3D designed case for R2
(Frank W.) #21
some small infos:
  • under the bpi-R2 you can install no 9.5mm HDD, but a smaller SSD (7.5mm height)
  • i have mounted/glued my case wrong, depending on screwholes for the hdd (must be near the sd-card-block), will correct this in my construction-sheme
https://drive.google.com/open?id=1iOo8cNNdOz7Oj0ZhAfNTLlnJVUt2A0zM
(Felix) #22
Finally, got my 3D designed case printed. The board can be fitted into the case nicely with a ssd mounted at the bottom. There is another ssd mount space on the top cover of the case.
