Hello: When it says it will run Linux Ubuntu is this the same x86 version my desktop will run? I need to be able to use Google Chrome not Chromium. Also when will it be available in the U.S. Thank you for your responce.
Hi! Is there a Ubuntu Core image for the BPI-M64 board please? Thank you in advance for your reply.
allwinner A64 chip and R18 chip is PIN to PIN compatibility, so BPI-M64 just replace R18 ,A64 chip onboard, easy to DIY new product.
QUESTION: I purchased an AC adapter for my bpi-m64, and bpi-m3 (couldnāt decide which one i wanted, so i bought both).
The adapter i bought says itās output is 5VDC 3000ma.
When i MEASURE the output with a digital multimeter, i see 5.38VDC.
Is that voltage too high? Will it cause any harm? OR is it ok to use this adapter?
How I will root it in android 7� is there any android image with root access�
Hello, could you use adb shell? this is root permission.
