Hi all!
I can’t get bpi-m4 working with emmc boot. Here is what I do: -----all my work is with ssh -------
- created SD with ubuntu 16.04 server image (2020…ubuntu…sd-emmc…img)
- Booted ok, I can reach bpi via ssh
- Copied same image to USB
- Put USB in bpi-m4
- mount USB.
- bpi-copy the image in usb.
bpi-copy start the job and at the end says OK!! You can remove the BOOTDISK /dev/mmcblk1 now!! Is this allright?
Then, shutdown, removed SD, power on and bpi-m4 even not ask for IP from the dhcp. Green led is blinking, yellow led in LAN is blilnking.
Can anyone help me?
Edit: Sometimes emmc boots fine, but sometimes too, ssh tries throw “connection refused” or “connection reset by peer”. I think that board it is faulty. Even lshw shows 648 MB of RAM, and it is supposed a 2GB one. any idea?
