Banana Pi BPI-R2 19.07.7 OpenWRT Router image 2021-04-15, Kernel 4.19.81
Wan IP : DHCP
Lan IP : 192.168.1.1
image download:
google driver:
baidu link : 百度网盘 请输入提取码 Pincode: fthx
source code on github:
Wan IP : DHCP
image download:
google driver:
i try to compile this image in ubuntu,but there are some error when i complie. error message is as follows:
‘’’ checking for library containing fdatasync… none required checking for fdatasync… (cached) yes checking for cap_get_file in -lcap… no configure: error: libcap library was not found or not usable Makefile:151: recipe for target ‘/home/rst/work_dir/bpi-r64-openwrt/BPI-R64-openwrt/build_dir/target-aarch64_cortex-a53_musl/coreutils-8.32/.configured_68b329da9893e34099c7d8ad5cb9c940’ failed make[3]: *** [/home/rst/work_dir/bpi-r64-openwrt/BPI-R64-openwrt/build_dir/target-aarch64_cortex-a53_musl/coreutils-8.32/.configured_68b329da9893e34099c7d8ad5cb9c940] Error 1 ‘’’
i alredy install libcap-dev,but also complie fail,can u help me,please,thx
I also compile the image based on BPI-R64-openwrt code, but it can upgrade successfully on SD image(OpenWRT Router image 2021-05-01).
I can not find a way to upgrade the openwrt-mediatek-mt7622-BPI-R64-SD-squashfs-sysupgrade.bin.
Can anyone help to fix it? Thanks!
