The camera/Image Sensor (Omnivision 5640 CMOS) is not working Banana PI m2
The camera/Image Sensor (Omnivision 5640 CMOS) which works with Banana PI m1 (with Android 4.2 OS), is not working Banana PI m2 which also uses Android 4.2 OS.
Can someone help me with this issue?
I’ve already checked the related connections and the camera, which has no problems.
we will update soon , we have fixed this issue ,new image will support . waitting a moment.
The camera/Image Sensor OV5640 is not working Banana PI m2 which also uses Android 4.4 OS. When will new image support?
on M2 ,support it .please check your setting.
Where is the new android version? Is the update was done on the same version of the android? In the old version did not see the camera.
The camera/Image Sensor (Omnivision 5640 CMOS) is not working Banana PI m2 which also uses Android version 4.0 HDMI release date 2/8/2015. The problem would be fixed in the new version .
Can you help me? Is this issue related to a change made ​​in the new version ?
we do this test now, please just wait , once we have OK, i will let you konw.
I am waiting, thank you…
