Downloaf https://www.armbian.com/bananapi-m3/
serial console, 8 cores, DVFS, USB, SATA, HDMI, DRM video driver, …
https://forum.armbian.com/topic/474-banana-pi-m3/?do=findComment&comment=57400
is it possible to friend this img with 7 LCD module?
There is no direct support, which means you can’t just enable it … but anything is possible. If you have some knowledge, guts and time, here is an example which could help:
thank you i will try to smoke your example and do it.
Updated images:
Fixed Ethernet: https://github.com/armbian/build/commit/d28cbcaf79169b684c11f599ebd3e441d029c66e
Updated images with slightly higher CPU clock.
OK, but where ? I can’t seem to find it
Images: https://dl.armbian.com/bananapim3/
If you want to build image, https://github.com/armbian/build script needs extra parameter to build unsupported targets, EXPERT=“yes”
Amazing work! This is the only stable image I’ve found for the Bananapi M3. Everything that Sinovoip wasn’t able to do until today. Thank you so much
Hello guys!
I tried all the known options for me to connect the LCD display S070WV20HG-DC16 with the touchscreen on the ft5x_ts driver, and failed because apparently not smart enough for this, the my brains are exploding.
In the kernel, I did not find the drivers on the display (S070WV20_MIPI_RGB) and the driver on the screen in the kernel is not compiled.
Is anyone can correct in the device tree file the parameters for the LCD section for the display as I understood the data can be taken from the fex file:1.fex.txt (75.7 KB)
pull in the kernel driver for the display for compilation from here:S070WV20_MIPI_RGB.c
And make correct Device tree binary file(dtb),Uboot and drivers for kernel.
I will award beer for the implemented solution
I am afraid it is not a simple task even for those few people that can handle this without extensive learning.
Minimum board support costs - dealing with (board only) hardware and people easily cost our project on average 15-20.000 EUR per year per board while end-user donations are still only up to a few hundred per month. For the whole project - people and infrastructure. This means support is heavily sponsored by our private resources. If “you” would cover costs I will be more than happy to help “you” whenever I can. Since “you” don’t and are willing to buy a beer and not paying for the costs, we have to draw the line and say: “This board is supported and receive everything without asking, this is not and we don’t care to help even we could”. Day has only 24h.
Good luck.
Updated images with minor fixes, kernel bumped to 4.18.18 https://www.armbian.com/bananapi-m3/
Danke genau das habe ich gesucht!
thank you friend this is the best image
Does not work - I have kernel panic and restart over and over again - says that filesystem is missing
Yes, its a known problem but no time to fix.
@dfurmans That problem should be fixed.
Updated images:
Boot log: http://ix.io/25fC
Bump. Updated images.
Hello. How to increase the frequency of the CPU and GPU, how to install the Midnight commander… And even in Chromium, I can’t log in to my Google account.
