Video gets recorded to SD-card but I can't access the live picture
Video gets recorded to SD-card but I can’t access the live Picture.
When I try to access the live Picture accessing rtsp://BPI-D1_IP in VLC I receive a Connection error.
main debug: adding item rtsp://10.10.10.155/' ( rtsp://10.10.10.155/ ) qt4 debug: Adding a new MRL to recent ones: rtsp://10.10.10.155/ main debug: meta ok for (null), need to fetch art main debug: processing request item: rtsp://10.10.10.155/, node: null, skip: 0 main debug: rebuilding array of current - root Wiedergabeliste main debug: rebuild done - 2 items, index 1 main debug: starting playback of the new playlist item main debug: resyncing on rtsp://10.10.10.155/ main debug: rtsp://10.10.10.155/ is at 1 main debug: creating new input thread main debug: Creating an input for 'rtsp://10.10.10.155/' main debug: looking for meta fetcher module matching "any": 1 candidates lua debug: Trying Lua scripts in C:\Users\hunti_000\AppData\Roaming\vlc\lua\meta\fetcher lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\fetcher lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac main debug: using meta fetcher module "lua" main debug: removing module "lua" main debug: searching art for rtsp://10.10.10.155/ main debug: looking for art finder module matching "any": 2 candidates main debug: using timeshift granularity of 50 MiB, in path 'C:\Users\HUNTI_~1\AppData\Local\Temp' main debug:rtsp://10.10.10.155/’ gives access rtsp' demux’ path 10.10.10.155/' main debug: creating demux: access='rtsp' demux='' location='10.10.10.155/' file='\\10.10.10.155\' lua debug: Trying Lua scripts in C:\Users\hunti_000\AppData\Roaming\vlc\lua\meta\art main debug: looking for access_demux module matching "rtsp": 12 candidates live555 debug: version 2014.05.27 lua debug: Trying Lua scripts in C:\Program Files\VideoLAN\VLC\lua\meta\art lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\01_googleimage.luac lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac lua debug: Trying Lua playlist script C:\Program Files\VideoLAN\VLC\lua\meta\art\03_lastfm.luac main debug: no art finder modules matched main debug: art not found for rtsp://10.10.10.155/ qt4 debug: IM: Setting an input live555 debug: connection error -10057 live555 error: Failed to connect with rtsp://10.10.10.155/ main debug: no access_demux modules matched main debug: creating access 'rtsp' location='10.10.10.155/', path='\\10.10.10.155\' main debug: looking for access module matching "rtsp": 20 candidates main debug: net: connecting to 10.10.10.155 port 554 main debug: connection succeeded (socket = 2300) access_realrtsp debug: rtsp connected access_realrtsp warning: only real/helix rtsp servers supported for now main debug: no access modules matched main error: open ofrtsp://10.10.10.155/’ failed main debug: dead input main debug: changing item without a request (current 1/2) main debug: nothing to play qt4 debug: IM: Deleting the input
Can anyone help me ?
Kind Regards angelspawn
1 check if the D1 works in AP mode 2 connect with D1 through wifi 3 then open VLC to connect if still not works, have a try on mobile phone
Thanks for your reply I got access again after I have connected in AP mode and resetting all settings in VLC.
