The Rails Port from GitHub - Installation Error
(JesseVoss) #1
Could you give some advise what I do wrong? I have got blank Ubuntu server 12.04.3 and try to install The Rails follow by Install.md from GitHub. When I reach step with this command: $sudo bundle exec rake db:create I have recieved error: Couldn’t create database for {“adapter”=>“postgresql”, “encoding”=>“unicode”, … and so on… In Google search I have found recomendation like - put host: localhost and port: 5432 in config/database.yml. In my case it does not work. Have you any other advise or hints?
Any help will be apprecited.
I didn’t find the right solution from the Internet.
References:
https://forum.openstreetmap.org/viewtopic.php?id=22919
Animated Explainer Video Company
Thank you.
