=> ttyS0: Read file text from JAVA
Hello,
Pls, I am trying to read dev/ttyS0 file and I’ll like store it into a string, but cannot find the right JAVA code from the web… Can anyone help me?
Arrghh, still can’t store file text to a string and set it as textview. Let me explain you that I want to do:
I have attached an Arduino to the M64 ttyS0 serial port. The Arduino gets temperature from sensor and sends by serial the temperature , I can see the dev/ttyS0 file is changing value correctly:
cat /dev/ttyS0
180
181
181
182 … (continue getting the data in a new line)
I am doing:
 public void start(View view) throws InterruptedException {
    Button empezar = (Button) findViewById(R.id.empezar);
    Process process = null;
    DataOutputStream dos = null;
    try
    process = Runtime.getRuntime().exec("su");
    dos = new DataOutputStream(process.getOutputStream());
    dos.writeBytes("exec 3</dev/ttyS0" + "\n"); //REDIRECT SERIAL OUTPUT TO FD 3.
    dos.flush(); // Enter???
    dos.writeBytes("cat <&3 > /sdcard/temperatura.txt & PID=$!" + "\n"); //REDIRECT SERIAL OUTPUT TO FILE
    dos.flush();
    dos.writeBytes("kill $PID" + "\n"); //KILL CAT PROCESS
    dos.flush();
    dos.writeBytes("exec 3<&-" + "\n"); // FREE FD 3
    dos.flush();
    dos.close();
   } catch (IOException gpio) {
        gpio.printStackTrace();
And I am getting the serial data in a file named temperatura.txt in the external virtual storage main path.
Temperatura.txt contains integers, the content is:
185
186
187
188
189
190
190
191 … (continue getting data from /dev/ttyS0)
Then I tryed different methods to get the file text to String and the show it in a TextView
class LeeFichero {
public void main(String[] arg) {
    File archivo = null;
    FileReader fr = null;
    BufferedReader br = null;
    try {
        archivo = new File (Environment.getExternalStorageDirectory().getPath(), "temperatura.txt");
        fr = new FileReader (archivo);
        br = new BufferedReader(fr);
        // File read
        String linea = br.readLine();
        while((linea=br.readLine())!=null)
    // Write string to the textView
            TextView temperatura = (TextView)findViewById(R.id.temperatura);
            temperatura.setText (linea);
    catch(Exception e){
        e.printStackTrace();
    }finally{
         try{
            if( null != fr ){
                fr.close();
        }catch (Exception e2){
            e2.printStackTrace();
But when I press the start Button, the TextView don’t show any data
I also tried to copy file
to
/data/data/myapkdirectory/files
and run the next code:
 try
        BufferedReader fin =
                new BufferedReader(
                        new InputStreamReader(
                                openFileInput("temperatura.txt")));
       String texto = fin.readLine();
        fin.close();
        TextView temp = (TextView)findViewById(R.id.temperatura);
        temp.setText((CharSequence) texto);
    catch (Exception ex)
        Log.e("Ficheros", "Error al leer fichero desde memoria interna");
      TextView temp = (TextView) findViewById(R.id.temperatura);
        temp.setText("texto");
Again, I can’t get the text file data in the TextView
Pls, any help Will be appreciated. How can I get ttyS0 data to a string and show it in a TextView correctly in JAVA? Or I am in the wrong way???
Hello, more advances:
I can see if that I do " cat /dev/ttyS0 > data/data/myapkpackage/files/temp.txt" ,then I get a file named temp.txt in my apk files directory, but I can´t set it to a TextView with:
  try
    new BufferedReader(
            openFileInput("temp.txt")));
String text = fin.readLine();
fin.close();
TextView temperature = (TextView)findViewById(R.id.tvtemp);
temperature.setText("text");
} catch (Exception ex) { Log.e(“Files”, “Error reading internal memory”); }
IMPORTANT If I edit the temp.txt in the data/data/myapk/files folder with a text editor (manually) and then save , and run the java code again, the temp.txt content will be displayed in the TextView without any problem.
IMPORTANT2 Also, if I try to create and write the file temp.txt with this code:
try
OutputStreamWriter fout=
    new OutputStreamWriter(
        openFileOutput("temp.txt", Context.MODE_PRIVATE)); //  also works OK with MODE_APPEND
fout.write("Testing Reading test.");
fout.close();
Log.e("Ficheros", "Error al escribir fichero a memoria interna");
And then I run again the “file Reading from internal memory” JAVA code:
try
    new BufferedReader(
fin.close();
Log.e("Files", "Error reading internal memory");
Why cat /dev/ttyS0 > data/data/myapkpackage/files/temp.txt don´t créate a valid .txt file? How solve it>?
