April 15, 2021, 7:33am
Banana Pi BPI-R2 19.07.7 OpenWRT Router image 2021-04-15, Kernel 4.14.112
Wan IP : DHCP
Lan IP : 192.168.1.1
google image download link:
baidu link :
https://pan.baidu.com/s/1_0dWUsLXc4HUurAdleOf_w pincode: 7262
source code on github:
github source code have update ,please use make V=s -j12 commond compile youself image , or you can development with this code.
@sinovoip I was facing same problem. Luckily i saw your post thanks for sharing this with us. Really good man.
DeadMeat
(Alex R.)
April 18, 2021, 8:32am
6
The same for me - no access.
mhz
(mhz)
April 18, 2021, 10:32pm
7
Hi !
The link requires to submit a request to access the file. Can you change that to public access?
April 19, 2021, 2:16am
10
alex72
(Александр)
April 19, 2021, 2:32pm
11
changes are not saved after a reboot
DeadMeat
(Alex R.)
April 20, 2021, 3:44am
12
All my interfaces-related changes has been saved, and applied across reboot.
frank-w
(Frank W.)
April 24, 2021, 6:43am
15
Is mainline openwrt still unusable? Wifi driver will not be accepted upstream due to size and qualita…but if you compile your own you can merge driver source from my repo
DeadMeat
(Alex R.)
April 24, 2021, 9:16pm
16
I use it just for testing/learning, so no production-used yet.
I don’t need wifi right now, but some day i’ll try;)
frank-w
(Frank W.)
April 25, 2021, 9:35am
17
I meant why using an outdated version with kernel 4.14…
DeadMeat
(Alex R.)
April 26, 2021, 4:30am
18
I bricked it on my last kernel update attempt
guzhvaan
(Андрей Гужва)
February 10, 2022, 5:33pm
19
Hello everyone There is no Wireless in the Network item. Why? How to set up WIFI ?
