BananaPi BPI-M3 New Image (New Emmc) Ubuntu16.04 & Debian9 Release 2018-07-18
Hi I’m facing a problem with touch module (HC070TG38035). I have tried this module with BPI M1 and M64 boards, touch is detected but not corrected calibrated. I have used ubuntu desktop 16.04 image in both cases, getting the same result. Could you help me with this issue?
I have opened a new post: BPI M1 and BPI LCD 7" (HC070TG38035)
Did you have other board? Both M1 and M64 have this problem right?
Hi Jack.
Yes both have this problem. I don’t have another board.
Thank you.
Hi.
LCD module finally works with BPI M64 board!!! We updated drivers from https://github.com/BPI-SINOVOIP/BPI-M64-bsp and used gt9xxnew_ts.
Thanks for your help.
Can somebody help, Im using mipi display is it enough to connect only 4 mipi data lines(positive and negative) and clock line(positive and negative). I dont need touch interface. Display is hsd088ipw1-a. I have all voltages necessary for display.
Hi all, I got trouble to use the M3 as an NFS 4 client with the recent debian image. I always get a null pointer dereference. Does anybody know how to solve this?
[   54.333510] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[   54.333551] pgd = e35c8000
[   54.333574] [00000000] *pgd=00000000
[   54.333622] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[   54.343109] Modules linked in: bcmdhd ft5x_ts sunxi_ir_rx vfe_v4l2 videobuf_dma_contig videobuf_core ov5640 cci vfe_subdev vfe_os pvrsrvkm(O) option usb_wwan spidev ip_tables x_tables
[   54.343109] CPU: 0    Tainted: G           O  (3.4.39-BPI-M3-Kernel #3)
[   54.343109] PC is at nfs4_init_client+0xd8/0x124
[   54.343109] LR is at nfs_idmap_new+0xf4/0x11c
Thank You Very Much
Chromium not worked!!
How to run mysql or mariaDB on BPI M3 Debian?
I’m angry!!! :face_with_symbols_over_mouth:
It seems that this is not possible!
This is the worst board!
This is the worst core!
This is rubbish!
I also did not solve this problem :frowning:
sorry for this, let me check please.
if possible, please make a debian server. Many do not need a desktop
3 month BPI M3 works. And now this:
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p1 does not exist. Dropping to a shell!
Rebooting automatically due to panic= boot argument
sorry for late reply, I will release one soon.
hello, could you please descrip more detail for this?
Where is your wiki ? I wanna build Kernel 5.0.X for Banana Pi M3 …
Hello,please check here:http://wiki.banana-pi.org/Getting_Started_with_M3
I have built linux from https://github.com/BPI-SINOVOIP/BPI-M3-bsp/tree/master/linux-sunxi and replaced uImage from existing 2018-07-11-ubuntu-16.04-mate-desktop-preview-bpi-m3-sd-emmc.img BSP. but it stop booting after.
Booting kernel from Legacy Image at 48000000 …
Image Name: Linux-3.4.39-BPI-M3-Kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 7015064 Bytes = 6.7 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum … OK
Loading init Ramdisk from Legacy Image at 43100000 …
Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5161148 Bytes = 4.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum … OK Loading Kernel Image … OK OK [ 16.291][mmc]: MMC Device 2 not found [ 16.294][mmc]: mmc not find,so not exit [ 16.299] Starting kernel …
[sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 2048MB
ion_carveout reserve: 96m 128m
ion_reserve_common: ion reserve: [0xb8000000, 0xc0000000]!
ion_cma reserve: 120m 176m 512m
ion_reserve_common: ion reserve: [0xa0000000, 0xc0000000]!
------sun8i_smp_init_ops----37-----
Any help on this issue?
Hi. I am a new user M3. I use Debian. When i update packers list, there is an inscription that some repositories are not available. My next action should be left in the list only in the official repository Debian. then I use the command “aptitude safe-upgrade” in the end, I get a login at login, idle Synaptic, does not see the flash drive. i can’t fix it(new to Linux). Bought m3 to use this program on it: https://planet-cnc.com/software/ Can the program work on this computer? And how to update packages?
Hello!
i have the problem i installed the debian server and the default root password is not available. What’s the password? because for me, 1234 doesn’t work. thank you in advance for your help.
