[SOLVED] Loop Reboot on M3 with EMMC and some SD images
Hi everyone!
I’m trying to install many images on the M3 without success.
The only one that worked was the “raspian lite” on the SD Card.
The other images are looping reboot with the output:
819 [ 4.016941] get sysconfig para erro! 820 [ 4.022326] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0718 821 [ 4.022334] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2 822 [ 4.022341] usb 1-1.1: Product: USB Storage 823 [ 4.022346] usb 1-1.1: SerialNumber: 000000000033 824 [ 4.058390] get sysconfig para erro! 825 [ 4.058672] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 826 [ 4.059890] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 827 [ 4.061449] [mmc]: sdc0 fail to get regulator 828 [ 4.061455] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 829 [ 4.080044] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 830 [ 4.100855] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 831 [ 4.101701] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 832 [ 4.101728] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 833 [ 4.104207] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 834 [ 4.106105] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! 835 [ 4.106128] Try sdio 836 [ 4.106943] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 837 [ 4.107773] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 838 [ 4.108603] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 839 [ 4.109433] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 840 [ 4.109455] *******************Try sd ******************* 841 [ 4.110273] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 842 [ 4.111105] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 843 [ 4.111935] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 844 [ 4.112765] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 845 [ 4.112789] Try mmc 846 [ 4.112797] [mmc]: sdc0 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 847 [ 4.113693] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! 848 [ 4.113720] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 849 [ 4.113829] [mmc]: sdc0 fail to get regulator 850 [ 4.113834] [mmc]: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail 851 [ 4.116408] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 852 [ 4.117940] [mmc]: sdc0 fail to get regulator 853 [ 4.117945] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 854 [ 4.130042] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 855 [ 4.151112] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 856 [ 4.152211] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 857 [ 4.152236] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 858 [ 4.154841] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 859 [ 4.157019] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! 860 [ 4.157042] Try sdio 861 [ 4.158125] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 862 [ 4.159226] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 863 [ 4.160326] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !!
819 [ 4.016941] get sysconfig para erro! 820 [ 4.022326] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0718 821 [ 4.022334] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2 822 [ 4.022341] usb 1-1.1: Product: USB Storage 823 [ 4.022346] usb 1-1.1: SerialNumber: 000000000033 824 [ 4.058390] get sysconfig para erro! 825 [ 4.058672] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 826 [ 4.059890] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 827 [ 4.061449] [mmc]: sdc0 fail to get regulator 828 [ 4.061455] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 829 [ 4.080044] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 830 [ 4.100855] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 831 [ 4.101701] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 832 [ 4.101728] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 833 [ 4.104207] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 834 [ 4.106105] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! 835 [ 4.106128] Try sdio 836 [ 4.106943] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 837 [ 4.107773] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 838 [ 4.108603] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 839 [ 4.109433] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 840 [ 4.109455] *******************Try sd ******************* 841 [ 4.110273] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 842 [ 4.111105] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 843 [ 4.111935] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 844 [ 4.112765] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 845 [ 4.112789] Try mmc 846 [ 4.112797] [mmc]: sdc0 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 847 [ 4.113693] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! 848 [ 4.113720] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B 849 [ 4.113829] [mmc]: sdc0 fail to get regulator 850 [ 4.113834] [mmc]: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail 851 [ 4.116408] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B 852 [ 4.117940] [mmc]: sdc0 fail to get regulator 853 [ 4.117945] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail 854 [ 4.130042] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 855 [ 4.151112] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 856 [ 4.152211] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! 857 [ 4.152236] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 858 [ 4.154841] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B 859 [ 4.157019] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! 860 [ 4.157042] Try sdio 861 [ 4.158125] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 862 [ 4.159226] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 863 [ 4.160326] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 864 [ 4.161426] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! 865 [ 4.161448] *******************Try sd ******************* 866 [ 4.162532] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 867 [ 4.163632] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! 868 [ 4.164778] [mmc]: *** sunxi_mci_dump_errinfo(L824): get sysconfig para erro! 869 [ 4.165034] ctp_wakeup: !!!gpio data 1 870 [ 4.270051] get_device_para_value:get subname:icn83xx_ts error! val.val:0 871 [ 4.270058] get_detect_list: script_get_item err.support_number = 11. 872 [ 4.270065] get_device_para_value:get subname:gt818_ts error! val.val:0 873 [ 4.270071] get_detect_list: script_get_item err.support_number =^@HELLO! BOOT0 is starting! 874 boot0 version : 4.0.0 875 rtc[1] value = 0x00010000 876 rtc[2] value = 0x00020000 877 rtc[3] value = 0x00030000 878 DRAM DRIVE INFO: V1.0 879 DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) 880 DRAM normal_mode value: 00000001 881 DRAM CLK =672 MHZ 882 PMU: AXP81X 883 ddr voltage = 1200 mv 884 using ic A83T 885 using axp AXP813 886 DRAM zq value: 00003bfb 887 dram size =2048 888 card boot number = 2 889 card no is 2 890 sdcard 2 line count 0 891 [mmc]: mmc driver ver 2014-8-11 15:06:39 892 [mmc]: Try SD card 2 893 [mmc]: mmc 2 cmd 8 timeout, err 00000100 894 [mmc]: mmc 2 cmd 8 err 00000100 895 [mmc]: mmc 2 send if cond failed
And loop…loop…loop…
I check the md5 of all images and the hash hits already replaced the card and power supply
Any ideia ?
Sorry my english. Im Brazilian :slight_smile:
I retry with new raspian image…no sucess…
Im doing this :
1-) Boot on sd Raspian lite than…:
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
root@bananapi:~# root@bananapi:~# mount /dev/sdb1 /mnt/
(sdb is a 32gb pendrive)
root@bananapi:~# cd /mnt/ root@bananapi:/mnt# ls 2016-05-13-raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.img.zip root@bananapi:/mnt# unzip -p 2016-05-13-raspbian-jessie-mate-gpu-bpi-m3-sd-emmc.i img.zip | dd of=/dev/mmcblk1 bs=4096
1908736+0 records in 1908736+0 records out 7818182656 bytes (7.8 GB) copied, 940.503 s, 8.3 MB/s
root@bananapi:/mnt# sync root@bananapi:/mnt# shutdown -h now [ 2265.973186] Power down.
2-) Click power on withoud sdcard…and eternal reboot loop
root@bananapi:/mnt# shutdown -h now [ 2265.973186] Power down. HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000 DRAM DRIVE INFO: V1.0 DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM normal_mode value: 00000001 DRAM CLK =672 MHZ PMU: AXP81X ddr voltage = 1200 mv using ic A83T using axp AXP813 DRAM zq value: 00003bfb dram size =2048 card boot number = 2 card no is 2 sdcard 2 line count 0 [mmc]: mmc driver ver 2014-8-11 15:06:39 [mmc]: Try SD card 2 [mmc]: mmc 2 cmd 8 timeout, err 00000100 [mmc]: mmc 2 cmd 8 err 00000100 [mmc]: mmc 2 send if cond failed [mmc]: mmc 2 cmd 55 timeout, err 00000100 [mmc]: mmc 2 cmd 55 err 00000100 [mmc]: mmc 2 send app cmd failed [mmc]: Try MMC card 2 [mmc]: MMC ver 5.0 [mmc]: SD/MMC Card: 4bit, capacity: 7456MB [mmc]: vendor: Man 00150100 Snr 0077f9b0 [mmc]: product: 8WPD3 [mmc]: revision: 5.2 [mmc]: SD/MMC 2 init OK!!! sdcard 2 init ok ERROR! NOT find the head of uboot. The size of uboot is 000d8000. sum=ce3ec68c src_sum=ce3ec68c set_mmc_para,sdly 50M 0 set_mmc_para,sdly 25M 0 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. [ 0.346]
U-Boot 2011.09-rc1-00000-gfe0f876 (May 03 2016 - 13:13:31) Allwinner Technology
[ 0.355]version: 2.1.0 normal mode [ 0.435]pmbus: normal or secure os ready [ 0.439]PMU: AXP81X [ 0.441]PMU: AXP81X found bat_vol=0, ratio=100 [ 0.447]PMU: dcdc2 900 [ 0.449]PMU: pll1 1008 Mhz AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz set power on vol to default dcdc1_vol = 3300, onoff=1 dcdc2_vol = 900, onoff=1 dcdc3_vol = 900, onoff=1 dcdc4_vol = 900, onoff=1 dcdc6_vol = 900, onoff=1 aldo1_vol = 1800, onoff=0 aldo2_vol = 1800, onoff=1 aldo3_vol = 3000, onoff=1 eldo2_vol = 1800, onoff=0 dldo1_vol = 3300, onoff=0 dldo2_vol = 3300, onoff=0 dldo3_vol = 2500, onoff=1 dldo4_vol = 2800, onoff=0 fldo2_vol = 900, onoff=1 gpio0_vol = 3300, onoff=1 gpio1_vol = 3300, onoff=1 find power_sply to end supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b04, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b08, value=0xd, pmu_vol=3300 supply=dldo3 axp=axp81x, supply=dldo3, vol=1800 reg addr=0x1c20b0c, value=0x0, pmu_vol=1800 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b10, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b14, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b18, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b1c, value=0xd, pmu_vol=3300 supply=aldo3 axp=axp81x, supply=aldo3, vol=3000 reg addr=0x1f02f00, value=0xa, pmu_vol=3000 config gpio bias voltage finish vbus exist no battery, limit to dc ac100 reg 0x00 = 0x101 ac100 reg 0xd0 = 0x0 ac100 reg 0xd1 = 0x0 446:(board.c:power_source_init) [AXP81X]:[00]=[34] [AXP81X]:[01]=[10] [AXP81X]:[02]=[83] [AXP81X]:[03]=[51] [AXP81X]:[04]=[00] [AXP81X]:[05]=[00] [AXP81X]:[06]=[00] [AXP81X]:[07]=[00] [AXP81X]:[08]=[00] [AXP81X]:[09]=[00] [AXP81X]:[0A]=[00] [AXP81X]:[0B]=[00] [AXP81X]:[0C]=[00] [AXP81X]:[0D]=[00] [AXP81X]:[0E]=[00] [AXP81X]:[0F]=[00] [AXP81X]:[10]=[3F] [AXP81X]:[11]=[00] [AXP81X]:[12]=[20] [AXP81X]:[13]=[C8] [AXP81X]:[14]=[08] [AXP81X]:[15]=[1A] [AXP81X]:[16]=[1A] [AXP81X]:[17]=[0B] [AXP81X]:[18]=[15] [AXP81X]:[19]=[00] [AXP81X]:[1A]=[16] [AXP81X]:[1B]=[00] [AXP81X]:[1C]=[0B] [AXP81X]:[1D]=[04] [AXP81X]:[1E]=[00] [AXP81X]:[1F]=[00] [AXP81X]:[20]=[11] [AXP81X]:[21]=[A8] [AXP81X]:[22]=[A8] [AXP81X]:[23]=[A8] [AXP81X]:[24]=[A4] [AXP81X]:[25]=[9E] [AXP81X]:[26]=[A8] [AXP81X]:[27]=[FC] [AXP81X]:[28]=[0B] [AXP81X]:[29]=[0B] [AXP81X]:[2A]=[17] [AXP81X]:[2B]=[00] [AXP81X]:[2C]=[00] [AXP81X]:[2D]=[B0] [AXP81X]:[2E]=[40] [AXP81X]:[2F]=[00] [AXP81X]:[30]=[03] [AXP81X]:[31]=[03] [AXP81X]:[32]=[43] [AXP81X]:[33]=[C8] [AXP81X]:[34]=[C7] [AXP81X]:[35]=[68] [AXP81X]:[36]=[58] [AXP81X]:[37]=[00] [AXP81X]:[38]=[A5] [AXP81X]:[39]=[1F] [AXP81X]:[3A]=[83] [AXP81X]:[3B]=[08] [AXP81X]:[3C]=[FC] [AXP81X]:[3D]=[16] [AXP81X]:[3E]=[7C] BPI-M3:[AXP81X]:[3A]=[83] BPI-M3: [AXP81X]: set [3A]=[85] BPI-M3:[AXP81X]: read [3A]=[85] BPI-M3: [AXP81X]: set [35]=[83] BPI-M3:[AXP81X]: read [35]=[83] BPI-M3:[AXP81X]: do_reset resetting … set next mode 14 drv_disp_exit [ 0.842][mmc]: MMC Device 2 not found [ 0.846][mmc]: mmc not find,so not exit HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000 DRAM DRIVE INFO: V1.0 DRAM Type =7 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM normal_mode value: 00000001 DRAM CLK =672 MHZ PMU: AXP81X ddr voltage = 1200 mv using ic A83T using axp AXP813 DRAM zq value: 00003bfb dram size =2048 card boot number = 2 card no is 2 sdcard 2 line count 0 [mmc]: mmc driver ver 2014-8-11 15:06:39 [mmc]: Try SD card 2 [mmc]: mmc 2 cmd 8 timeout, err 00000100 [mmc]: mmc 2 cmd 8 err 00000100 [mmc]: mmc 2 send if cond failed [mmc]: mmc 2 cmd 55 timeout, err 00000100 [mmc]: mmc 2 cmd 55 err 00000100 [mmc]: mmc 2 send app cmd failed [mmc]: Try MMC card 2 [mmc]: MMC ver 5.0 [mmc]: SD/MMC Card: 4bit, capacity: 7456MB [mmc]: vendor: Man 00150100 Snr 0077f9b0 [mmc]: product: 8WPD3 [mmc]: revision: 5.2 [mmc]: SD/MMC 2 init OK!!! sdcard 2 init ok ERROR! NOT find the head of uboot. The size of uboot is 000d8000. sum=ce3ec68c src_sum=ce3ec68c set_mmc_para,sdly 50M 0 set_mmc_para,sdly 25M 0 Succeed in loading uboot from sdmmc flash. Ready to disable icache. Jump to secend Boot. [ 0.346]
[ 0.355]version: 2.1.0 normal mode [ 0.435]pmbus: normal or secure os ready [ 0.439]PMU: AXP81X [ 0.441]PMU: AXP81X found bat_vol=0, ratio=100 [ 0.447]PMU: dcdc2 900 [ 0.449]PMU: pll1 1008 Mhz AXI0=336 Mhz,PLL_PERIPH =1200 Mhz AHB1=200 Mhz, APB1=100 Mhz set power on vol to default dcdc1_vol = 3300, onoff=1 dcdc2_vol = 900, onoff=1 dcdc3_vol = 900, onoff=1 dcdc4_vol = 900, onoff=1 dcdc6_vol = 900, onoff=1 aldo1_vol = 1800, onoff=0 aldo2_vol = 1800, onoff=1 aldo3_vol = 3000, onoff=1 eldo2_vol = 1800, onoff=0 dldo1_vol = 3300, onoff=0 dldo2_vol = 3300, onoff=0 dldo3_vol = 2500, onoff=1 dldo4_vol = 2800, onoff=0 fldo2_vol = 900, onoff=1 gpio0_vol = 3300, onoff=1 gpio1_vol = 3300, onoff=1 find power_sply to end supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b04, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b08, value=0xd, pmu_vol=3300 supply=dldo3 axp=axp81x, supply=dldo3, vol=1800 reg addr=0x1c20b0c, value=0x0, pmu_vol=1800 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b10, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b14, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b18, value=0xd, pmu_vol=3300 supply=dcdc1 axp=axp81x, supply=dcdc1, vol=3300 reg addr=0x1c20b1c, value=0xd, pmu_vol=3300 supply=aldo3 axp=axp81x, supply=aldo3, vol=3000 reg addr=0x1f02f00, value=0xa, pmu_vol=3000 config gpio bias voltage finish vbus exist no battery, limit to dc ac100 reg 0x00 = 0x101 ac100 reg 0xd0 = 0x0 ac100 reg 0xd1 = 0x0 446:(board.c:power_source_init) [AXP81X]:[00]=[34] [AXP81X]:[01]=[10] [AXP81X]:[02]=[83] [AXP81X]:[03]=[51] [AXP81X]:[04]=[00] [AXP81X]:[05]=[00] [AXP81X]:[06]=[00] [AXP81X]:[07]=[00] [AXP81X]:[08]=[00] [AXP81X]:[09]=[00] [AXP81X]:[0A]=[00] [AXP81X]:[0B]=[00] [AXP81X]:[0C]=[00] [AXP81X]:[0D]=[00] [AXP81X]:[0E]=[00] [AXP81X]:[0F]=[0E] [AXP81X]:[10]=[3F] [AXP81X]:[11]=[00] [AXP81X]:[12]=[20] [AXP81X]:[13]=[C8] [AXP81X]:[14]=[08] [AXP81X]:[15]=[1A] [AXP81X]:[16]=[1A] [AXP81X]:[17]=[0B] [AXP81X]:[18]=[15] [AXP81X]:[19]=[00] [AXP81X]:[1A]=[16] [AXP81X]:[1B]=[00] [AXP81X]:[1C]=[0B] [AXP81X]:[1D]=[04] [AXP81X]:[1E]=[00] [AXP81X]:[1F]=[00] [AXP81X]:[20]=[11] [AXP81X]:[21]=[A8] [AXP81X]:[22]=[A8] [AXP81X]:[23]=[A8] [AXP81X]:[24]=[A4] [AXP81X]:[25]=[9E] [AXP81X]:[26]=[A8] [AXP81X]:[27]=[FC] [AXP81X]:[28]=[0B] [AXP81X]:[29]=[0B] [AXP81X]:[2A]=[17] [AXP81X]:[2B]=[00] [AXP81X]:[2C]=[00] [AXP81X]:[2D]=[B0] [AXP81X]:[2E]=[40] [AXP81X]:[2F]=[00] [AXP81X]:[30]=[03] [AXP81X]:[31]=[03] [AXP81X]:[32]=[43] [AXP81X]:[33]=[C8] [AXP81X]:[34]=[C7] [AXP81X]:[35]=[83] [AXP81X]:[36]=[58] [AXP81X]:[37]=[00] [AXP81X]:[38]=[A5] [AXP81X]:[39]=[1F] [AXP81X]:[3A]=[85] [AXP81X]:[3B]=[08] [AXP81X]:[3C]=[FC] [AXP81X]:[3D]=[16] [AXP81X]:[3E]=[7C] BPI-M3:[AXP81X]:[3A]=[85] limit to 2500mA fel key old mode run key detect no key found no key input dram_para_set start dram_para_set end [ 0.793]DRAM: 2 GiB relocation Offset is: 75af7000 user_gpio config user_gpio ok gic: normal or no secure os mode script config pll_de to 504 Mhz script config pll_video1 to 297 Mhz Not Found clk pll_video in script enable power vcc-hdmi-18, ret=0 DRV_DISP_Init end [ 0.958]boot_disp.output_disp=1 [ 0.961]boot_disp.output_type=3 [ 0.965]boot_disp.output_mode=5 [ 0.968]fetch script data boot_disp.auto_hpd fail disp1 device type(4) enable attched ok, mgr1<–>device1, type=4, mode=5---- ready to set mode workmode = 0 MMC: 2 [ 0.983][mmc]: mmc driver ver 2015-04-13 14:50:00 [ 0.988][mmc]: get sdc_phy_wipe fail. [ 0.992][mmc]: get sdc0 sdc_erase fail. [ 0.996][mmc]: get sdc_2xmode ok, val = 1 [ 1.000][mmc]: get sdc_ddrmode ok, val = 1 [ 1.004][mmc]: get sdc_f_max fail,use default 50000000Hz [ 1.010][mmc]: get card_line ok, card_line = 8 [ 1.014][mmc]: get sdc_ex_dly_used fail,use default [ 1.020][mmc]: SUNXI SD/MMC: 2 [ 1.033][mmc]: Try SD card 2 [ 1.036][mmc]: mmc 2 cmd 8 err 100 [ 1.042][mmc]: mmc send if cond failed [ 1.046][mmc]: mmc 2 cmd 55 err 100 [ 1.051][mmc]: send app cmd failed [ 1.054][mmc]: Try MMC card 2 [ 1.094][mmc]: mmc re-update_phase [ 1.099][mmc]: mmc re-update_phase [ 1.104][mmc]: mmc re-update_phase [ 1.109][mmc]: ddr8 [ 1.111][mmc]: mmc re-update_phase [ 1.124][mmc]: CID 0x15010038 0x57504433 0x520077f9 0xb0ff7275 [ 1.129][mmc]: MMC ver 5.0 [ 1.132][mmc]: mmc clk 50000000 [ 1.135][mmc]: SD/MMC Card: 8bit, capacity: 7456MB [ 1.140][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB [ 1.146][mmc]: SD/MMC 2 init OK!!! [ 1.151][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte [ 1.156][mmc]: secure_feature 0x55 [ 1.160][mmc]: secure_removal_type 0x9 [ 1.164]sunxi flash init ok the secure storage map is empty no item name key_burned_flag in the map sunxi secure storage has no flag [ 1.177]usb burn from boot delay time 0 [ 1.248]usb prepare ok [ 2.050]timer occur [ 2.052]overtime [ 2.087]do_burn_from_boot usb : no usb exist limit to dc In: serial Out: serial Err: serial --------fastboot partitions-------- -total partitions:6- -name- -start- -size-
boot-res : 1000000 2000000
env : 3000000 1000000
boot : 4000000 1000000
rootfs : 5000000 20000000
klog : 25000000 1000000
UDISK : 26000000 0
base bootcmd=run setargs_nand boot_normal bootcmd set setargs_mmc key 0 recovery key high 10, low 8 cant find fstbt value no misc partition is found to be run cmd=run setargs_mmc boot_normal serial is: 00000000000000000000 mount part name boot-res cant open script.bin, maybe it is not exist WORK_MODE_BOOT board_status_probe [ 2.165]pre sys mode sunxi_bmp_logo_display [ 2.202][mmc]: blkcnt should not be 0 [ 2.221]fetch script data boot_disp.output_disp fail [ 2.226]screen_id =1, screen_width =1280, screen_height =720 [ 2.231]frame buffer address 46400000 [ 2.235]Hit any key to stop autoboot: 0 Interface: MMC Device 2: Vendor: MID 000015 PSN 77f9b0ff Rev: PRV 0.0 Prod: PNM 8WPD3R Type: Removable Hard Disk Capacity: 7456.0 MB = 7.2 GB (15269888 x 512) Partition 1: Filesystem: FAT16 "BPI-BOOT " [ 5.514][mmc]: blkcnt should not be 0 Loaded environment from uEnv.txt Running uenvcmd … Banaan Pi bpi-m3 chip: a83t Service: linux
** Unable to read “bananapi/berryboot.img” from mmc 2:1 **
Booting kernel from Legacy Image at 48000000 …
Image Name: Linux-3.4.39-BPI-M3-Kernel Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 5717288 Bytes = 5.5 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum … OK Loading Kernel Image … OK OK [ 5.715][mmc]: mmc exit start [ 5.728][mmc]: mmc 2 cmd 8 err 100 [ 5.733][mmc]: mmc send if cond failed [ 5.737][mmc]: mmc 2 cmd 55 err 100 [ 5.742][mmc]: send app cmd failed [ 5.754][mmc]: get sdc_phy_wipe fail. [ 5.758][mmc]: get sdc0 sdc_erase fail. [ 5.762][mmc]: get sdc_2xmode ok, val = 1 [ 5.766][mmc]: get sdc_ddrmode ok, val = 1 [ 5.770][mmc]: get sdc_f_max fail,use default 50000000Hz [ 5.775][mmc]: get card_line ok, card_line = 8 [ 5.780][mmc]: get sdc_ex_dly_used fail,use default [ 5.785][mmc]: mmc 2 exit ok [ 5.788] Starting kernel …
[sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 2048MB ion_carveout reserve: 96m 128m ion_reserve_common: ion reserve: [0xb8000000, 0xc0000000]! ion_cma reserve: 120m 176m 512m ion_reserve_common: ion reserve: [0xa0000000, 0xc0000000]! ------sun8i_smp_init_ops----37----- [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.39-BPI-M3-Kernel (root@8ac3451c5c3b) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #1 SMP PREEMPT Tue May 3 13:47:01 UTC 2016 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: sun8i [ 0.000000] cma: CMA: reserved 512 MiB at a0000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] On node 0 totalpages: 524288 [ 0.000000] free_area_init_node: node 0, pgdat c0c7c540, node_mem_map c0d2f000 [ 0.000000] Normal zone: 1404 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 158340 pages, LIFO batch:31 [ 0.000000] HighMem zone: 3204 pages used for memmap [ 0.000000] HighMem zone: 361340 pages, LIFO batch:31 [ 0.000000] script_init enter! [ 0.000000] script_init exit! [ 0.000000] [mcpm_smp_init_cpus] ncores=8 [ 0.000000] PERCPU: Embedded 8 pages/cpu @c1f53000 s11776 r8192 d12800 u32768 [ 0.000000] pcpu-alloc: s11776 r8192 d12800 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519680 [ 0.000000] Kernel command line: enforcing=1 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootwait init=/init vmalloc=384M ion_cma_list=“120m,176m,512m” loglevel=8 bootmenutimeout=10 datadev=mmcblk0p2 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1535508k/1535508k available, 561644k reserved, 933888K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe7800000 - 0xff000000 ( 376 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe7000000 ( 624 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0ae0dd0 (11108 kB) [ 0.000000] .init : 0xc0ae1000 - 0xc0b39e00 ( 356 kB) [ 0.000000] .data : 0xc0b3a000 - 0xc0c93a50 (1383 kB) [ 0.000000] .bss : 0xc0c93a74 - 0xc0d2e258 ( 618 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:544 [ 0.000000] Architected local timer running at 24.00MHz. [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.001345] Calibrating delay loop (skipped), value calculated using timer frequency… 4800.00 BogoMIPS (lpj=24000000) [ 0.001418] pid_max: default: 32768 minimum: 301 [ 0.001752] Mount-cache hash table entries: 512 [ 0.003102] Initializing cgroup subsys cpuacct [ 0.003148] Initializing cgroup subsys memory [ 0.003221] Initializing cgroup subsys devices [ 0.003255] Initializing cgroup subsys freezer [ 0.003287] Initializing cgroup subsys blkio [ 0.003341] Initializing cgroup subsys perf_event [ 0.003437] CPU: Testing write buffer coherency: ok [ 0.003526] ftrace: allocating 27619 entries in 81 pages [ 0.040301] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.040384] Setting up static identity map for 0x4076b5a8 - 0x4076b600 [ 0.010000] CPU1: Booted secondary processor [ 0.010000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.010000] CPU2: Booted secondary processor [ 0.010000] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.010000] CPU3: Booted secondary processor [ 0.010000] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.260089] CPU4: failed to boot: -22 [ 0.300068] CPU5: failed to boot: -22 [ 0.340069] CPU6: failed to boot: -22 [ 0.380092] CPU7: failed to boot: -22 [ 0.380306] Brought up 4 CPUs [ 0.380332] SMP: Total of 4 processors activated (19200.00 BogoMIPS). [ 0.380910] devtmpfs: initialized [ 0.387462] pinctrl core: initialized pinctrl subsystem [ 0.411064] NET: Registered protocol family 16 [ 0.434051] DMA: preallocated 2048 KiB pool for atomic coherent allocations [ 0.434164] script_sysfs_init success [ 0.434215] sunxi_dump_init success [ 0.435357] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl [ 0.437175] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver [ 0.437639] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl [ 0.438869] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.438914] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.439773] [sunxi-module]: [sunxi-module.0] probe success [ 0.440454] script config pll_video1 to 297 Mhz [ 0.440491] script config pll_ve to 432 Mhz [ 0.440515] Not Found clk pll_periph in script [ 0.440543] script config pll_gpu to 432 Mhz [ 0.440572] script config pll_hsic to 480 Mhz [ 0.440600] script config pll_de to 504 Mhz [ 0.440622] sunxi_default_clk_init [ 0.440642] try to set pll6ahb1 to 200000000 [ 0.440703] try to set ahb clk source to pll6ahb1 [ 0.440728] set ahb clk source to pll6ahb1 [ 0.440753] try to set ahb1 to 200000000 [ 0.440778] try to set apb1 to 100000000 [ 0.441696] ===fe3o4==== sunxi_root_procfs_attach ret:0 [ 0.451320] bio: create slab at 0 [ 0.451320] [ARISC] :sunxi-arisc driver v1.70 [ 0.463403] [ARISC] :arisc version: [v0.1.25.3] [ 0.463459] [sunxi-module]: arisc register success [ 0.463891] sunxi_get_soc_bin: slow chip [ 0.464341] [ARISC] :sunxi-arisc driver v1.70 startup succeeded [ 0.010000] CPU4: Booted secondary processor [ 0.010000] CPU4: thread -1, cpu 0, socket 1, mpidr 80000100 [ 0.010000] CPU5: Booted secondary processor [ 0.010000] CPU5: thread -1, cpu 1, socket 1, mpidr 80000101 [ 0.010000] CPU6: Booted secondary processor [ 0.010000] CPU6: thread -1, cpu 2, socket 1, mpidr 80000102 [ 0.010000] CPU7: Booted secondary processor [ 0.010000] CPU7: thread -1, cpu 3, socket 1, mpidr 80000103 [ 0.491426] SCSI subsystem initialized [ 0.491426] libata version 3.00 loaded. [ 0.491426] usbcore: registered new interface driver usbfs [ 0.491426] usbcore: registered new interface driver hub [ 0.491426] usbcore: registered new device driver usb [ 0.491426] twi_chan_cfg()335 - [twi0] has no twi_regulator. [ 0.491426] twi_chan_cfg()335 - [twi1] has no twi_regulator. [ 0.491426] twi_chan_cfg()335 - [twi2] has no twi_regulator. [ 0.491702] Linux video capture interface: v2.00 [ 0.500643] BPI-M3: tmp [00] [ 0.500643] BPI-M3: set PMIC AC 4000mA [ 0.500643] BPI-M3: set PMIC AC 4000mA [ 0.510411] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.511088] Bluetooth: Core ver 2.16 [ 0.511160] NET: Registered protocol family 31 [ 0.511186] Bluetooth: HCI device and connection manager initialized [ 0.511219] Bluetooth: HCI socket layer initialized [ 0.511245] Bluetooth: L2CAP socket layer initialized [ 0.511291] Bluetooth: SCO socket layer initialized [ 0.511586] cfg80211: Calling CRDA to update world regulatory domain [ 0.511680] Switching to clocksource arch_sys_counter [ 0.537827] FS-Cache: Loaded [ 0.538176] CacheFiles: Loaded [ 0.549908] axp81x_dcdc1: Failed to create debugfs directory [ 0.551126] NET: Registered protocol family 2 [ 0.551510] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.552310] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.554806] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.556391] TCP: Hash tables configured (established 131072 bind 65536) [ 0.556422] TCP: reno registered [ 0.556449] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.556516] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.556951] NET: Registered protocol family 1 [ 0.557409] RPC: Registered named UNIX socket transport module. [ 0.557442] RPC: Registered udp transport module. [ 0.557466] RPC: Registered tcp transport module. [ 0.557490] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.558205] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available [ 0.558399] [pm]aw_pm_init! [ 0.558425] standby_mode = 1. [ 0.558446] wakeup src cnt is : 2. [ 0.558473] pmu name: pmu1_para . [ 0.558498] pmu1_enable = 0x1. [ 0.558519] pmux_id = 0x7. [ 0.558541] pmu name: pmu2_para . [ 0.558563] config_pmux_para: script_parser_fetch err. [ 0.558588] pmu2_enable = 0x0. [ 0.559004] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559189] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559229] add_sys_pwr_dm: axp81x_aldo2 ldo already alwayson. [ 0.559321] after inited: sys_mask config = 0xebd5. [ 0.559349] dynamic_standby enalbe = 0x0. [ 0.559403] sunxi_reg_init enter [ 0.559712] lock super standby for a83! [ 0.559746] lookup_scene_lock_name: new scene lock super_standby [ 0.559774] scene_lock_init name=super_standby [ 0.559800] scene_lock: super_standby, type 5, count 1 [ 0.561787] highmem bounce pool size: 64 pages [ 0.569692] VFS: Disk quotas dquot_6.5.2 [ 0.570099] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.572288] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.572858] NFS: Registering the id_resolver key type [ 0.573621] Installing knfsd (copyright © 1996 [email protected]). [ 0.574892] NTFS driver 2.1.30 [Flags: R/W]. [ 0.575318] fuse init (API version 7.18) [ 0.576472] ceph: loaded (mds proto 32) [ 0.576520] msgmni has been set to 1175 [ 0.584823] alg: No test for stdrng (krng) [ 0.668242] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.668301] io scheduler noop registered [ 0.668326] io scheduler deadline registered [ 0.668532] io scheduler cfq registered (default) [ 0.669004] pwm module init! [ 0.669613] [DISP]disp_module_init [ 0.703718] [DISP] Fb_map_kernel_logo,line:895:Fb_map_kernel_logo failed! [ 0.719007] Console: switching to colour frame buffer device 160x45 [ 0.735165] [DISP]disp_module_init finish [ 0.810691] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI [ 0.810900] sw_uart_pm()890 - uart0 clk is already enable [ 0.811066] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n [ 1.003426] console [ttyS0] enabled [ 1.309476] axp81x_dcdc1: Failed to create debugfs directory [ 1.470402] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI [ 1.470943] axp81x_dcdc1: Failed to create debugfs directory [ 1.471098] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI [ 1.472183] [drm] Initialized drm 1.1.0 20060810 [ 1.487084] brd: module loaded [ 1.493749] loop: module loaded [ 1.494075] [rf_pm]: select module num is 10 [ 1.494091] [rf_pm]: module power1 name vcc-wifi-io [ 1.494105] [rf_pm]: failed to fetch module_power1_vol [ 1.494120] [rf_pm]: module power2 name [ 1.494133] [rf_pm]: failed to fetch module_power2_vol [ 1.494148] [rf_pm]: module power3 name [ 1.494161] [rf_pm]: failed to fetch module_power3_vol [ 1.494175] [rf_pm]: mod has no power_switch gpio [ 1.494188] [rf_pm]: mod has no chip_en gpio [ 1.494202] [rf_pm]: lpo_use_apclk: ac10032k2 [ 1.494310] [rf_pm]: get power regulator failed. [ 1.494324] [rf_pm]: enable vcc-wifi-io. [ 1.629397] [rf_pm]: mod info power switch -1 [ 1.810152] [rf_pm]: set ac10032k2 32k out [ 1.810165] scene_lock_init name=rf_pm [ 1.810545] [wifi_pm]: wifi gpio init is OK !! [ 1.810623] [rfkill]: mod has no ls_int gpio [ 1.810632] [rfkill]: mod has no pcm_ch gpio [ 1.810970] [rfkill]: rfkill set power 0 [ 1.830114] Loading iSCSI transport class v2.0-870. [ 1.830633] iscsi: registered transport (tcp) [ 1.831117] [spi]: Found 1 spi devices in config files [ 1.831130] boards_num modalias max_spd_hz bus_num cs mode [ 1.831149] 0 spidev 33000000 0 0 3
[ 1.831599] axp81x_dcdc1: Failed to create debugfs directory [ 1.831868] spi spi0: master is unqueued, this is deprecated [ 1.832251] allwinners SoC SPI Driver loaded for Bus SPI-0 with 1 Slaves at most [ 1.832264] [spi-0]: driver probe succeed, base f1c68000, irq 97! [ 1.833812] usbcore: registered new interface driver qf9700 [ 1.833896] usbcore: registered new interface driver smsc95xx [ 1.833961] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 1.854081] sunxi-ehci sunxi-ehci.1: SW USB2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 1.854117] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 [ 1.945596] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 [ 2.280047] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 [ 2.441837] ehci_irq: highspeed device connect [ 2.441955] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.441968] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.441980] usb usb1: Product: SW USB2.0 ‘Enhanced’ Host Controller (EHCI) Driver [ 2.441991] usb usb1: Manufacturer: Linux 3.4.39-BPI-M3-Kernel ehci_hcd [ 2.442002] usb usb1: SerialNumber: sunxi-ehci [ 2.600466] hub 1-0:1.0: USB hub found [ 2.600495] hub 1-0:1.0: 1 port detected [ 2.600946] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver [ 2.621063] sunxi-ohci sunxi-ohci.1: SW USB2.0 ‘Open’ Host Controller (OHCI) Driver [ 2.621096] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 2 [ 2.621141] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 <6>[ 2.684145] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.684158] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.684170] usb usb2: Product: SW USB2.0 ‘Open’ Host Controller (OHCI) Driver [ 2.684181] usb usb2: Manufacturer: Linux 3.4.39-BPI-M3-Kernel ohci_hcd [ 2.684191] usb usb2: SerialNumber: sunxi-ohci [ 2.684760] hub 2-0:1.0: USB hub found [ 2.684785] hub 2-0:1.0: 1 port detected [ 2.685215] Initializing USB Mass Storage driver… [ 2.685354] usbcore: registered new interface driver usb-storage [ 2.685363] USB Mass Storage support registered. [ 2.685436] usbcore: registered new interface driver ums-alauda [ 2.685488] usbcore: registered new interface driver ums-cypress [ 2.685541] usbcore: registered new interface driver ums-datafab [ 2.685593] usbcore: registered new interface driver ums_eneub6250 [ 2.685646] usbcore: registered new interface driver ums-freecom [ 2.685697] usbcore: registered new interface driver ums-isd200 [ 2.685746] usbcore: registered new interface driver ums-jumpshot [ 2.685796] usbcore: registered new interface driver ums-karma [ 2.685846] usbcore: registered new interface driver ums-onetouch [ 2.685912] usbcore: registered new interface driver ums-realtek [ 2.685977] usbcore: registered new interface driver ums-sddr09 [ 2.686029] usbcore: registered new interface driver ums-sddr55 [ 2.686083] usbcore: registered new interface driver ums-usbat [ 2.686221] usbcore: registered new interface driver usbserial [ 2.686287] usbcore: registered new interface driver usbserial_generic [ 2.686333] USB Serial support registered for generic [ 2.686348] usbserial: USB Serial Driver core [ 2.686679] file system registered [ 2.688643] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 2.688656] android_usb gadget: Number of LUNs=3 [ 2.688667] lun0: LUN: removable file: (no medium) [ 2.688677] lun1: LUN: removable file: (no medium) [ 2.688687] lun2: LUN: removable file: (no medium) [ 2.689071] android_usb gadget: android_usb ready [ 2.774019] axp81x_dcdc1: Failed to create debugfs directory [ 2.920170] usb 1-1: new high-speed USB device number 2 using sunxi-ehci [ 3.073224] sunxi_hcd_host0 sunxi_hcd_host0: sunxi_hcd host driver [ 3.441679] sunxi_hcd_host0 sunxi_hcd_host0: new USB bus registered, assigned bus number 3 [ 3.454149] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.464948] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.476174] usb usb3: Product: sunxi_hcd host driver [ 3.484794] usb usb3: Manufacturer: Linux 3.4.39-BPI-M3-Kernel sunxi_hcd-hcd [ 3.495780] usb usb3: SerialNumber: sunxi_hcd_host0 [ 3.504341] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101 [ 3.504938] hub 3-0:1.0: USB hub found [ 3.504963] hub 3-0:1.0: 1 port detected [ 3.506019] mousedev: PS/2 mouse device common for all mice [ 3.506408] sunxikbd_script_init: key para not found, used default para. [ 3.507281] sunxi_rtc_init(796): sunxi rtc device register! [ 3.507412] keyname:ctp_para subname:ctp_power_io ,get error! [ 3.508016] rtc_gettime(333): read time 1970-1-1 1:39:8 [ 3.508198] get sysconfig para erro! [ 3.508221] get sysconfig para erro! [ 3.508239] get sysconfig para erro! [ 3.508258] get sysconfig para erro! [ 3.508306] ctp_wakeup: !!!gpio data 1 [ 3.508409] alarm_gettime(470): get alarm time 1970-1-1 1:0:0 success! [ 3.508834] rtc_gettime(333): read time 1970-1-1 1:39:8 [ 3.509107] rtc0 rtc0: rtc core: registered rtc0 as rtc0 [ 3.509328] sunxi_rtc_probe(756)! [ 3.509412] i2c /dev entries driver [ 3.510288] IR RC5(x) protocol handler initialized [ 3.510463] sunxi cedar version 0.1 [ 3.510544] [cedar]: install start!!! [ 3.510785] [cedar]: install end!!! [ 3.510822] Driver for 1-wire Dallas network protocol. [ 3.516723] Bluetooth: HCI UART driver ver 2.2 [ 3.516735] Bluetooth: HCI H4 protocol initialized [ 3.516744] Bluetooth: HCI BCSP protocol initialized [ 3.516753] Bluetooth: HCI Realtek H5 protocol initialized [ 3.517355] sunxi_get_soc_bin: slow chip [ 3.520118] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.113 2015-5-20 17:17) Compiled in May 3 2016 at 13:30:14 [ 3.520170] [mmc]: get mmc1’s sdc_power is null! [ 3.520189] [mmc]: get mmc2’s 2xmode ok, val = 1 [ 3.520194] [mmc]: get mmc2’s ddrmode ok, val = 1 [ 3.520202] [mmc]: MMC host used card: 0x7, boot card: 0x5, io_card 2 [ 3.610047] get_device_para_value:get subname:icn83xx_ts error! val.val:0 [ 3.610054] get_detect_list: script_get_item err.support_number = 11. [ 3.610062] get_device_para_value:get subname:gt818_ts error! val.val:0 [ 3.610067] get_detect_list: script_get_item err.support_number = 8. [ 3.610073] get_device_para_value:get subname:tu_ts error! val.val:0 [ 3.610078] get_detect_list: script_get_item err.support_number = 7. [ 3.610085] get_device_para_value:get subname:gt9xxf_ts error! val.val:0 [ 3.610090] get_detect_list: script_get_item err.support_number = 6. [ 3.610098] get_device_para_value:get subname:gslX680new error! val.val:0 [ 3.610103] get_detect_list: script_get_item err.support_number = 3. [ 3.610147] sw_get_write_info:open error …IS(filp):1 [ 3.610161] sw_set_write_info:open error …IS(filp):1 [ 3.610165] get write info erro! [ 3.610356] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.630183] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.647211] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.650188] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.670191] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.690186] sunxi_i2c_do_xfer()945 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x38) [ 3.777161] usb 1-1: Product: USB 2.0 Hub [ 3.777401] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.778488] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.780051] [mmc]: sdc0 fail to get regulator [ 3.780057] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail [ 3.800026] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.820844] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 3.821676] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 3.821698] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.824166] [mmc]: sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.826062] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 3.826081] Try sdio [ 3.826894] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.827719] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.828545] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.829369] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.829389] *******************Try sd ******************* [ 3.830205] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.831032] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.831859] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.832687] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.832705] Try mmc [ 3.832713] [mmc]: sdc0 set ios: clk 400000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.833608] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! [ 3.833629] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.833724] [mmc]: sdc0 fail to get regulator [ 3.833729] [mmc]: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail [ 3.836295] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.837821] [mmc]: sdc0 fail to get regulator [ 3.837826] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail [ 3.850030] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.871105] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 3.872201] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 3.872222] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.874820] [mmc]: sdc0 set ios: clk 300000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.876995] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 3.877014] Try sdio [ 3.878095] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.879188] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.880282] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.881375] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 3.881394] *******************Try sd ******************* [ 3.882475] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.883572] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.884668] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.885762] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 55, RTO !! [ 3.885780] Try mmc [ 3.885787] [mmc]: sdc0 set ios: clk 300000Hz bm OD pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.886962] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 1, RTO !! [ 3.886983] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.887073] [mmc]: sdc0 fail to get regulator [ 3.887078] [mmc]: *** sunxi_mci_set_ios(L2223): sdc0 card_power_off fail [ 3.889643] [mmc]: sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.891168] [mmc]: sdc0 fail to get regulator [ 3.891174] [mmc]: *** sunxi_mci_set_ios(L2159): sdc0 card_power_on fail [ 3.903767] [mmc]: sdc2 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 3.904071] hub 1-1:1.0: USB hub found [ 3.904180] hub 1-1:1.0: 4 ports detected [ 4.180061] [mmc]: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 4.201672] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 4.203316] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 52, RTO !! [ 4.203344] [mmc]: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 4.206215] [mmc]: sdc0 set ios: clk 200000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 4.208957] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 8, RTO !! [ 4.208981] Try sdio [ 4.210602] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 4.212237] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 4.213872] [mmc]: *** sunxi_mci_dump_errinfo(L824): smc 0 err, cmd 5, RTO !! [ 4.215507] [mmc]: *** sunxi_mci_dump_errinfo(HELLO! BOOT0 is starting! boot0 version : 4.0.0 rtc[1] value = 0x00010000 rtc[2] value = 0x00020000 rtc[3] value = 0x00030000
This is a cause that looks a lot about my problem !
right here :
and read my tutorial in part 13, to help you find a solution !
Time to translate French to Portuguese. Google will kkkkkk: D
Im reading…
Thanks for help.
Hi CastMan!
Now with 2.4A Power Supply on “usb power” and 1A power supply on USB OTG i got a correct boot.
Thanks for help.
That’s great !
Warning ! normally is not recommended use the OTG port to power the M3, + power suply micro USB !
