Hello sinovoip bpi Team, thank you for your answer. I need not a datasheet and a schematic diagram, I need a Image to flash a SD-Card. For days I try to burn a SD card however without succes. Is there an image running on the Banana Pi M2 Berry? The images you have proposed do not run at my Banana Pi. Best Regards Jürgen
you can use this miage
Thank you very much for your answer. My Model is “Banana Pi M2 Berry”, V40 Quadcore 1,2 GHz, SATA WLAN, GBLAN, BT Serial# 4250236815510 CR-1573544 Best Regards Jürgen
Dear Sir, Thank you for your hint. I have used this Image. But it did not work. You can watch the result in a video. The Link to the Video: https://www.magentacloud.de/lnk/AcgCiu3M. Use VLC Media Player to watch the Video-Stream. Regards Jürgen
Hallo Sie müssen darauf achten wie die Bezeichnung ist Ich habe das gleiche gerät Banana PI BPI-M2 / BPI-M2 Berry Funktioniert einwandfrei. Achim
Let’s talk wedge pillows! Numerous studies have shown that sleeping in an elevated position not only helps alleviate symptoms from acid reflux or GERD, but also help with flu, back pains, and swollen feet.
My M2 berry v1.0 board is shutting down after running for some minutes without warning. I’m running the official image, Ubuntu 16.04, downloaded from the M2 berry wiki page. I’d like to investigate if one of the components is broken. The schematics have been posted here, but I’m missing the board view. Would it be possible to share that? Or if it is already, where can I find it?
