BPI-M3 new image: ArchLinuxARM-lite-bpi-m3 2016-5-10
Heya, maybe you’ll need this SDCard-burner called PhoenixCard Tool !
I remember I had to use it to burn the android images for BPI-M3 I found here… in that tool you have chose whether to create a direct bootable SD card or to create a SD card that only burns your image to the (faster) emmc storage when it boots.
From then I’d suggest to make dd images of the emmc regularly as backups!
peace
Good day! I download your image, burn it to SD card. Insert card to my bpi-m3, turned it on, but after welcome screen banana turning off. What am i doing wrong?
I have another image: BPI-M3 new image:ArchLinuxARM Lite for BPI-M3 (20151209) - it works fine.
Mine was doing this until I switched to using a 5.1 V 2.5 A power supply directly to the DC in jack, instead of using USB. The one of the Steam Link fits perfect.
@sinovoip Would it be possible to update this image? Thanks
@sinovoip what toolchain did you use when compiling this kernel?
I’ve prepared image for Banana Pi-M3 with Arch Linux sunxi kernel-4.18-rc3 and uboot-2018.01.
Maybe someone will find it usefull.
SMP - Works, Wifi - Works.
