BPI-R2-bsp-4.14 and 4.4.70
(Troumad) #1
Hello
I have try thus : https://github.com/BPI-SINOVOIP/BPI-R2-bsp-4.14 with my mageia :
[root@localhost ~]# urpmi pv [root@localhost ~]# urpmi u-boot-tools [root@localhost ~]# urpmi gcc-arm-linux-gnu
I have 3 problems :
  1. My SD card is here :
/dev/sdb* and this is not good :
  • lsblk: /dev/mmcblk0 : n’est pas un périphérique bloc
  • INFO: /dev/mmcblk0 : SD/eMMC !!
  • umount device: /dev/mmcblk0
  • update /dev/mmcblk0p1(vfat) with BPI-BOOT-bpi-r2.tgz
  • mount: /mnt : le périphérique spécial /dev/mmcblk0p1 n’existe pas.
  1. I have download
-rw-r–r-- 1 root root 45935582 nov. 8 21:52 4.4.70-BPI-R2-Kernel.tgz
-rw-r–r-- 1 root root 63234581 nov. 8 21:53 4.4.70-BPI-R2-Kernel-net.tgz
but not the BPI-R2-bsp-4.14 .
  1. There is nothing in the boot directory
[root@localhost ~]# ll /mnt/sdb2/boot/
total 0
(Frank W.) #2
Strange that your current kernel recognize mmcblk as sdx…have you a udev-rule which renames the device? I don’t know mageia but linux-kernel should name it mmcblk
For 3…/boot in rootfs should be mountpoint of partition #1 sdb1 in your case
Don’t understand #1 and #2
Do you try a install-script? You can also try my 4.14 :slight_smile:
(Troumad) #3
I don’t have rename the device. I have a mageia Caudron (test for the mga7) and the pthers PC the the home have mageia6 (the stable version).
A computer with mga6 as the same problem (sdc, but not mmcblk).
(Frank W.) #4
maybe mageia/caudron (i did not know it) brings this renaming…but you can create a symlink from /dev/sdx(y) to /dev/mmcblkx(py) to make the script run
if you have /dev/sdc as sd-card make this as root
ln -s /dev/sdc /dev/mmcblk0
ln -s /dev/sdc1 /dev/mmcblk0p1
ln -s /dev/sdc2 /dev/mmcblk0p2
(Troumad) #5
Now, I try your .deb in https://github.com/frank-w/BPI-R2-4.14/releases/ Why the 4.14 but not the 4.18 ?
(Frank W.) #6
you can also try 4.18…this should be listed on this page too…
4.14 is LTS-Kernel and with more functions like poweroff,2nd gmac,hdmi,4.19 is LTS too, but the additional functions are currently missing
