Auto power on problem
Hi guys. I have a problem with my BPI-R2. When I plug the power cable the system is not started automatically and I should hold the power button to bring the system up. I use regular 2A adaptors and official BPI Lede image. Thanks
hold the power key for around 8s~, and please change your tag to BPI-R2, thanks
Thanks, Jackzeng. The problem is every time I want to boot the system I should hold the power key. Is there any way that the system automatically boots the OS when I plug the power cable. thanks
if usb otg port is connected to pc, system can boot up after power on, thanks.
Is there any way to boot up without otg port ?
You can solder pins of power-switch
Can I ask you to describe your solution ? Thanks
https://www.fw-web.de/dokuwiki/doku.php?id=en/bpi-r2/hardware
Near on top…if you want to use actial 4.14 kernel please see linked issue
thanks, frank it worked
