u-boot debug trace
BPI-R2> pci enum
uclass_find_device_by_seq() 0 -1
uclass_find_device_by_seq() 0 0
uclass_find_device_by_seq() - -1 -1 'pcie@1a140000'
uclass_find_device_by_seq() - not found
uclass_find_device_by_seq() - -1 -1 'ephy_default'
uclass_find_device_by_seq() - -1 -1 'mux'
uclass_find_device_by_seq() - -1 -1 'conf'
uclass_find_device_by_seq() - -1 1 'mmc0default'
uclass_find_device_by_seq() - -1 -1 'conf-cmd-data'
uclass_find_device_by_seq() - -1 -1 'conf-clk'
uclass_find_device_by_seq() - -1 -1 'conf-rst'
uclass_find_device_by_seq() - -1 2 'mmc1default'
uclass_find_device_by_seq() - -1 -1 'conf-wp'
uclass_find_device_by_seq() - -1 -1 'pcie-default'
uclass_find_device_by_seq() - -1 -1 'uart0-default'
uclass_find_device_by_seq() - -1 -1 'uart1-default'
uclass_find_device_by_seq() - -1 0 'uart2-default'
uclass_find_device_by_seq() - found
uclass_find_device_by_seq() 0 1
uclass_find_device_by_seq() 0 2
uclass_find_device_by_seq() 0 3
uclass_find_device_by_seq() - -1 -1 'uart2-alt'
uclass_find_device_by_seq() - -1 0 'pinctrl@10005000'
clk_set_defaults() clk_set_defaults(pcie-default)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7e870
ofnode_read_prop() ofnode_read_prop: assigned-clock-rates: ofnode_read_prop() <not found>
fdtdec_get_int() fdtdec_get_int: #power-domain-cells: fdtdec_get_int() 0x1 (1)
power_domain_get_by_index() power_domain_get_by_index(dev=feb7f580, power_domain=fe9fc33c)
uclass_get_device_by_ofnode() Looking for scpsys@10006000
uclass_find_device_by_ofnode() Looking for scpsys@10006000
uclass_find_device_by_ofnode() - result for scpsys@10006000: scpsys@10006000 (ret=0)
uclass_get_device_by_ofnode() - result for scpsys@10006000: scpsys@10006000 (ret=0)
power_domain_of_xlate_default() power_domain_of_xlate_default(power_domain=fe9fc33c)
power_domain_on() power_domain_on(power_domain=fe9fc33c)
pci_uclass_pre_probe() pci_uclass_pre_probe, bus=0/pcie@1a140000, parent=root_driver
decode_regions() decode_regions: len=12, cells_per_record=6
decode_regions() decode_regions: region 0, pci_addr=1a160000, addr=1a160000, size=10000, space_code=1
decode_regions() - type=1, pos=0
decode_regions() decode_regions: region 1, pci_addr=60000000, addr=60000000, size=10000000, space_code=3
decode_regions() - type=0, pos=1
ofnode_read_bool() ofnode_read_bool: u-boot,skip-auto-config-until-reloc: ofnode_read_bool() false
clk_set_defaults() clk_set_defaults(pcie@1a140000)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7f580
__of_translate_address() OF: ** translation for device pcie@1a140000 **
__of_translate_address() OF: bus is default (na=1, ns=1) on
__of_translate_address() OF: reached root node
clk_get_by_name() clk_get_by_name(dev=feb7f580, name=free_ck, clk=feb85858)
fdtdec_get_int() fdtdec_get_int: #clock-cells: fdtdec_get_int() 0x1 (1)
uclass_get_device_by_ofnode() Looking for clock-controller@10000000
uclass_find_device_by_ofnode() Looking for clock-controller@10000000
uclass_find_device_by_ofnode() - result for clock-controller@10000000: clock-controller@10000000 (ret=0)
uclass_get_device_by_ofnode() - result for clock-controller@10000000: clock-controller@10000000 (ret=0)
clk_of_xlate_default() clk_of_xlate_default(clk=feb85858)
clk_request() clk_request(dev=feb7e258, clk=feb85858)
clk_enable() clk_enable(clk=feb85858)
ofnode_read_pci_addr() ofnode_read_pci_addr: reg: ofnode_read_pci_addr() pci address #0: 00000000 00000000 00000000
clk_get_by_name() clk_get_by_name(dev=feb7f580, name=sys_ck0, clk=feb9c8e0)
uclass_get_device_by_ofnode() Looking for syscon@1a000000
uclass_find_device_by_ofnode() Looking for syscon@1a000000
uclass_find_device_by_ofnode() - result for syscon@1a000000: syscon@1a000000 (ret=0)
uclass_get_device_by_ofnode() - result for syscon@1a000000: syscon@1a000000 (ret=0)
uclass_find_device_by_seq() - -1 1 'dummy13m'
uclass_find_device_by_seq() - -1 -1 'oscillator-1'
uclass_find_device_by_seq() - -1 -1 'oscillator-0'
uclass_find_device_by_seq() - -1 0 'clock-controller@10000000'
uclass_find_device_by_seq() - -1 5 'syscon@10001000'
uclass_find_device_by_seq() - -1 2 'syscon@10003000'
uclass_find_device_by_seq() - -1 3 'clock-controller@10209000'
uclass_find_device_by_seq() 0 4
uclass_find_device_by_seq() - -1 -1 'syscon@1a000000'
uclass_find_device_by_seq() - -1 4 'syscon@1b000000'
uclass_find_device_by_seq() 0 5
uclass_find_device_by_seq() 0 6
clk_set_defaults() clk_set_defaults(syscon@1a000000)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7f480
__of_translate_address() OF: ** translation for device syscon@1a000000 **
clk_of_xlate_default() clk_of_xlate_default(clk=feb9c8e0)
clk_request() clk_request(dev=feb7f480, clk=feb9c8e0)
fdtdec_get_int() fdtdec_get_int: #reset-cells: fdtdec_get_int() 0x1 (1)
uclass_find_device_by_ofnode() - result for syscon@1a000000: reset (ret=0)
uclass_get_device_by_ofnode() - result for syscon@1a000000: reset (ret=0)
uclass_find_device_by_seq() - -1 -1 'reset'
uclass_find_device_by_seq() - -1 0 'reset'
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7f4f8
uclass_find_device_by_ofnode() - result for syscon@1a000000: (none) (ret=-19)
uclass_get_device_by_ofnode() - result for syscon@1a000000: (none) (ret=-19)
uclass_find_device_by_seq() - -1 0 'syscon@1b000000'
uclass_find_device_by_seq() - -1 1 'syscon@10001000'
ofnode_read_prop() ofnode_read_prop: reg: fdtdec_get_addr_size_fixed() fdtdec_get_addr_size_fixed: reg: __of_translate_address() OF: ** translation for device syscon@1a000000 **
fdtdec_get_addr_size_fixed() addr=1a000000, size=1000
ofnode_read_bool() ofnode_read_bool: little-endian: ofnode_read_bool() false
ofnode_read_bool() ofnode_read_bool: big-endian: ofnode_read_bool() false
ofnode_read_bool() ofnode_read_bool: native-endian: ofnode_read_bool() false
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb85b08
reset_of_xlate_default() reset_of_xlate_default(reset_ctl=feb9c8d0)
generic_phy_get_by_index() generic_phy_get_by_index(dev=feb7f580, index=0, phy=feb9c900)
fdtdec_get_int() fdtdec_get_int: #phy-cells: fdtdec_get_int() 0x1 (1)
uclass_get_device_by_ofnode() Looking for pcie-phy@1a149900
uclass_find_device_by_ofnode() Looking for pcie-phy@1a149900
uclass_find_device_by_ofnode() - result for pcie-phy@1a149900: (none) (ret=-19)
uclass_get_device_by_ofnode() - result for pcie-phy@1a149900: (none) (ret=-19)
generic_phy_get_by_index() generic_phy_get_by_index: uclass_get_device_by_ofnode failed: err=-19
uclass_get_device_by_ofnode() Looking for pcie-phy@1a149000
uclass_find_device_by_ofnode() Looking for pcie-phy@1a149000
uclass_find_device_by_ofnode() - result for pcie-phy@1a149000: pcie-phy@1a149000 (ret=0)
uclass_get_device_by_ofnode() - result for pcie-phy@1a149000: pcie-phy@1a149000 (ret=0)
uclass_find_device_by_seq() - -1 -1 'pcie-phy@1a149000'
uclass_find_device_by_seq() - -1 -1 'pcie-phy@1a14a000'
clk_set_defaults() clk_set_defaults(pcie-phy@1a149000)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7f5f8
__of_translate_address() OF: ** translation for device pcie-phy@1a149000 **
fdtdec_get_addr_size_fixed() fdtdec_get_addr_size_fixed: reg: __of_translate_address() OF: ** translation for device pcie-phy@1a149900 **
__of_translate_address() OF: bus is default (na=1, ns=1) on pcie-phy@1a149000
__of_translate_address() OF: parent bus is default (na=1, ns=1) on
of_translate_one() OF: no ranges, 1:1 translation
of_translate_one() OF: with offset: 437557504
fdtdec_get_addr_size_fixed() addr=1a149900, size=700
clk_get_by_name_nodev() clk_get_by_name_nodev(node=fe9fe2d8, name=ref, clk=feb9ca58)
fdtdec_get_int() fdtdec_get_int: #clock-cells: fdtdec_get_int() 0x0 (0)
uclass_get_device_by_ofnode() Looking for oscillator-0
uclass_find_device_by_ofnode() Looking for oscillator-0
uclass_find_device_by_ofnode() - result for oscillator-0: oscillator-0 (ret=0)
uclass_get_device_by_ofnode() - result for oscillator-0: oscillator-0 (ret=0)
ofnode_read_u32() ofnode_read_u32: clock-frequency: ofnode_read_u32() 0x18cba80 (26000000)
uclass_find_device_by_seq() - -1 6 'syscon@1a000000'
uclass_find_device_by_seq() 0 7
clk_set_defaults() clk_set_defaults(oscillator-0)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7e1d0
clk_of_xlate_default() clk_of_xlate_default(clk=feb9ca58)
clk_request() clk_request(dev=feb7e1d0, clk=feb9ca58)
ofnode_read_u32() ofnode_read_u32: reg: ofnode_read_u32() 0x1a149900 (437557504)
ofnode_read_pci_addr() ofnode_read_pci_addr: reg: ofnode_read_pci_addr() pci address #0: 00000800 00000000 00000000
clk_get_by_name() clk_get_by_name(dev=feb7f580, name=sys_ck1, clk=feb9cae0)
clk_of_xlate_default() clk_of_xlate_default(clk=feb9cae0)
clk_request() clk_request(dev=feb7f480, clk=feb9cae0)
reset_of_xlate_default() reset_of_xlate_default(reset_ctl=feb9cad0)
generic_phy_get_by_index() generic_phy_get_by_index(dev=feb7f580, index=1, phy=feb9cb00)
uclass_get_device_by_ofnode() Looking for pcie-phy@1a14a900
uclass_find_device_by_ofnode() Looking for pcie-phy@1a14a900
uclass_find_device_by_ofnode() - result for pcie-phy@1a14a900: (none) (ret=-19)
uclass_get_device_by_ofnode() - result for pcie-phy@1a14a900: (none) (ret=-19)
uclass_get_device_by_ofnode() Looking for pcie-phy@1a14a000
uclass_find_device_by_ofnode() Looking for pcie-phy@1a14a000
uclass_find_device_by_ofnode() - result for pcie-phy@1a14a000: pcie-phy@1a14a000 (ret=0)
uclass_get_device_by_ofnode() - result for pcie-phy@1a14a000: pcie-phy@1a14a000 (ret=0)
uclass_find_device_by_seq() - -1 0 'pcie-phy@1a149000'
clk_set_defaults() clk_set_defaults(pcie-phy@1a14a000)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb7f650
__of_translate_address() OF: ** translation for device pcie-phy@1a14a000 **
fdtdec_get_addr_size_fixed() fdtdec_get_addr_size_fixed: reg: __of_translate_address() OF: ** translation for device pcie-phy@1a14a900 **
__of_translate_address() OF: bus is default (na=1, ns=1) on pcie-phy@1a14a000
of_translate_one() OF: with offset: 437561600
fdtdec_get_addr_size_fixed() addr=1a14a900, size=700
clk_get_by_name_nodev() clk_get_by_name_nodev(node=fe9fe3f4, name=ref, clk=feb9cc18)
clk_of_xlate_default() clk_of_xlate_default(clk=feb9cc18)
clk_request() clk_request(dev=feb7e1d0, clk=feb9cc18)
ofnode_read_u32() ofnode_read_u32: reg: ofnode_read_u32() 0x1a14a900 (437561600)
clk_enable() clk_enable(clk=feb9c8e0)
reset_assert() reset_assert(reset_ctl=feb9c8d0)
reset_deassert() reset_deassert(reset_ctl=feb9c8d0)
clk_enable() clk_enable(clk=feb9ca58)
Port0 link down
clk_enable() clk_enable(clk=feb9cae0)
reset_assert() reset_assert(reset_ctl=feb9cad0)
reset_deassert() reset_deassert(reset_ctl=feb9cad0)
clk_enable() clk_enable(clk=feb9cc18)
pci_uclass_post_probe() pci_uclass_post_probe: probing bus 0
pci_bind_bus_devices() pci_bind_bus_devices: bus 0/pcie@1a140000: found device 0, function 0pci_bind_bus_devices() : find ret=-19
pci_find_and_bind_driver() pci_find_and_bind_driver: Searching for driver: vendor=14c3, device=801
pci_find_and_bind_driver() pci_find_and_bind_driver: No match found: bound generic driver instead
pci_bind_bus_devices() pci_bind_bus_devices: bus 0/pcie@1a140000: found device 1, function 0pci_bind_bus_devices() : find ret=-19
fdtdec_get_alias_seq() Looking for 'pci' at 6928, name pcie@1,0
fdtdec_get_alias_seq() Not found
pci_auto_config_devices() pci_auto_config_devices: start
pciauto_show_region() PCI Autoconfig: Bus Memory region: [60000000-6fffffff],
Physical Memory [60000000-6fffffffx]
pciauto_show_region() PCI Autoconfig: Bus I/O region: [1a160000-1a16ffff],
Physical Memory [1a160000-1a16ffffx]
pci_auto_config_devices() pci_auto_config_devices: device pci_0:0.0
dm_pciauto_setup_device() PCI Autoconfig: BAR 0, Mem, size=0x2000000, pciauto_region_allocate() address=0x60000000 bus_lower=0x62000000
dm_pciauto_setup_device() PCI Autoconfig: BAR 1, Mem, size=0x10000, pciauto_region_allocate() address=0x62000000 bus_lower=0x62010000
dm_pciauto_setup_device() PCI Autoconfig: BAR 2, I/O, size=0x4, pciauto_region_allocate() address=0x1a160000 bus_lower=0x1a160004
dm_pciauto_setup_device() PCI Autoconfig: BAR 3, I/O, size=0xe10, pciauto_region_allocate() address=0x1a160e10 bus_lower=0x1a161c20
dm_pciauto_setup_device() PCI Autoconfig: BAR 4, Mem, size=0xf0010, pciauto_region_allocate() address=0x62100000 bus_lower=0x621f0010
dm_pciauto_setup_device() PCI Autoconfig: BAR 5, I/O, size=0x10, pciauto_region_allocate() address=0x1a161c20 bus_lower=0x1a161c30
pci_auto_config_devices() pci_auto_config_devices: device pci_0:1.0
dm_pciauto_config_device() PCI Autoconfig: Found P2P bridge, device 1
dm_pciauto_setup_device() PCI Autoconfig: BAR 0, Mem, size=0x10000, pciauto_region_allocate() address=0x62200000 bus_lower=0x62210000
dm_pci_hose_probe_bus() dm_pci_hose_probe_bus
pci_get_bus_max() pci_get_bus_max: ret=0
dm_pci_hose_probe_bus() dm_pci_hose_probe_bus: bus = 1/pci_0:1.0
uclass_find_device_by_seq() - -1 0 'pcie@1a140000'
uclass_find_device_by_seq() - -1 -1 'pci_0:1.0'
pci_uclass_pre_probe() pci_uclass_pre_probe, bus=1/pci_0:1.0, parent=pcie@1a140000
clk_set_defaults() clk_set_defaults(pcie@1,0)
clk_set_default_parents() clk_set_default_parents: could not read assigned-clock-parents for feb9ccd0
pci_uclass_post_probe() pci_uclass_post_probe: probing bus 1
