is not out yet :stuck_out_tongue:
Haha, really, fix mistake. If I correct understand your post… standart .config from:
     CONFIG_IFB=m
     CONFIG_NET_SCH_FQ_CODEL=m
     CONFIG_NET_ACT_MIRRED=m
to:
CONFIG_IFB=n
But I don’t manipulate trafficshaping policy self… And from first post answered how to disable it, without kernel recompile. In lsmod I don’t see what any traffic shaping modules has been added, but is idea, see for it later.
interesting will be which module makes problems and why…these options are added on 4.14.95 and should break my ap0 too…i see none of these modules in my lsmod
[19:52] frank@bpi-r2-e:~$ lsmod
nft_compat             20480  0
nf_tables              86016  1 nft_compat
nfnetlink              16384  2 nft_compat,nf_tables
aes_arm_bs             20480  0
crypto_simd            16384  1 aes_arm_bs
cryptd                 24576  1 crypto_simd
xt_TCPMSS              16384  1
xt_tcpmss              16384  1
pppoe                  20480  4
pppox                  16384  1 pppoe
ppp_generic            32768  10 pppox,pppoe
slhc                   16384  1 ppp_generic
xt_addrtype            16384  4
veth                   16384  0
ip6t_REJECT            16384  1
nf_reject_ipv6         16384  1 ip6t_REJECT
xt_mac                 16384  4
ip6t_rt                16384  3
nf_conntrack_ipv6      20480  10
nf_defrag_ipv6         20480  1 nf_conntrack_ipv6
ip6table_filter        16384  1
ip6_tables             24576  7 ip6table_filter
ipt_REJECT             16384  2
nf_reject_ipv4         16384  1 ipt_REJECT
xt_limit               16384  2
xt_iprange             16384  9
xt_recent              20480  14
tun                    36864  2
xt_conntrack           16384  39
iptable_filter         16384  1
ipt_MASQUERADE         16384  4
nf_nat_masquerade_ipv4    16384  1 ipt_MASQUERADE
xt_nat                 16384  12
xt_tcpudp              16384  53
iptable_nat            16384  1
nf_conntrack_ipv4      16384  46
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
nf_nat_ipv4            16384  1 iptable_nat
nf_nat                 32768  3 xt_nat,nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack          126976  8 xt_nat,nf_conntrack_ipv6,nf_conntrack_ipv4,ipt_MASQUERADE,nf_nat_masquerade_ipv4,xt_conntrack,nf_nat_ipv4,nf_nat
xt_mark                16384  3
iptable_mangle         16384  1
mt76x2e                61440  0
mt76                   36864  1 mt76x2e
mtk_thermal            16384  0
thermal_sys            61440  1 mtk_thermal
spi_mt65xx             20480  0
pwm_mediatek           16384  0
evbug                  16384  0
mt6577_auxadc          16384  0
nvmem_mtk_efuse        16384  0
mtk_pmic_keys          16384  0
rtc_mt6397             16384  1
nfsd                  339968  13
ip_tables              24576  4 iptable_mangle,iptable_filter,iptable_nat
x_tables               28672  21 ipt_REJECT,xt_nat,iptable_mangle,ip_tables,nft_compat,iptable_filter,xt_mark,xt_mac,xt_tcpudp,xt_tcpmss,ipt_MASQUERADE,xt_limit,ip6t_REJECT,xt_recent,ip6table_filter,xt_addrtype,xt_iprange,ip6t_rt,xt_conntrack,ip6_tables,xt_TCPMSS
these options result in own modules
[19:52] frank@bpi-r2-e:~$ find /lib/modules/$(uname -r) -iname '*sch*.ko'
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_teql.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_tbf.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_cbq.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_sfq.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_prio.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_netem.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_fq_codel.ko <<<<<<<<<
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_htb.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_red.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_dsmark.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_gred.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/sch_ingress.ko
[19:54] frank@bpi-r2-e:~$ find /lib/modules/$(uname -r) -iname '*ifb*.ko'
/lib/modules/4.14.131-bpi-r2-main/kernel/drivers/net/ifb.ko <<<<<<<<<<<<<<<<
[19:54] frank@bpi-r2-e:~$ find /lib/modules/$(uname -r) -iname '*act*.ko'
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/act_vlan.ko
/lib/modules/4.14.131-bpi-r2-main/kernel/net/sched/act_mirred.ko  <<<<<<<
maybe you can try to unload them if loaded
Only sch_fq_codel module will be loaded and while try to rmmod sch_fq_codel rmmod: ERROR: Module sch_fq_codel is in use. Then I try to blacklist sch_fq_codel in /etc/modprobe.d/blacklist.conf, but module will be loaded with ignore it.
lsmod shows which module uses other modules in “used by” column. Afair there is a forced mode in modprobe (modprobe -rf …)
modprobe -rf sch_fq_codel modprobe: FATAL: Module sch_fq_codel is in use.
:+1: glad you did it.
Me too, looks like it loads by wifi driver.
You should remove if from all devices, likely by using tc command. I’m not such familiar with it, so I don’t know exact command.
As i know - it prevents module loading on boot, by init scripts, but it still able to load it maunally. If wifi driver loads it you can simply check it: Remove wifi-init script from autostart, reboot and check if it’s loaded. If it’s not - start wifi-init manually and recheck module.
Please show your lsmod.
Have you activated tc-lines in wifi.sh?
Good day frank-w! I not have in my /etc/init.d/wifi.sh tc-lines. lsmod with troubles:
ip6table_filter        16384  0
ip6_tables             24576  1 ip6table_filter
ipt_MASQUERADE         16384  1
iptable_nat            16384  1
nf_conntrack_ipv4      16384  2
nf_nat                 32768  2 nf_nat_masquerade_ipv4,nf_nat_ipv4
nf_conntrack          126976  5 nf_conntrack_ipv4,ipt_MASQUERADE,nf_nat_masquerade_ipv4,nf_nat_ipv4,nf_nat
iptable_filter         16384  0
ath10k_pci             49152  0
ath10k_core           286720  1 ath10k_pci
ath                    28672  1 ath10k_core
rtc_mt6397             16384  1
mtk_thermal            16384  0
thermal_sys            65536  2 mtk_thermal,ath10k_core
spi_mt65xx             20480  0
sch_fq_codel           20480  7
mtkhnat                24576  0
ip_tables              24576  2 iptable_filter,iptable_nat
x_tables               28672  5 ip_tables,iptable_filter,ipt_MASQUERADE,ip6table_filter,ip6_tables
lsmod without troubles:
fuse                  106496  1
iptable_nat            16384  1
ath10k_pci             53248  0
mtk_thermal            16384  0
thermal_sys            61440  2 mtk_thermal,ath10k_core
spi_mt65xx             20480  0
rtc_mt6397             16384  1
mtkhnat                24576  0
Frank, did you updated wifi drivers with @LeXa2 patches you mentioned before in this branch?
Afair No,lexas patches are only in 5.4+
I guess problematic system calls tc anyhow…
