BPI-M3 new image:raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.img V1.0 2016-5-13
(bpi team) #1
2016-05-13-raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.img.zip
  1. BPI-M3 kernel 3.4
  2. username & password: pi/bananapi , root/bananapi
  3. support HDMI 1080P & 720P(default)
  4. support eMMC
  5. support GMAC
  6. support WIFI
  7. support SATA
  8. support bpi-bootsel cmd can switch to (bpi-m3 & bpi-m2 & bpi-m2p)
  9. support uEnv.txt to fatload script.bin & uImage
  10. support uEnv.txt to set video 1080P & 720P & 480P …
  11. support power max. up to 2.5A ~ for DC-IN.
  12. support GPU PowerVR SGX544MP (glmark2-es2)
  13. fix rootmydevice issue
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjNHF3N3hQZXhDWUU/view?usp=sharing
MD5: b8eafe5c4c03b1de2230116b18f35278
(miguel) #2
Hello!, my bpi turn of itself after splash-sreen with this image. Does anyone know something about it?. The image it´s flased in a sd-card.
Thanks
(bpi team) #3
are you use TP screen or HDMI ???
(Nestor Cagnoli) #4
I retry with new raspian image…no sucess…
Im doing this :
1-) Boot on sd old Raspian lite image than…:
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
root@bananapi:~# root@bananapi:~# mount /dev/sdb1 /mnt/
(sdb is a 32gb pendrive)
root@bananapi:~# cd /mnt/ root@bananapi:/mnt# ls 2016-05-13-raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.img.zip root@bananapi:/mnt# unzip -p 2016-05-13-raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.i img.zip | dd of=/dev/mmcblk1 bs=4096
1908736+0 records in 1908736+0 records out 7818182656 bytes (7.8 GB) copied, 940.503 s, 8.3 MB/s
root@bananapi:/mnt# sync root@bananapi:/mnt# shutdown -h now [ 2265.973186] Power down.
2-) Click power on withoud sdcard…and eternal reboot loop
root@bananapi:/mnt# shutdown -h now [ 2265.973186] Power down. HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000 DRAM DRIVE INFO: V1.0 DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM normal_mode value: 00000001 DRAM CLK =672 MHZ PMU: AXP81X ddr voltage = 1200 mv using ic A83T using axp AXP813 DRAM zq value: 00003bfb dram size =2048 card boot number = 2 card no is 2 sdcard 2 line count 0 mmc: mmc driver ver 2014-8-11 15:06:39 mmc: Try SD card 2 mmc: mmc 2 cmd 8 timeout, err 00000100 mmc: mmc 2 cmd 8 err 00000100 mmc: mmc 2 send if cond failed mmc: mmc 2 cmd 55 timeout, err 00000100 mmc: mmc 2 cmd 55 err 00000100 mmc: mmc 2 send app cmd failed mmc: Try MMC card 2 mmc: MMC ver 5.0 Card: 4bit, capacity: 7456MB mmc: vendor: Man 00150100 Snr 0077f9b0 mmc: product: 8WPD3 mmc: revision: 5.2 2 init OK!!!*** sdcard 2 init ok ERROR! NOT find the head of uboot. The size of uboot is 000d8000. sum=ce3ec68c src_sum=ce3ec68c set_mmc_para,sdly 50M 0 set_mmc_para,sdly 25M 0 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. [ 0.346]
U-Boot 2011.09-rc1-00000-gfe0f876 (May 03 2016 - 13:13:31) Allwinner Technology
[ 0.355]version: 2.1.0 normal mode [ 0.435]pmbus: normal or secure os ready [ 0.439]PMU: AXP81X [ 0.441]PMU: AXP81X found bat_vol=0, ratio=100 [ 0.447]PMU: dcdc2 900 [ 0.449]PMU: pll1 1008 Mhz AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz set power on vol to default dcdc1_vol = 3300, onoff=1 dcdc2_vol = 900, onoff=1 dcdc3_vol = 900, onoff=1 dcdc4_vol = 900, onoff=1 dcdc6_vol = 900, onoff=1 aldo1_vol = 1800, onoff=0 aldo2_vol = 1800, onoff=1 aldo3_vol = 3000, onoff=1 eldo2_vol = 1800, onoff=0 dldo1_vol = 3300, onoff=0 dldo2_vol = 3300, onoff=0 dldo3_vol = 2500, onoff=1 dldo4_vol = 2800, onoff=0 fldo2_vol = 900, onoff=1 gpio0_vol = 3300, onoff=1 gpio1_vol = 3300, onoff=1 find power_sply to end supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b04, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b08, value=0xd, pmu_vol=3300 supply=dldo3 axp=axp81x, supply=dldo3, vol=1800 reg addr=0x1c20b0c, value=0x0, pmu_vol=1800 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b10, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b14, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b18, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b1c, value=0xd, pmu_vol=3300 supply=aldo3 axp=axp81x, supply=aldo3, vol=3000 reg addr=0x1f02f00, value=0xa, pmu_vol=3000 config gpio bias voltage finish vbus exist no battery, limit to dc ac100 reg 0x00 = 0x101 ac100 reg 0xd0 = 0x0 ac100 reg 0xd1 = 0x0 446:(board.c:power_source_init) [AXP81X]:[00]=[34] [AXP81X]:[01]=[10] [AXP81X]:[02]=[83] [AXP81X]:[03]=[51] [AXP81X]:[04]=[00] [AXP81X]:[05]=[00] [AXP81X]:[06]=[00] [AXP81X]:[07]=[00] [AXP81X]:[08]=[00] [AXP81X]:[09]=[00] [AXP81X]:[0A]=[00] [AXP81X]:[0B]=[00] [AXP81X]:[0C]=[00] [AXP81X]:[0D]=[00] [AXP81X]:[0E]=[00] [AXP81X]:[0F]=[00] [AXP81X]:[10]=[3F] [AXP81X]:[11]=[00] [AXP81X]:[12]=[20] [AXP81X]:[13]=[C8] [AXP81X]:[14]=[08] [AXP81X]:[15]=[1A] [AXP81X]:[16]=[1A] [AXP81X]:[17]=[0B] [AXP81X]:[18]=[15] [AXP81X]:[19]=[00] [AXP81X]:[1A]=[16] [AXP81X]:[1B]=[00] [AXP81X]:[1C]=[0B] [AXP81X]:[1D]=[04] [AXP81X]:[1E]=[00] [AXP81X]:[1F]=[00] [AXP81X]:[20]=[11] [AXP81X]:[21]=[A8] [AXP81X]:[22]=[A8] [AXP81X]:[23]=[A8] [AXP81X]:[24]=[A4] [AXP81X]:[25]=[9E] [AXP81X]:[26]=[A8] [AXP81X]:[27]=[FC] [AXP81X]:[28]=[0B] [AXP81X]:[29]=[0B] [AXP81X]:[2A]=[17] [AXP81X]:[2B]=[00] [AXP81X]:[2C]=[00] [AXP81X]:[2D]=[B0] [AXP81X]:[2E]=[40] [AXP81X]:[2F]=[00] [AXP81X]:[30]=[03] [AXP81X]:[31]=[03] [AXP81X]:[32]=[43] [AXP81X]:[33]=[C8] [AXP81X]:[34]=[C7] [AXP81X]:[35]=[68] [AXP81X]:[36]=[58] [AXP81X]:[37]=[00] [AXP81X]:[38]=[A5] [AXP81X]:[39]=[1F] [AXP81X]:[3A]=[83] [AXP81X]:[3B]=[08] [AXP81X]:[3C]=[FC] [AXP81X]:[3D]=[16] [AXP81X]:[3E]=[7C] BPI-M3:[AXP81X]:[3A]=[83] BPI-M3: [AXP81X]: set [3A]=[85] BPI-M3:[AXP81X]: read [3A]=[85] BPI-M3: [AXP81X]: set [35]=[83] BPI-M3:[AXP81X]: read [35]=[83] BPI-M3:[AXP81X]: do_reset resetting … set next mode 14 drv_disp_exit 0.842: MMC Device 2 not found 0.846: mmc not find,so not exit HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000 DRAM DRIVE INFO: V1.0 DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM normal_mode value: 00000001 DRAM CLK =672 MHZ PMU: AXP81X ddr voltage = 1200 mv using ic A83T using axp AXP813 DRAM zq value: 00003bfb dram size =2048 card boot number = 2 card no is 2 sdcard 2 line count 0 mmc: mmc driver ver 2014-8-11 15:06:39 mmc: Try SD card 2 mmc: mmc 2 cmd 8 timeout, err 00000100 mmc: mmc 2 cmd 8 err 00000100 mmc: mmc 2 send if cond failed mmc: mmc 2 cmd 55 timeout, err 00000100 mmc: mmc 2 cmd 55 err 00000100 mmc: mmc 2 send app cmd failed mmc: Try MMC card 2 mmc: MMC ver 5.0 Card: 4bit, capacity: 7456MB mmc: vendor: Man 00150100 Snr 0077f9b0 mmc: product: 8WPD3 mmc: revision: 5.2 2 init OK!!!*** sdcard 2 init ok ERROR! NOT find the head of uboot. The size of uboot is 000d8000. sum=ce3ec68c src_sum=ce3ec68c set_mmc_para,sdly 50M 0 set_mmc_para,sdly 25M 0 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. [ 0.346]
[ 0.355]version: 2.1.0 normal mode [ 0.435]pmbus: normal or secure os ready [ 0.439]PMU: AXP81X [ 0.441]PMU: AXP81X found bat_vol=0, ratio=100 [ 0.447]PMU: dcdc2 900 [ 0.449]PMU: pll1 1008 Mhz AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz set power on vol to default dcdc1_vol = 3300, onoff=1 dcdc2_vol = 900, onoff=1 dcdc3_vol = 900, onoff=1 dcdc4_vol = 900, onoff=1 dcdc6_vol = 900, onoff=1 aldo1_vol = 1800, onoff=0 aldo2_vol = 1800, onoff=1 aldo3_vol = 3000, onoff=1 eldo2_vol = 1800, onoff=0 dldo1_vol = 3300, onoff=0 dldo2_vol = 3300, onoff=0 dldo3_vol = 2500, onoff=1 dldo4_vol = 2800, onoff=0 fldo2_vol = 900, onoff=1 gpio0_vol = 3300, onoff=1 gpio1_vol = 3300, onoff=1 find power_sply to end supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b04, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b08, value=0xd, pmu_vol=3300 supply=dldo3 axp=axp81x, supply=dldo3, vol=1800 reg addr=0x1c20b0c, value=0x0, pmu_vol=1800 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b10, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b14, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b18, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b1c, value=0xd, pmu_vol=3300 supply=aldo3 axp=axp81x, supply=aldo3, vol=3000 reg addr=0x1f02f00, value=0xa, pmu_vol=3000 config gpio bias voltage finish vbus exist no battery, limit to dc ac100 reg 0x00 = 0x101 ac100 reg 0xd0 = 0x0 ac100 reg 0xd1 = 0x0 446:(board.c:power_source_init) [AXP81X]:[00]=[34] [AXP81X]:[01]=[10] [AXP81X]:[02]=[83] [AXP81X]:[03]=[51] [AXP81X]:[04]=[00] [AXP81X]:[05]=[00] [AXP81X]:[06]=[00] [AXP81X]:[07]=[00] [AXP81X]:[08]=[00] [AXP81X]:[09]=[00] [AXP81X]:[0A]=[00] [AXP81X]:[0B]=[00] [AXP81X]:[0C]=[00] [AXP81X]:[0D]=[00] [AXP81X]:[0E]=[00] [AXP81X]:[0F]=[0E] [AXP81X]:[10]=[3F] [AXP81X]:[11]=[00] [AXP81X]:[12]=[20] [AXP81X]:[13]=[C8] [AXP81X]:[14]=[08] [AXP81X]:[15]=[1A] [AXP81X]:[16]=[1A] [AXP81X]:[17]=[0B] [AXP81X]:[18]=[15] [AXP81X]:[19]=[00] [AXP81X]:[1A]=[16] [AXP81X]:[1B]=[00] [AXP81X]:[1C]=[0B] [AXP81X]:[1D]=[04] [AXP81X]:[1E]=[00] [AXP81X]:[1F]=[00] [AXP81X]:[20]=[11] [AXP81X]:[21]=[A8] [AXP81X]:[22]=[A8] [AXP81X]:[23]=[A8] [AXP81X]:[24]=[A4] [AXP81X]:[25]=[9E] [AXP81X]:[26]=[A8] [AXP81X]:[27]=[FC] [AXP81X]:[28]=[0B] [AXP81X]:[29]=[0B] [AXP81X]:[2A]=[17] [AXP81X]:[2B]=[00] [AXP81X]:[2C]=[00] [AXP81X]:[2D]=[B0] [AXP81X]:[2E]=[40] [AXP81X]:[2F]=[00] [AXP81X]:[30]=[03] [AXP81X]:[31]=[03] [AXP81X]:[32]=[43] [AXP81X]:[33]=[C8] [AXP81X]:[34]=[C7] [AXP81X]:[35]=[83] [AXP81X]:[36]=[58] [AXP81X]:[37]=[00] [AXP81X]:[38]=[A5] [AXP81X]:[39]=[1F] [AXP81X]:[3A]=[85] [AXP81X]:[3B]=[08] [AXP81X]:[3C]=[FC] [AXP81X]:[3D]=[16] [AXP81X]:[3E]=[7C] BPI-M3:[AXP81X]:[3A]=[85] limit to 2500mA fel key old mode run key detect no key found no key input dram_para_set start dram_para_set end [ 0.793]DRAM: 2 GiB relocation Offset is: 75af7000 user_gpio config user_gpio ok gic: normal or no secure os mode script config pll_de to 504 Mhz script config pll_video1 to 297 Mhz Not Found clk pll_video in script enable power vcc-hdmi-18, ret=0 DRV_DISP_Init end [ 0.958]boot_disp.output_disp=1 [ 0.961]boot_disp.output_type=3 [ 0.965]boot_disp.output_mode=5 [ 0.968]fetch script data boot_disp.auto_hpd fail disp1 device type(4) enable attched ok, mgr1<–>device1, type=4, mode=5---- ready to set mode workmode = 0 MMC: 2 0.983: mmc driver ver 2015-04-13 14:50:00 0.988: get sdc_phy_wipe fail. 0.992: get sdc0 sdc_erase fail. 0.996: get sdc_2xmode ok, val = 1 1.000: get sdc_ddrmode ok, val = 1 1.004: get sdc_f_max fail,use default 50000000Hz 1.010: get card_line ok, card_line = 8 1.014: get sdc_ex_dly_used fail,use default 1.020: SUNXI SD/MMC: 2 1.033: Try SD card 2 1.036: mmc 2 cmd 8 err 100 1.042: mmc send if cond failed 1.046: mmc 2 cmd 55 err 100 1.051: send app cmd failed 1.054: Try MMC card 2 1.094: mmc re-update_phase 1.099: mmc re-update_phase 1.104: mmc re-update_phase 1.109: ddr8 1.111: mmc re-update_phase 1.124: CID 0x15010038 0x57504433 0x520077f9 0xb0ff7275 1.129: MMC ver 5.0 1.132: mmc clk 50000000 1.135: SD/MMC Card: 8bit, capacity: 7456MB 1.140: boot0 capacity: 4000KB,boot1 capacity: 4000KB 1.146: SD/MMC 2 init OK!!! 1.151: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte 1.156: secure_feature 0x55 1.160: secure_removal_type 0x9 [ 1.164]sunxi flash init ok the secure storage map is empty no item name key_burned_flag in the map sunxi secure storage has no flag [ 1.177]usb burn from boot delay time 0 [ 1.248]usb prepare ok [ 2.050]timer occur [ 2.052]overtime [ 2.087]do_burn_from_boot usb : no usb exist limit to dc In: serial Out: serial Err: serial --------fastboot partitions-------- -total partitions:6- -name- -start- -size-
boot-res : 1000000 2000000
env : 3000000 1000000
boot : 4000000 1000000
rootfs : 5000000 20000000
klog : 25000000 1000000
UDISK : 26000000 0
base bootcmd=run setargs_nand boot_normal bootcmd set setargs_mmc key 0 recovery key high 10, low 8 cant find fstbt value no misc partition is found to be run cmd=run setargs_mmc boot_normal serial is: 00000000000000000000 mount part name boot-res cant open script.bin, maybe it is not exist WORK_MODE_BOOT board_status_probe [ 2.165]pre sys mode sunxi_bmp_logo_display 2.202: blkcnt should not be 0 [ 2.221]fetch script data boot_disp.output_disp fail [ 2.226]screen_id =1, screen_width =1280, screen_height =720 [ 2.231]frame buffer address 46400000 [ 2.235]Hit any key to stop autoboot: 0 Interface: MMC Device 2: Vendor: MID 000015 PSN 77f9b0ff Rev: PRV 0.0 Prod: PNM 8WPD3R Type: Removable Hard Disk Capacity: 7456.0 MB = 7.2 GB (15269888 x 512) Partition 1: Filesystem: FAT16 "BPI-BOOT " 5.514: blkcnt should not be 0 Loaded environment from uEnv.txt Running uenvcmd … Banaan Pi bpi-m3 chip: a83t Service: linux
** Unable to read “bananapi/berryboot.img” from mmc 2:1 **
Booting kernel from Legacy Image at 48000000 …
Image Name: Linux-3.4.39-BPI-M3-Kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 5717288 Bytes = 5.5 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum … OK Loading Kernel Image … OK OK 5.715: mmc exit start 5.728: mmc 2 cmd 8 err 100 5.733: mmc send if cond failed 5.737: mmc 2 cmd 55 err 100 5.742: send app cmd failed 5.754: get sdc_phy_wipe fail. 5.758: get sdc0 sdc_erase fail. 5.762: get sdc_2xmode ok, val = 1 5.766: get sdc_ddrmode ok, val = 1 5.770: get sdc_f_max fail,use default 50000000Hz 5.775: get card_line ok, card_line = 8 5.780: get sdc_ex_dly_used fail,use default 5.785: mmc 2 exit ok [ 5.788] Starting kernel …
boot, get meminfo: Start: 0x40000000 Size: 2048MB ion_carveout reserve: 96m 128m ion_reserve_common: ion reserve: [0xb8000000, 0xc0000000]! ion_cma reserve: 120m 176m 512m ion_reserve_common: ion reserve: [0xa0000000, 0xc0000000]! ------sun8i_smp_init_ops----37----- [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.39-BPI-M3-Kernel (root@8ac3451c5c3b) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Tue May 3 13:47:01 UTC 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 512 MiB at a0000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 524288 [ 0.000000] free_area_init_node: node 0, pgdat c0c7c540, node_mem_map c0d2f000 [ 0.000000] Normal zone: 1404 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 158340 pages, LIFO batch:31 [ 0.000000] HighMem zone: 3204 pages used for memmap [ 0.000000] HighMem zone: 361340 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] [mcpm_smp_init_cpus] ncores=8 [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1f53000 s11776 r8192 d12800 u32768 [ 0.000000] pcpu-alloc: s11776 r8192 d12800 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519680 [ 0.000000] Kernel command line: enforcing=1 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootwait init=/init vmalloc=384M ion_cma_list=“120m,176m,512m” loglevel=8 bootmenutimeout=10 datadev=mmcblk0p2 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1535508k/1535508k available, 561644k reserved, 933888K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe7800000 - 0xff000000 ( 376 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe7000000 ( 624 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0ae0dd0 (11108 kB) [ 0.000000] .init : 0xc0ae1000 - 0xc0b39e00 ( 356 kB) [ 0.000000] .data : 0xc0b3a000 - 0xc0c93a50 (1383 kB) [ 0.000000] .bss : 0xc0c93a74 - 0xc0d2e258 ( 618 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.001345] Calibrating delay loop (skipped), value calculated using timer frequency… 4800.00 BogoMIPS (lpj=24000000) [ 0.001418] pid_max: default: 32768 minimum: 301 [ 0.001752] Mount-cache hash table entries: 512 [ 0.003102] Initializing cgroup subsys cpuacct [ 0.003148] Initializing cgroup subsys memory [ 0.003221] Initializing cgroup subsys devices [ 0.003255] Initializing cgroup subsys freezer [ 0.003287] Initializing cgroup subsys blkio [ 0.003341] Initializing cgroup subsys perf_event [ 0.003437] CPU: Testing write buffer coherency: ok [ 0.003526] ftrace: allocating 27619 entries in 81 pages [ 0.040301] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.040384] Setting up static identity map for 0x4076b5a8 - 0x4076b600 [ 0.010000] CPU1: Booted secondary processor [ 0.010000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.010000] CPU2: Booted secondary processor [ 0.010000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.010000] CPU3: Booted secondary processor [ 0.010000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.260089] CPU4: failed to boot: -22 [ 0.300068] CPU5: failed to boot: -22 [ 0.340069] CPU6: failed to boot: -22 [ 0.380092] CPU7: failed to boot: -22 [ 0.380306] Brought up 4 CPUs [ 0.380332] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.380910] devtmpfs: initialized [ 0.387462] pinctrl core: initialized pinctrl subsystem [ 0.411064] NET: Registered protocol family 16 [ 0.434051] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.434164] script_sysfs_init success [ 0.434215] sunxi_dump_init success [ 0.435357] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.437175] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.437639] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl [ 0.438869] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.438914] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.439773] [sunxi-module]: [sunxi-module.0] probe success [ 0.440454] script config pll_video1 to 297 Mhz [ 0.440491] script config pll_ve to 432 Mhz [ 0.440515] Not Found clk pll_periph in script [ 0.440543] script config pll_gpu to 432 Mhz [ 0.440572] script config pll_hsic to 480 Mhz [ 0.440600] script config pll_de to 504 Mhz [ 0.440622] sunxi_default_clk_init [ 0.440642] try to set pll6ahb1 to 200000000 [ 0.440703] try to set ahb clk source to pll6ahb1 [ 0.440728] set ahb clk source to pll6ahb1 [ 0.440753] try to set ahb1 to 200000000 [ 0.440778] try to set apb1 to 100000000 [ 0.441696] ===fe3o4==== sunxi_root_procfs_attach ret:0 [ 0.451320] bio: create slab at 0 [ 0.451320] [ARISC] :sunxi-arisc driver v1.70 [ 0.463403] [ARISC] :arisc version: [v0.1.25.3] [ 0.463459] [sunxi-module]: arisc register success [ 0.463891] sunxi_get_soc_bin: slow chip [ 0.464341] [ARISC] :sunxi-arisc driver v1.70 startup succeeded [ 0.010000] CPU4: Booted secondary processor [ 0.010000] CPU4: thread -1, cpu 0, socket 1, mpidr 80000100 [ 0.010000] CPU5: Booted secondary processor [ 0.010000] CPU5: thread -1, cpu 1, socket 1, mpidr 80000101 [ 0.010000] CPU6: Booted secondary processor [ 0.010000] CPU6: thread -1, cpu 2, socket 1, mpidr 80000102 [ 0.010000] CPU7: Booted secondary processor [ 0.010000] CPU7: thread -1, cpu 3, socket 1, mpidr 80000103 [ 0.491426] SCSI subsystem initialized [ 0.491426] libata version 3.00 loaded. [ 0.491426] usbcore: registered new interface driver usbfs [ 0.491426] usbcore: registered new interface driver hub [ 0.491426] usbcore: registered new device driver usb [ 0.491426] twi_chan_cfg()335 - [twi0] has no twi_regulator. [ 0.491426] twi_chan_cfg()335 - [twi1] has no twi_regulator. [ 0.491426] twi_chan_cfg()335 - [twi2] has no twi_regulator. [ 0.491702] Linux video capture interface: v2.00 [ 0.500643] BPI-M3: tmp [00] [ 0.500643] BPI-M3: set PMIC AC 4000mA [ 0.500643] BPI-M3: set PMIC AC 4000mA [ 0.510411] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.511088] Bluetooth: Core ver 2.16 [ 0.511160] NET: Registered protocol family 31 [ 0.511186] Bluetooth: HCI device and connection manager initialized [ 0.511219] Bluetooth: HCI socket layer initialized [ 0.511245] Bluetooth: L2CAP socket layer initialized [ 0.511291] Bluetooth: SCO socket layer initialized [ 0.511586] cfg80211: Calling CRDA to update world regulatory domain [ 0.511680] Switching to clocksource arch_sys_counter [ 0.537827] FS-Cache: Loaded [ 0.538176] CacheFiles: Loaded [ 0.549908] axp81x_dcdc1: Failed to create debugfs directory [ 0.551126] NET: Registered protocol family 2 [ 0.551510] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.552310] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.554806] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.556391] TCP: Hash tables configured (established 131072 bind 65536) [ 0.556422] TCP: reno registered [ 0.556449] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.556516] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.556951] NET: Registered protocol family 1 [ 0.557409] RPC: Registered named UNIX socket transport module. [ 0.557442] RPC: Registered udp transport module. [ 0.557466] RPC: Registered tcp transport module. [ 0.557490] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.558205] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.558399] [pm]aw_pm_init! [ 0.558425] standby_mode = 1. [ 0.558446] wakeup src cnt is : 2. [ 0.558473] pmu name: pmu1_para . [ 0.558498] pmu1_enable = 0x1. [ 0.558519] pmux_id = 0x7. [ 0.558541] pmu name: pmu2_para . [ 0.558563] config_pmux_para: script_parser_fetch err. [ 0.558588] pmu2_enable = 0x0. [ 0.559004] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559189] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559229] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559321] after inited: sys_mask config = 0xebd5. [ 0.559349] dynamic_standby enalbe = 0x0. [ 0.559403] sunxi_reg_init enter [ 0.559712] lock super standby for a83! [ 0.559746] lookup_scene_lock_name: new scene lock super_standby [ 0.559774] scene_lock_init name=super_standby [ 0.559800] scene_lock: super_standby, type 5, count 1 [ 0.561787] highmem bounce pool size: 64 pages [ 0.569692] VFS: Disk quotas dquot_6.5.2 [ 0.570099] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.572288] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.572858] NFS: Registering the id_resolver key type [ 0.573621] Installing knfsd (copyright © 1996 okir@monad.swb.de). [ 0.574892] NTFS driver 2.1.30 [Flags: R/W]. [ 0.575318] fuse init (API version 7.18) [ 0.576472] ceph: loaded (mds proto 32) [ 0.576520] msgmni has been set to 1175 [ 0.584823] alg: No test for stdrng (krng) [ 0.668242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.668301] io scheduler noop registered [ 0.668326] io scheduler deadline registered [ 0.668532] io scheduler cfq registered (default) [ 0.669004] pwm module init! [ 0.669613] [DISP]disp_module_init [ 0.703718] [DISP] Fb_map_kernel_logo,line:895:Fb_map_kernel_logo failed! [ 0.719007] Console: switching to colour frame buffer device 160x45 [ 0.735165] [DISP]disp_module_init finish [ 0.810691] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.810900] sw_uart_pm()890 - uart0 clk is already enable [ 0.811066] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 1.003426] console [ttyS0] enabled [ 1.309476] axp81x_dcdc1: Failed to create debugfs directory [ 1.470402] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 1.470943] axp81x_dcdc1: Failed to create debugfs directory [ 1.471098] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 1.472183] [drm] Initialized drm 1.1.0 20060810 [ 1.487084] brd: module loaded [ 1.493749] loop: module loaded [ 1.494075] [rf_pm]: select module num is 10 [ 1.494091] [rf_pm]: module power1 name vcc-wifi-io [ 1.494105] [rf_pm]: failed to fetch module_power1_vol [ 1.494120] [rf_pm]: module power2 name [ 1.494133] [rf_pm]: failed to fetch module_power2_vol [ 1.494148] [rf_pm]: module power3 name [ 1.494161] [rf_pm]: failed to fetch module_power3_vol [ 1.494175] [rf_pm]: mod has no power_switch gpio [ 1.494188] [rf_pm]: mod has no chip_en gpio [ 1.494202] [rf_pm]: lpo_use_apclk: ac10032k2 [ 1.494310] [rf_pm]: get power regulator failed. [ 1.494324] [rf_pm]: enable vcc-wifi-io. [ 1.629397] [rf_pm]: mod info power switch -1 [ 1.810152] [rf_pm]: set ac10032k2 32k out [ 1.810165] scene_lock_init name=rf_pm [ 1.810545] [wifi_pm]: wifi gpio init is OK !! [ 1.810623] [rfkill]: mod has no ls_int gpio [ 1.810632] [rfkill]: mod has no pcm_ch gpio [ 1.810970] [rfkill]: rfkill set power 0 [ 1.830114] Loading iSCSI transport class v2.0-870. [ 1.830633] iscsi: registered transport (tcp) [ 1.831117] [spi]: Found 1 spi devices in config files [ 1.831130] boards_num modalias max_spd_hz bus_num cs mode [ 1.831149] 0 spidev 33000000 0 0 3 [ 1.831599] axp81x_dcdc1: Failed to create debugfs directory [ 1.831868] spi spi0: master is unqueued, this is deprecated [ 1.832251] allwinners SoC SPI Driver loaded for Bus SPI-0 with 1 Slaves at most [ 1.832264] [spi-0]: driver probe succeed, base f1c68000, irq 97! [ 1.833812] usbcore: registered new interface driver qf9700 [ 1.833896] usbcore: registered new interface driver smsc95xx [ 1.833961] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 1.854081] sunxi-ehci sunxi-ehci.1: SW USB2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 1.854117] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 1.945596] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 2.280047] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 2.441837] ehci_irq: highspeed device connect [ 2.441955] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.441968] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.441980] usb usb1: Product: SW USB2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 2.441991] usb usb1: Manufacturer: Linux 3.4.39-BPI-M3-Kernel ehci_hcd [ 2.442002] usb usb1: SerialNumber: sunxi-ehci [ 2.600466] hub 1-0:1.0: USB hub found [ 2.600495] hub 1-0:1.0: 1 port detected [ 2.600946] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver [ 2.621063] sunxi-ohci sunxi-ohci.1: SW USB2.0 ‘Open’ Host Controller (OHCI) Driver [ 2.621096] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2 [ 2.621141] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 <6>[ 2.684145] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.684158] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.684170] usb usb2: Product: SW USB2.0 ‘Open’ Host Controller (OHCI) Driver [ 2.684181] usb usb2: Manufacturer: Linux 3.4.39-BPI-M3-Kernel ohci_hcd [ 2.684191] usb usb2: SerialNumber: sunxi-ohci [ 2.684760] hub 2-0:1.0: USB hub found [ 2.684785] hub 2-0:1.0: 1 port detected [ 2.685215] Initializing USB Mass Storage driver… [ 2.685354] usbcore: registered new interface driver usb-storage [ 2.685363] USB Mass Storage support registered. [ 2.685436] usbcore: registered new interface driver ums-alauda [ 2.685488] usbcore: registered new interface driver ums-cypress [ 2.685541] usbcore: registered new interface driver ums-datafab [ 2.685593] usbcore: registered new interface driver ums_eneub6250 [ 2.685646] usbcore: registered new interface driver ums-freecom [ 2.685697] usbcore: registered new interface driver ums-isd200 [ 2.685746] usbcore: registered new interface driver ums-jumpshot [ 2.685796] usbcore: registered new interface driver ums-karma [ 2.685846] usbcore: registered new interface driver ums-onetouch [ 2.685912] usbcore: registered new interface driver ums-realtek [ 2.685977] usbcore: registered new interface driver ums-sddr09 [ 2.686029] usbcore: registered new interface driver ums-sddr55 [ 2.686083] usbcore: registered new interface driver ums-usbat [ 2.686221] usbcore: registered new interface driver usbserial [ 2.686287] usbcore: registered new interface driver usbserial_generic [ 2.686333] USB Serial support registered for generic [ 2.686348] usbserial: USB Serial Driver core [ 2.686679] file system registered [ 2.688643] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 2.688656] android_usb gadget: Number of LUNs=3 [ 2.688667] lun0: LUN: removable file: (no medium) [ 2.688677] lun1: LUN: removable file: (no medium) [ 2.688687] lun2: LUN: removable file: (no medium) [ 2.689071] android_usb gadget: android_usb ready [ 2.774019] axp81x_dcdc1: Failed to create debugfs directory [ 2.920170] usb 1-1: new high-speed USB device number 2 using sunxi-ehci [ 3.073224] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver [ 3.441679] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3 [ 3.454149] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.464948] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.476174] usb usb3: Product: sunxi_hcd host driver [ 3.484794] usb usb3: Manufacturer: Linux 3.4.39-BPI-M3-Kernel sunxi_hcd-hcd [ 3.495780] usb usb3: SerialNumber: sunxi_hcd_host0 [ 3.504341] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 3.504938] hub 3-0:1.0: USB hub found [ 3.504963] hub 3-0:1.0: 1 port detected [ 3.506019] mousedev: PS/2 mouse device common for all mice [ 3.506408] sunxikbd_script_init: key para not found, used default para. [ 3.507281] sunxi_rtc_init(796): sunxi rtc device register! [ 3.507412] keyname:ctp_para subname:ctp_power_io ,get error! [ 3.508016] rtc_gettime(333): read time 1970-1-1 1:39:8 [ 3.508198] get sysconfig para erro! [ 3.508221] get sysconfig para erro! [ 3.508239] get sysconfig para erro! [ 3.508258] get sysconfig para erro! [ 3.508306] ctp_wakeup: !!!gpio data 1 [ 3.508409] alarm_gettime(470): get alarm time 1970-1-1 1:0:0 success! [ 3.508834] rtc_gettime(333): read time 1970-1-1 1:39:8 [ 3.509107] rtc0 rtc0: rtc core: registered rtc0 as rtc0 [ 3.509328] sunxi_rtc_probe(756)! [ 3.509412] i2c /dev entries driver [ 3.510288] IR RC5(x) protocol handler initialized [ 3.510463] sunxi cedar version 0.1 [ 3.510544] [cedar]: install start!!! [ 3.510785] [cedar]: install end!!! [ 3.510822] Driver for 1-wire Dallas network protocol. [ 3.516723] Bluetooth: HCI UART driver ver 2.2 [ 3.516735] Bluetooth: HCI H4 protocol initialized [ 3.516744] Bluetooth: HCI BCSP protocol initialized [ 3.516753] Bluetooth: HCI Realtek H5 protocol initialized [ 3.517355] sunxi_get_soc_bin: slow chip 3.520118: SD/MMC/SDIO Host Controller Driver(v1.113 2015-5-20 17:17) Compiled in May 3 2016 at 13:30:14 3.520170: get mmc1’s sdc_power is null! 3.520189: get mmc2’s 2xmode ok, val = 1 3.520194: get mmc2’s ddrmode ok, val = 1 3.520202: MMC host used card: 0x7, boot card: 0x5, io_card 2 [ 3.610047] get_device_para_value:get subname:icn83xx_ts error! val.val:0 [ 3.610054] get_detect_list: script_get_item err.support_number = 11. [ 3.610062] get_device_para_value:get subname:gt818_ts error! val.val:0 [ 3.610067] get_detect_list: script_get_item err.support_number = 8. [ 3.610073] get_device_para_value:get subname:tu_ts error! val.val:0 [ 3.610078] get_detect_list: script_get_item err.support_number = 7. [ 3.610085] get_device_para_value:get subname:gt9xxf_ts error! val.val:0 [ 3.610090] get_detect_list: script_get_item err.support_number = 6. [ 3.610098] get_device_para_value:get subname:gslX680new error! val.val:0 [ 3.610103] get_detect_list: script_get_item err.support_number = 3. [ 3.610147] sw_get_write_info:open error …IS(filp):1 [ 3.610161] sw_set_write_info:open error …IS(filp):1 [ 3.610165] get write info erro! [ 3.610356] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.630183] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.647211] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.650188] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.670191] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.690186] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.777161] usb 1-1: Product: USB 2.0 Hub 3.777401: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.778488: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.780051: sdc0 fail to get regulator 3.780057: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 3.800026: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.820844: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 3.821676: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 3.821698: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.824166: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.826062: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 3.826081] Try sdio 3.826894: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.827719: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.828545: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.829369: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.829389] *******************Try sd ******************* 3.830205: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.831032: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.831859: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.832687: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.832705] Try mmc 3.832713: sdc0 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.833608: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! 3.833629: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.833724: sdc0 fail to get regulator 3.833729: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail 3.836295: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.837821: sdc0 fail to get regulator 3.837826: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 3.850030: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.871105: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 3.872201: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 3.872222: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.874820: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.876995: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 3.877014] Try sdio 3.878095: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.879188: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.880282: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 3.881375: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.881394] *******************Try sd ******************* 3.882475: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.883572: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.884668: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 3.885762: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.885780] Try mmc 3.885787: sdc0 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.886962: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! 3.886983: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.887073: sdc0 fail to get regulator 3.887078: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail 3.889643: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 3.891168: sdc0 fail to get regulator 3.891174: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 3.903767: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.904071] hub 1-1:1.0: USB hub found [ 3.904180] hub 1-1:1.0: 4 ports detected 4.180061: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 4.201672: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 4.203316: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 4.203344: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 4.206215: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 4.208957: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 4.208981] Try sdio 4.210602: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 4.212237: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 4.213872: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 4.215507: *** sunxi_mci_dump_errinfo(HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000
(miguel) #5
I’m using HDMI out, and 2A power supply
(Nestor Cagnoli) #6
Hi Eloah!
Now with 2.4A Power Supply on “usb power” and 1A power supply on USB OTG i got a correct boot.
Thanks for help.
(miguel) #7
OK. It seems to be the same problem as ncagnoli reported. When connecting the 5v-2,5A to micro-USB alone, it doesn’t boot. But while connecting other power source (1A) to the power jack at the same time, it boots up correctly.
Thanks for your help.
(Tv Schraeg) #8
and support DVI with Rasbian? Can you help ? And the Audio analog?
