A83T Booting issues
(Sankar) #1
HI, We are using A83T in our project. We are trying to boot the system through battery. But the system hangs in the at one location. Please find the log below.
"new_power_status = 0
key pressed value=0x1
timeout, but no power key found
no key input
dram_para_set start
dram_para_set end
[     11.569]DRAM:  2 GiB
relocation Offset is: 75af7000"
Can you please help on this to solve the issues.
Thanks and Regards, Sankar.K
(Sankar) #2
Hi, Is any one can support the issues.
(ZB) #3
Hello, could you please tell me which image did you use?
Did you use M3?
(Wing Tiger) #4
I suspect that power is not enough. A83t moody and very hot
(Sankar) #5
Hi, The issues is solved. Power was not enough. Thanks
