TOSHIBA MK8032GSX 80 GB 2.5" - how to make it work with Banana Pi - what do i need else
(say_hello) #1
hello dear community,
i have a hdd from a notebook that i do not need any more - so i took the hdd.
i want to use it in combination with Banana Pi it is a TOSHIBA MK8032GSX 80 GB 2.5" 5400 RPM 8 MB SATA Laptop Hard Disk Drive HDD
well i need some adaptors that can help here - in order to make the things working . what do i need to have here!`?
does this here help: https://www.netzwerkartikel.de/onlineshop/Kabel/SATA-SATA-Stromkabel-IN29695B/29695B-index.htm?gclid=EAIaIQobChMI2f2Hzdy03AIVGKmWCh1tqAHpEAQYAiABEgI4A_D_BwE
InLine SATA Anschlusskabel für Banana Pi, mit Daten- und Stromanschluss, 0,35m SATA Kabel - InLine Kabel SATA Anschlusskabel, zum Verbinden von SATA Laufwerken mit dem Banana Pi Microcomputer mit Daten- und Stromanschluss Länge ca. 0,35m SATA Kabel 0,35 Meter SATA Stromkabel - InLine
Abbildung: InLine SATA Anschlusskabel für Banana Pi, mit Daten- und Stromanschluss, 0,35m
love to hear from you
(ZB) #2
Hello, this is my adapter,Sata --> data + power
You could find more infos in wiki:
http://wiki.banana-pi.org/Getting_Started_with_M2_Ultra_/_Berry#SATA
(Silvy Rivers) #3
Yes, you need this cable (from ALLNET). With a regular power adaptor (5V 2A), you can use it with an SSD-drive. A regular power adaptor is probably not strong enough to power the banana pi AND the HDD you want to use. To make it work, I use a 5V 3A power switch that powers the banana pi and the HDD as in the picture below.HDD_Connect
The red and black cable are cut and connected to the power switch. The banana pi is powered by the power connector that is intended for the SATA-Drive. Make sure the red cables are connected to +V of the power switch, the black cables to -V
Hope this helps.
