I’m currently working towards getting better performance from the graphics hardware - hardware scaling at least - but hopefully some X11 2D accelerations and GLES on the Mali 450 inside our device.
I’ve backported the latest (I could find) mtk-vcodec, mtk-jpeg mtk-mdp and mtk-vpu to 4.4.70. The code we had was old, broken and hard-coded for 64bit (v4l2 hasn’t changed much so it was just a few minor changes)
The mtk-vcodec-dec (for example) has loaded into the kernel without any problem along with all of the v4l2 dependant modules. I understand that its a v4l memory to memory decoder and ffmpeg as well as gstreamer apparently both support it.
“Video decoder, Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 high profile 1080p@60fps”
I assume that these drivers are for the decoder/encoder functionality?
No difference in video - doesn’t look like the hardware is getting used. 2D performance via fbdev is fine for straight blits - but there’s no hook for hardware scaling.
I’m using the sunxi fbturbo X11 driver now - performance is better than the stock fbdev - but still not good enough to scale video.
Surprisingly even in the unaccelerated state - without scaling the image, it plays back 720p very smoothly (changing resolution works fine on debian - not sure why it’s stuck to 1080p on the ubuntu image - not sure why anybody would use ubuntu)
I’m going to try writing an interface (drmmode) for xf86-video-armsoc - plugging it into the mediatek DRM driver - I’ll learn more and I might have some useful information for people at the end.
