BananaPi M3 + touchscreen USB/HDMI (help)
(Frigorifico El Golli) #1
Hi. I have a bananapi M3 with ubuntu (I was test with these images: 2018-01-04-ubuntu-16.04-mate-desktop-v1.0-bpi-m3-sd-emmc and 2017-07-13-ubuntu-16.04-mate-desktop-beta-bpi-m3-ov8865-sd-emmc), but the touch functions not working.
Explanation: the touchscreen have 2 usb (one for power and one for “touch signal”), when I powered on the bananapi, the screen works, image is displayed, but the touch (just touch) not work. The bananapi is conected a DC 5v/2A. I tried plug a usb power screen in my usb notebook, but the result is the same. P.S.: When the usb touch and hdmi cable (from touchscreen) was plugged in the bananapi and usb power (from touchscreen) was plugged in my notebook, when I try power on the bananapi, it not work, I need unplug usb touch cable from bananapi for it power on, then I plug again and works, the screen display image but the touch functions not work. Testing the touchscreen in my notebook wich windows 10, it works normaly, touch and image.
The touchscreen is exactly this: https://pt.aliexpress.com/item/10-Polegada-IPS-Tela-de-Toque-Capacitivo-Para-Raspberry-Pi-1280-800-TFT-LCD-Touch-Display/32856398095.html?spm=a2g0s.9042311.0.0.7634b90aAHCCpE
Someone can help me?
Thanks.
Bom dia. Tenho um bananaPi M3, já testei com essas imagens, mas o resultado foi o mesmo: 2018-01-04-ubuntu-16.04-mate-desktop-v1.0-bpi-m3-sd-emmc e 2017-07-13-ubuntu-16.04-mate-desktop-beta-bpi-m3-ov8865-sd-emmc.
Comprei essa tela de 10": https://pt.aliexpress.com/item/10-Polegada-IPS-Tela-de-Toque-Capacitivo-Para-Raspberry-Pi-1280-800-TFT-LCD-Touch-Display/32856398095.html?spm=a2g0s.9042311.0.0.7634b90aAHCCpE
Mas quando ligo no bananaPi, ela mostra a imagem normal, porém as funções de touchscreen não funcionam. A tela tem 2 usbs (1 para a energia e 1 para o touch) e um HDMI. Já testei ligando o usb da energia no usb do meu notebook, e também ligando diretamente na energia, mas também não funcionou. O bananaPi está ligado na energia com um carregador via entrada DC com 5V/2A. Já testei a tela em meu notebook com windows, e funciona normalmente, tanto o touch quanto a imagem. Uma questão que achei interessante, quando eu tento ligar o bananaPi, ele não liga, eu preciso desconectar os usb (da tela) então ele liga, dai posso ligar os usbs novamente e liga normalmente (porém somente a imagem é exibida, o touch não funciona).
Alguém consegue me ajudar? Obrigado.
