Banana Pi BPI-W2 android source code
Android 6 :
Android 7 :
BPI-W2 wiki documents:
Android 6 :
Android 7 :
Do both Ethernet ports work on this port ?
yes , ethernet work fine
Hello.
The scripts builded in blow directory /home/stan/externel/60_e/build_scripts/OpenWrt-ImageBuilder-rtd1295-mnas_emmc.Linux-x86_64/
feed.conf has the path need to correct
on make -j1 V=s got too much error need to edit one by one.
please can you share only the RTD1295 hardware config file and kernel path to compile the source of openWRT.
Thanks in Advance.
I re edit paths files and correct Lib path I hope will finish today
machine Linux ubuntu 5.19.0-31-generic #32-Ubuntu x86_64 GNU/Linux
nproc 40
thanks
