BPI-M2 New Image (Ubuntu15.04 beta V4.0) Release
“FATAL: Module fft5x_ts.ko not found.” The module is not found And shouldn’t that driver is for the bpi-m1+? I used the bpi-m2 one. And i need to add that it is the wrong pic
HI: Please try again.
fft5x_ts.ko ==> ft5x_ts.ko
sudo modprobe ft5x_ts.ko
That is the correct pic.
And for the command the same thing happen FATAL: Module ft5x_ts.ko not found.
HI: try it
cd /lib/modules/3.3.0-BPI-M2-Kernel/kernel/drivers/input/touchscreen sudo modprobe ft5x_ts.ko
The modprobe command run without a problem but the bottom of the touchscreen still doesn’t work fyi the upper part of the screen. The touchscreen does work
The bottom one doesn’t work
Is this a case of hardware malfunction? Or is this a software malfunction. Could you just please show me that your touch screen on the bottom part is responding and working. So we could plan to order another touch screen
please wating ,we test it now.
Why does setting up the touchscreen, the bananapi, and booting it up takes such a long time? Does the lcd didn’t work?
