BPI-M2+ new image: Debian-8-jessie-lite-bpi-m2p-sd-emmc.img V1.1 2016-5-15
(bpi team) #1
2016-05-15-debian-8-jessie-lite-bpi-m2p-sd-emmc.img.zip
  1. BPI-M2P kernel 3.4
  2. username & password: root/bananapi
  3. support HDMI 1080P & 720P(default)
  4. support eMMC
  5. support GMAC
  6. support WIFI
  7. support bpi-bootsel cmd can switch to (bpi-m3 & bpi-m2 & bpi-m2p)
  8. support uEnv.txt to fatload script.bin & uImage
  9. support uEnv.txt to set video 1080P & 720P & 480P …
  10. fix rootmydevice issue
  11. based on armbian rootfs, thanks for armbian
Google Drive: https://drive.google.com/file/d/0B_YnvHgh2rwjQ1g5SG03bG9YYzg/view?usp=sharing
MD5: 93b9a4d16d55dc5e99795d8084f4f941
you can use bootsel commond to run it on BPI-M3, or run openelec on BPI-M2+
(AJS) #2
HI, when can we expect an image with BT working
(dontje) #3
i try this image, burnt with win32disk imager, but cannot boot up display just blank anything i’m missing?
(bpi team) #4
please reference here:
https://bananapi.gitbooks.io/bpi-m2-/content/bpi-m2+_quick_start.html
(bpi team) #5
BT driver have include in this image , but some issue for setting ,we try to fixed it.
(dontje) #6
follow this https://bananapi.gitbooks.io/bpi-m2-/content/bpi-m2+_quick_start.html but still cannot see display i try armbian image, works fine
(bpi team) #7
are you format your SD card at first???
(dontje) #8
yes, exactly follow instruction formatted with SD formater downloaded from https://www.sdcard.org/downloads/formatter_4/eula_windows/ after burn image, sdcard can be mounted successfully under linux and I can see 2 partition; fat32 and ext4 which means sdcard not corrupted
#9
By accident I observed a strange behaviour with this image on the M2+ board. Accessing /proc/sram as a normal user leads to a kernel oops message and leaves the system in an unusable state, e.g. accessing the file system is impossible.
bpr@bananapi:~$ cat /proc/sram
Message from syslogd@localhost at Jun 17 18:57:35 ...
 kernel:[  173.241581] sunxi oops: enable sdcard JTAG interface
Message from syslogd@localhost at Jun 17 18:57:38 ...
 kernel:[  173.251561] sunxi oops: cpu frequency: 912 MHz
 kernel:[  173.251561] sunxi oops: ddr frequency: 672 MHz
 kernel:[  173.251561] sunxi oops: gpu frequency: 105 MHz
 kernel:[  173.251561] sunxi oops: cpu temperature: 61
 kernel:[  173.251561] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
 kernel:[  173.251561] Process cat (pid: 1314, stack limit = 0xe5be62f8)
 kernel:[  173.251561] Stack: (0xe5be7e60 to 0xe5be8000)
 kernel:[  173.251561] 7e60: c0a828c0 e5be7ebc e5be7e80 c0a828e0 e5be7ebc e5be7e80 c0024144 c0387f80
 kernel:[  173.251561] 7e80: 0000c000 00000000 00000000 c0a828d4 e5be7ec4 e5d52540 00000001 00000001
 kernel:[  173.251561] 7ea0: 00000000 00020000 b6c6c000 e5be7ed0 e5be7f0c e5be7ec0 c01382d4 c0024108
 kernel:[  173.251561] 7ec0: c00fffdc e5d52568 e5df5ec0 e5be7f70 00000000 00000000 00000000 c072d368
 kernel:[  173.251561] 7ee0: e676a368 e6316d40 c01380f0 e5df5ec0 00020000 b6c6c000 e6316d8c e5be7f70
 kernel:[  173.251561] 7f00: e5be7f3c e5be7f10 c016691c c01380fc e5be7f70 00020000 e5df5ec0 b6c6c000
 kernel:[  173.251561] 7f20: e5be7f70 00000000 00000000 00000000 e5be7f6c e5be7f40 c0119968 c0166898
 kernel:[  173.251561] 7f40: e5be6000 b6c6b000 00022000 e5df5ec0 b6c6c000 00020000 00000003 00000000
 kernel:[  173.251561] 7f60: e5be7fa4 e5be7f70 c0119a30 c01198b4 00000000 00000000 00000022 00000000
 kernel:[  173.251561] 7f80: ffffffff 00020000 00020000 b6c6c000 c000e368 e5be6000 00000000 e5be7fa8
 kernel:[  173.251561] 7fa0: c000e100 c01199f0 00020000 00020000 00000003 b6c6c000 00020000 000271c4
 kernel:[  173.251561] 7fc0: 00020000 00020000 b6c6c000 00000003 7fffe000 00000000 00000000 00020000
 kernel:[  173.251561] 7fe0: 00000000 beebe524 00013835 b6ea0fa6 400f0030 00000003 00000000 00000012
 kernel:[  173.251561] Code: e1a04000 ebf47676 e1a02004 e3a04000 (e5b23008)
Segmentation fault
bpr@bananapi:~$ top
-bash: /usr/bin/top: Input/output error
(freeman32) #10
Hello I’m new user of banana-pi M2+ and i’m learning for activate the wifi on this version lite.
Thanks you for reply !
Sorry for my english !
