Currently i don’t see your config i also don’t know which dhcp-server you use…
In my wiki you’ll instructions for configuring dnsmasq as dhcp-server. You have to bridge lan-ports or setup different config for each. Don’t forget to set static ip for bridge/lan-ports and the dhcp-range should match that config
# ifupdown has been replaced by netplan(5) on this system. See
# /etc/netplan for current configuration.
# To re-enable ifupdown on this system, you can run:
# sudo apt install ifupdown
auto lo
iface lo inet loopback
dns-nameservers 192.168.0.1
auto eth0
iface eth0 inet manual
pre-up ip link set $IFACE up
auto lan0
iface lan0 inet static
address 192.168.1.1
netmask 255.255.255.0
allow-hotplug eth1
auto eth1
iface eth1 inet dhcp
auto wan
iface wan inet dhcp
Since ethx is always connected auto ethx is the right one…allow hotplug is used for ports which may not be connected (to avoid waiting for intwrface on bootup)
