Sys-config for Banana pi BPI-M1 BPI-M1+
share by hange
I tried to modify a sys-config (refer bpi-config) for BananaPro. The main menu: “1 Boot to Desktop/Console/Scratch” “Choose whether to boot to desktop, Scratch, or the command-line” “2 Internationalisation Options” “Set up language and regional settings to match your location” “3 Change User Password” “Change the password for the default user(lemaker)” “4 Expand Filesystem” “Ensures that all of the SD card storage is available to the OS” “5 Set Swap Space” “Enable/Disable the swap space” “6 Set Hostname” “Set the visible name for this board on a network” “7 Remote Access” “Enable/Disable remote command line access to your board using SSH” “8 Advance Options” “Configure advanced settings” “9 About sys-config” “Information about this configuration tool”
You can configure the display output from HDMI,LCD and AV(but need tools fex2bin and bin2fex). Choose boot desktop or command-line (lubuntu not work, don’t know how to do ;( ). The script is not perfect, please take a look at how to improve it. :wink:
#!/bin/sh
# Copyright (C) 2015 LeMaker Community <[email protected]>
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#       http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
DEFUSER=bananapi
UID=`id -u`
SCRIPTNAME=$(basename $0)
IS_PLATFORM=$(grep -i "hardware" /proc/cpuinfo | sed s/[[:space:]]//g | cut -d: -f2)
HEIGHT=20
WIDTH=108
DISKNAME=mmcblk0
REBOOT_FLAG=0
if [ $UID -ne 0 ];then
        echo "Please run the $SCRIPTNAME with root."
        exit
fi
enable_boot_to_scratch() {
        if [ -e /etc/profile.d/boottoscratch.sh ]; then
                printf "/etc/profile.d/boottoscratch.sh exists, so assuming boot to scratch enabled\n"
                return 0;
        fi
        sed -i /etc/inittab -e "s|^\(1:2345.*getty.*tty1.*\)|\
#\1 # BTS_TO_ENABLE\n1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>\&1 # BTS_TO_DISABLE|"
cat <<-EOF > /etc/profile.d/boottoscratch.sh
#!/bin/sh
# Part of bpi-config http://github.com/LeMaker/bpi-config
# See LICENSE file for copyright and license details
# Should be installed to /etc/profile.d/boottoscratch.sh to force scratch to run upon boot
# You may also want to set automatic login in /etc/inittab on tty1 by adding a
# line such as the following (bpi-config does this for you):
# 1:2345:respawn:/bin/login -f bananapi tty1 </dev/tty1 >/dev/tty1 2>&1 # BTS_TO_DISABLE
if [ $(tty) = "/dev/tty1" ]; then
  printf "openbox --config-file /home/pi/boottoscratch/openbox_rc.xml & scratch" | xinit /dev/stdin
  printf "\n\n\nShutting down in 5 seconds, hit ctrl-C to cancel\n" && sleep 5 && sudo shutdown -h now
fi
EOF
  mkdir -p /home/bananapi/boottoscratch
  cat <<-EOF > /home/bananapi/boottoscratch/openbox_rc.xml
<?xml version="1.0" encoding="UTF-8"?>
<openbox_config xmlns="http://openbox.org/3.4/rc"
    xmlns:xi="http://www.w3.org/2001/XInclude">
<applications>
  <application name="squeak" type="normal">
    <focus>yes</focus>
    <fullscreen>yes</fullscreen>
  </application>
</applications>
</openbox_config>
EOF
  telinit q
disable_boot_to_scratch() {
    rm -f /etc/profile.d/boottoscratch.sh
    sed -i /etc/inittab \
      -e "s/^#\(.*\)#\s*BTS_TO_ENABLE\s*/\1/" \
      -e "/#\s*BTS_TO_DISABLE/d"
    telinit q
  fi
set_boot_method()
        BOOTOPTS=$(whiptail --title "Enable Boot to Desktop/Console/Scratch" --menu "Choose the method to boot" --ok-button "Select" --cancel-button "Exit" $HEIGHT $WIDTH 3 \
        "<Desktop>" "Start the system with the X11 window" \
          "<Console>" "Start the system with Console terminal" \
        "<Scratch>" "Start the system with the Scratch Application" \
        3>&1 1>&2 2>&3)
        if [ $? -eq 0 ];then
                case $BOOTOPTS in
                 "<Desktop>")
                        if [ -e /etc/init.d/lightdm ]; then
                          if id -u bananapi > /dev/null 2>&1; then
                                update-rc.d lightdm enable 2
                                sed /etc/lightdm/lightdm.conf -i -e "s/^#autologin-user=.*/autologin-user=bananapi/"
                          else
                                whiptail --msgbox "The pi user has been removed, can't set up boot to desktop" 20 60 2
                          fi
                        else
                          whiptail --msgbox "Do sudo apt-get install lightdm to allow configuration of boot to desktop" 20 60 2
                          return 1
        fi
                "<Console>")
                        [ -e /etc/init.d/lightdm ] && update-rc.d lightdm disable 2
                "<Scratch>")
                        if [ -e /usr/bin/scratch ]; then
                                else
                                        whiptail --msgbox "The bananapi user has been removed, can't set up boot to scratch" 20 60 2
                                fi
                        else
                                whiptail --msgbox "Do sudo apt-get install scratch to allow configuration of boot to scratch" 20 60 2
                        fi
                        whiptail --msgbox "Programmer error, unrecognised boot option" 20 60 2
                        return 1
                esac
                whiptail --title "Boot to the $BOOTOPTS" --msgbox "You have already set to boot system from the $BOOTOPTS, Choose Ok to continue" $HEIGHT $WIDTH
                REBOOT_FLAG=1
        fi
set_system_env()
        if(whiptail --title "Internationalisation Options" --yesno "Change the Locale, Choose Ok to continue." --yes-button "Ok" --no-button "Cancel" $HEIGHT $WIDTH)then
                dpkg-reconfigure locales
        fi
        if(whiptail --title "Internationalisation Options" --yesno "Change the TimeZone, Choose Ok to continue." --yes-button "Ok" --no-button "Cancel" $HEIGHT $WIDTH)then
                dpkg-reconfigure tzdata
        fi
        if(whiptail --title "Internationalisation Options" --yesno "Change the Keyboard Layout, Choose Ok to continue." --yes-button "Ok" --no-button "Cancel" $HEIGHT $WIDTH)then
                dpkg-reconfigure keyboard-configuration
                        #if [ $? -eq 0 ];then
                        #        systemctl restart keyboard-setup.service > /dev/null 2>&1
                        #fi
        fi
set_user_pwd()
        if(whiptail --title "Change the user(bananapi) password" --yesno "Would you like to reset password for the default user ?" --yes-button "Ok" --no-button "Cancel" $HEIGHT $WIDTH)then
                TMPOUT=`cat /etc/passwd | grep -i "$DEFUSER"`
                if [ "$TMPOUT" != "" ];then
                        passwd $DEFUSER
                                whiptail --title "Change the user(bananapi) password" --msgbox "Change the user password successful!" $HEIGHT $WIDTH
                        else
                                whiptail --title "Change the user(bananapi) password" --msgbox "Change the user password failed!" $HEIGHT $WIDTH
                        fi
                else
                        whiptail --title "Change the user(bananapi) password" --msgbox "The default user is not exist!" $HEIGHT $WIDTH
                fi
        fi
expand_filesystem()
        if(whiptail --title "Expand the filesystem" --yesno "Would you like to expand the filesystem ?" --yes-button "Ok" --no-button "Cancel" $HEIGHT $WIDTH)then
                ls -l /dev/$DISKNAME > /dev/null 2>&1
                        ENDPART=`ls -l /dev/${DISKNAME}* | wc -l` &&  ENDPART=$(($ENDPART-1))
                        STARTNUM=$(fdisk -l | grep /dev/${DISKNAME}p${ENDPART} | awk '{print $2}')
                          fdisk /dev/$DISKNAME <<-END
                        p
                        d
                        $ENDPART
                        n
                        p
                        $ENDPART
                        $STARTNUM
                        w
                        END
                fi
        fi
        cat <<-EOF > /etc/init.d/resize2fs_once
        resize2fs /dev/${DISKNAME}p${ENDPART}
        sudo rm -f /etc/init.d/resize2fs_once
        EOF
        chmod +x /etc/init.d/resize2fs_once &&
        cat <<-EOF > /etc/rc.local
        #!/bin/sh -e
        # rc.local
        # This script is executed at the end of each multiuser runlevel.
        # Make sure that the script will "exit 0" on success or any other
        # value on error.
        # In order to enable or disable this script just change the execution
        # bits.
        # By default this script does nothing.
        if [ -e /etc/init.d/resize2fs_once ];then
                sudo /etc/init.d/resize2fs_once
        fi
        exit 0
        EOF
        whiptail --title "Expand the filesystem" --msgbox "The filesystem has been expanded.\nThe filesystem will be enlarged upon the next reboot" $HEIGHT $WIDTH
        REBOOT_FLAG=1
set_swap_space()
        TMPOUT=`cat /etc/fstab | grep swap`
        if(whiptail --title "Set swap space" --yesno "Please choose the button below to enable or disable the swap space." --yes-button "Enable" --no-button "Disable" $HEIGHT $WIDTH)then
                        whiptail --title "Set swap space" --msgbox "The swap space has been enabled." $HEIGHT $WIDTH
                else
                        dd if=/dev/zero of=/var/swap bs=1M count=256 &&
                        mkswap /var/swap &&
                        swapon /var/swap &&
                        echo "/var/swap\tswap\tswap\tdefault \t0\t0" >> /etc/fstab &&
                        whiptail --title "Set swap space" --msgbox "Enable the swap space successful. Choose the Ok to continue." $HEIGHT $WIDTH ||
                        whiptail --title "Set swap space" --msgbox "Enable the swap space failed. Choose the Ok to continue." $HEIGHT $WIDTH
                fi
        else
                        sed -i "/swap/d" /etc/fstab &&
                        swapoff /var/swap &&
                         rm -rf /var/swap &&
                        whiptail --title "Set swap space" --msgbox "Disable the swap space successful.Choose the Ok to continue." $HEIGHT $WIDTH ||
                        whiptail --title "Set swap space" --msgbox "Disable the swap space failed. Choose the Ok to continue." $HEIGHT $WIDTH
                else
                        whiptail --title "Set swap space" --msgbox "The swap space has been disabled." $HEIGHT $WIDTH
                fi
        fi
adjust_cpu_freq_sun7i()
        COPTS=$(whiptail --title "OverClock" --menu "Choose the cpufreq below" --ok-button "Select" --cancel-button "Exit" $HEIGHT $WIDTH 3 \
        "<Modest>" "800MHz ARM (Low preformance)" \
        "<Medium>" "1000MHz ARM (Default value)" \
        "<High>" "1200MHz ARM (Duty of care)" \
        3>&1 1>&2 2>&3)
                case $COPTS in
                "<Modest>")
                        #!/bin/sh -e
                        # rc.local
                        # value on error.
                        # bits.
                        echo 25 >  /sys/devices/system/cpu/cpufreq/ondemand/up_threshold
                        echo 10 >  /sys/devices/system/cpu/cpufreq/ondemand/sampling_down_factor
                        echo 300000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
                        echo 800000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
                        exit 0
                        EOF
                "<Medium>")
                        #!/bin/sh -e
                        # rc.local
                        # value on error.
                        # bits.
                        echo 1008000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
                        exit 0
                        EOF
                "<High>")
                        #!/bin/sh -e
                        # rc.local
                        # value on error.
                        # bits.
                        echo 1200000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
                        exit 0
                        EOF
                esac
                chmod +x /etc/rc.local
                whiptail --title "OverClock" --msgbox "You have already re-adjusted the CPU frequency, Choose Ok to continue." $HEIGHT $WIDTH
        fi
set_display_output_sun7i()
        DOPTS=$(whiptail --title "Set Display Output" --menu "Choose the display output type below" $HEIGHT $WIDTH 5 \
        "<HDMI>" "Set the display output to the HDMI" \
        "<AV>" "Set the display output to the AV" \
        "<7-LCD>" "Set the display output to the 7 LCD" \
        "<5-LCD>" "Set the display output to the 5 LCD" \
        "<3.5-LCD>" "Set the display output to the 3.5 LCD" \
        3>&1 1>&2 2>&3)
                mount /dev/mmcblk0p1 /boot  &&
                bin2fex /boot/script.bin /boot/script.fex  > /dev/null 2>&1
                if [ $? -ne 0 ];then
                        whiptail --title "Set Display Output" --msgbox "Failed to Convert the bin to fex file, Please check the reasons below: \
                                        1.Repeat mounted partition /dev/mmcblk0p1 to /boot \
                                          \n2.The bin2fex command doesn't exist." 20 85
                        return
                fi
                LCD0_AREA_START=$(grep -n "lcd0_para" /boot/script.fex | cut -d: -f1)
                LCD0_AREA_END=$(grep -n "lcd1_para" /boot/script.fex | cut -d: -f1)
                case $DOPTS in
                        "<HDMI>")
                                sed -i -e "s/lcd_used.*/lcd_used = 0/g" \
                                   -e "s/screen0_output_type.*/screen0_output_type = 3/g" \
                                   -e "s/screen0_output_mode.*/screen0_output_mode = 4/g" /boot/script.fex
                        "<AV>")
                                   -e "s/screen0_output_type.*/screen0_output_type = 2/g" \
                                   -e "s/screen0_output_mode.*/screen0_output_mode = 11/g" /boot/script.fex
                        "<7-LCD>")
                sed -i  -e "s/screen0_output_type.*/screen0_output_type = 1/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_used.*/lcd_used = 1/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_x.*/lcd_x = 1024/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_y.*/lcd_y = 600/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_pwm_freq.*/lcd_pwm_freq = 22000/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_dclk_freq.*/lcd_dclk_freq = 55/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_if.*/lcd_if = 3/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hbp.*/lcd_hbp = 150/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_ht.*/lcd_ht = 1344/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vbp.*/lcd_vbp = 20/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vt.*/lcd_vt = 1270/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vspw.*/lcd_vspw = 10/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hspw.*/lcd_hspw = 50/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_lvds_bitwidth.*/lcd_lvds_bitwidth = 0/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_bl_en[ =].*/lcd_bl_en = port:PH08<1><0><default><1>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_power[ =].*/lcd_power = port:PH12<1><0><default><1>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd0[ =].*/lcdd0 = port:PD00<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd1[ =].*/lcdd1 = port:PD01<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd2[ =].*/lcdd2 = port:PD02<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd3[ =].*/lcdd3 = port:PD03<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd4[ =].*/lcdd4 = port:PD04<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd5[ =].*/lcdd5 = port:PD05<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd6[ =].*/lcdd6 = port:PD06<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd7[ =].*/lcdd7 = port:PD07<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd8[ =].*/lcdd8 = port:PD08<3><0><default><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd9[ =].*/lcdd9 = port:PD09<3><0><default><default>/g" \
                                        -e "s/ctp_used.*/ctp_used = 1/g" \
                                        -e "s/ctp_name.*/ctp_name = \"ft5x_ts\"/g" \
                                        -e "s/ctp_screen_max_x.*/ctp_screen_max_x = 1024/g" \
                                        -e "s/ctp_screen_max_y.*/ctp_screen_max_y = 600/g" \
                                        -e "s/ctp_det_used.*/ctp_det_used = 1/g" \
                                        -e "s/^ft5x_ts.*/ft5x_ts = 1/g"  /boot/script.fex
                        "<5-LCD>")
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_x.*/lcd_x = 800/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_y.*/lcd_y = 480/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_dclk_freq.*/lcd_dclk_freq = 30/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_if.*/lcd_if = 0/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hbp.*/lcd_hbp = 88/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_ht.*/lcd_ht = 928/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vbp.*/lcd_vbp = 32/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vt.*/lcd_vt = 1050/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vspw.*/lcd_vspw = 3/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hspw.*/lcd_hspw = 48/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hv_if.*/lcd_hv_if = 0/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd0[ =].*/lcdd0 = port:PD00<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd1[ =].*/lcdd1 = port:PD01<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd2[ =].*/lcdd2 = port:PD02<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd3[ =].*/lcdd3 = port:PD03<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd4[ =].*/lcdd4 = port:PD04<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd5[ =].*/lcdd5 = port:PD05<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd6[ =].*/lcdd6 = port:PD06<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd7[ =].*/lcdd7 = port:PD07<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd8[ =].*/lcdd8 = port:PD08<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd9[ =].*/lcdd9 = port:PD09<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd10[ =].*/lcdd10 = port:PD10<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd11[ =].*/lcdd11 = port:PD11<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd12[ =].*/lcdd12 = port:PD12<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd13[ =].*/lcdd13 = port:PD13<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd14[ =].*/lcdd14 = port:PD14<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd15[ =].*/lcdd15 = port:PD15<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd16[ =].*/lcdd16 = port:PD16<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd17[ =].*/lcdd17 = port:PD17<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd18[ =].*/lcdd18 = port:PD18<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd19[ =].*/lcdd19 = port:PD19<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd20[ =].*/lcdd20 = port:PD20<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd21[ =].*/lcdd21 = port:PD21<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd22[ =].*/lcdd22 = port:PD22<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdd23[ =].*/lcdd23 = port:PD23<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdclk[ =].*/lcdclk = port:PD24<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdde[ =].*/lcdde = port:PD25<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdhsync[ =].*/lcdhsync = port:PD26<2><0><3><default>/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdvsync[ =].*/lcdvsync = port:PD27<2><0><3><default>/g" \
                                        -e "s/ctp_screen_max_x.*/ctp_screen_max_x = 800/g" \
                                        -e "s/ctp_screen_max_y.*/ctp_screen_max_y = 480/g" \
                        "<3.5-LCD>")
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_x.*/lcd_x = 320/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_y.*/lcd_y = 240/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_dclk_freq.*/lcd_dclk_freq = 7/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hbp.*/lcd_hbp = 68/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_ht.*/lcd_ht = 408/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vbp.*/lcd_vbp = 18/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_vt.*/lcd_vt = 524/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcd_hspw.*/lcd_hspw = 30/g" \
                                        -e "${LCD0_AREA_START},${LCD0_AREA_END}s/lcdde[ =].*/lcdde = port:PD25<1><0><3><0>/g" \
                                        -e "s/ctp_screen_max_x.*/ctp_screen_max_x = 320/g" \
                                        -e "s/ctp_screen_max_y.*/ctp_screen_max_y = 240/g" \
                esac
                fex2bin /boot/script.fex /boot/script.bin  > /dev/null 2>&1
                sync
                umount /boot
                whiptail --title "Set Display Output" --msgbox "Set Display output type to the $DOPTS, Choose the Ok to continue." $HEIGHT $WIDTH
        fi
set_video_Acce_sunxi()
        if(whiptail --title "Video Acceleration" --yesno "Please choose the button below to enable or disable the Video Acceleration" --yes-button "Enable" --no-button "Disable" $HEIGHT $WIDTH)then
                if [ ! -f  /usr/share/X11/xorg.conf.d/99-fbturbo-sunxi.conf ];then
                        touch /usr/share/X11/xorg.conf.d/99-fbturbo-sunxi.conf
                fi
                cat <<-END > /usr/share/X11/xorg.conf.d/99-fbturbo-sunxi.conf
                Section "Screen"
                Identifier      "My Screen"
                Device          "Allwinner A10/A13 FBDEV"
                Monitor         "My Monitor"
                EndSection
                Section "Device"
                Identifier      "Allwinner A10/A13 FBDEV"
                Driver          "fbturbo"
                Option          "fbdev" "/dev/fb0"
                Option          "SwapbuffersWait" "true"
                Option          "AccelMethod" "G2D"
                EndSection
                Section "Monitor"
                Identifier      "My Monitor"
                Option          "DPMS" "false"
                EndSection
                END
                if [ ! -f /etc/modules-load.d/mali-sunxi.conf ];then
                        touch /etc/modules-load.d/mali-sunxi.conf
                fi
                cat <<-END > /etc/modules-load.d/mali-sunxi.conf
                ump
                mali
                mali_drm
                END
        else
                if [ -f /usr/share/X11/xorg.conf.d/99-fbturbo-sunxi.conf ];then
                        rm -f /usr/share/X11/xorg.conf.d/99-fbturbo-sunxi.conf
                fi
                if [ -f /etc/modules-load.d/mali-sunxi.conf ];then
                        rm -f /etc/modules-load.d/mali-sunxi.conf
                fi
        fi
set_hostname()
        whiptail --msgbox "Please note: RFCs mandate that a hostname's labels may contain only the
ASCII letters 'a' through 'z' (case-insensitive), the digits '0' through
'9',and the hyphen.Hostname labels cannot begin or end with a hyphen.
No other symbols, punctuation characters, or blank spaces are permitted." 20 80
        CURRENT_HOSTNAME=`cat /etc/hostname | tr -d " \t\n\r"`
        NEW_HOSTNAME=$(whiptail --inputbox "Please enter a hostname" 20 60 "$CURRENT_HOSTNAME" 3>&1 1>&2 2>&3)
                echo $NEW_HOSTNAME > /etc/hostname
                sed -i "s/127.0.0.1.*${CURRENT_HOSTNAME}/127.0.0.1\t${NEW_HOSTNAME}/g" /etc/hosts
                REBOOT_FLAG=1
        fi
set_sshd()
        if(whiptail --title "Set sshd service" --yesno "Please choose the button below to enable or disable the sshd service" --yes-button "Enable" --no-button "Disable" $HEIGHT $WIDTH)then
                sed -i '/start on runlevel/s/^#//' /etc/init/ssh.conf
        else
                sed -i '/start on runlevel/s/^/#/' /etc/init/ssh.conf
        fi
        REBOOT_FLAG=1
set_adv_opts()
        while true
        do
                AOPTS=$(whiptail --title "Advance Options" --menu "Setup Advance Options" --ok-button "Select" --cancel-button "Exit" $HEIGHT $WIDTH 4 \
                "A1 Display Output" "Configure the display output from HDMI,LCD and AV" \
                "A2 Video Acceleration" "Enable the Hardware Acceleration For X11, Improve the efficiency of decoding" \
                "A3 Overclock" "Configure overclocking for your Board" \
                3>&1 1>&2 2>&3)
                        case $AOPTS in
                        A1\ *)
                                if [ "$IS_PLATFORM" = "sun7i" ];then
                                else
                                fi
                        A2\ *)
                                else
                                fi
                        A3\ *)
                                whiptail --title "OverClock" --msgbox "Be aware that overclocking may reduce the lifetime of your Board. If \
                                        overclocking at a certain level causes system instability, try a more modest \
                                        overclock. Hold down shift during boot to temporarily disable overclock." 20 80
                                else
                                fi
                        esac
                        REBOOT_FLAG=1
                else
                        break;
                fi
        done
readme_about_tool()
        whiptail --title "About the sys-config" --msgbox "This tool provides a straight-forward way of doing initial configuration of the system. Although it can be run at any time, some of the options may have difficulties if you have heavily customised your installation. If you encounter a bug about using the sys-config, please report the bug to  http://bugs.lemaker.org." 20 80
#=================================Start Run======================================
while true
do
        MOPTS=$(whiptail --title "System Configuration Tool (sys-config)" --menu "Setup Options" --ok-button "Select" --cancel-button "Exit" $HEIGHT $WIDTH 9 \
        "1 Boot to Desktop/Console/Scratch" "Choose whether to boot to desktop, Scratch, or the command-line" \
        "2 Internationalisation Options" "Set up language and regional settings to match your location" \
        "3 Change User Password" "Change the password for the default user(lemaker)" \
          "4 Expand Filesystem" "Ensures that all of the SD card storage is available to the OS" \
        "5 Set Swap Space" "Enable/Disable the swap space" \
        "6 Set Hostname" "Set the visible name for this board on a network" \
    "7 Remote Access" "Enable/Disable remote command line access to your board using SSH" \
        "8 Advance Options" "Configure advanced settings" \
        "9 About sys-config" "Information about this configuration tool" \
        3>&1 1>&2 2>&3)
            case $MOPTS in
                  1\ *) set_boot_method ;;
                2\ *) set_system_env ;;
                3\ *) set_user_pwd ;;
                4\ *) expand_filesystem ;;
                5\ *) set_swap_space ;;
                6\ *) set_hostname ;;
                7\ *) set_sshd ;;
                8\ *) set_adv_opts ;;
                9\ *) readme_about_tool ;;
            esac
        else
                if [ "$REBOOT_FLAG" -eq 1 ];then
                        if(whiptail --title "Reboot The System"  --yesno "Would you like to reboot the system ?" $HEIGHT $WIDTH)then
                                sync
                                reboot
                        else
                                break;
                        fi
                fi
                break;
        fi
done
Link: http://www.lemaker.org/thread-17126-1-1.html
