Set CPU clock speed to 2GHz
with these lines change: [vf_table1] L_max_freq = 2016000000 L_min_freq = 480000000 L_LV_count = 8 L_LV1_freq = 2016000000 L_LV1_volt = 1080 L_LV2_freq = 1800000000 L_LV2_volt = 1000 L_LV3_freq = 1608000000 L_LV3_volt = 920 L_LV4_freq = 1200000000 L_LV4_volt = 840 L_LV5_freq = 0 L_LV5_volt = 840 L_LV6_freq = 0 L_LV6_volt = 840 L_LV7_freq = 0 L_LV7_volt = 840 L_LV8_freq = 0 L_LV8_volt = 840 B_max_freq = 2016000000 B_min_freq = 480000000 B_LV_count = 8 B_LV1_freq = 2016000000 B_LV1_volt = 1080 B_LV2_freq = 1800000000 B_LV2_volt = 1000 B_LV3_freq = 1608000000 B_LV3_volt = 920
I can set CPU at 2Ghz now, but it will not increase performance. Because L_LV1_volt = 1080 is the same value for 1.8Ghz which formerly used. When I do Geekbench test, it jump back to 1.8Ghz or lower
So, if we want “real” 2Ghz, we need to give L_LV1_volt a little higher value than 1080.
But what will be the safe value to do the real overclock but not burn BPI-M3?
L_LV1_freq = 2016000000 L_LV1_volt = 1160 L_LV2_freq = 1800000000 L_LV2_volt = 1080 L_LV3_freq = 1608000000 L_LV3_volt = 1000 L_LV4_freq = 1200000000 L_LV4_volt = 920
Anyone is brave enough to try?
That’s not the reason. There are certain aspects and some of them are related. You need higher VDD_CPUX at higher clockspeeds. The higher VDD_CPUX --> the higher also the heat emissions. Since A83T is prone to overheating: the higher VDD_CPUX --> earlier throttling.
So without understanding the relationship between clockspeed, VDD_CPUX (high enough to ensure reliability, low enough to not increase heat too much) and temperatures you can’t tune anything. And without something like RPi-Monitor drawing nice graphs you’re lost anyway:
http://kaiser-edv.de/tmp/4U4tkD/install-rpi-monitor-for-a83t_h8.sh
TL;DR: BPi M3 can not be ‘overclocked’ without liquid cooling. Without a heatsink this device is limited to 1.2GHz, with heatsink and much airflow 1.6Ghz is possible. Everything known since 1st devices have been delivered half a year ago:
http://linux-sunxi.org/Banana_Pi_M3#Thermal_behaviour
The only ‘overclocking mode’ that works is the absolute moronic one: 2.0 GHz when the device is idle, but way below when it’s busy and higher clockspeeds would be needed (that’s what you get with all the settings above)
Eventually this helps
https://www.google.de/url?sa=t&source=web&rct=j&url=http://dl.linux-sunxi.org/A83T/A83T_datasheet_Revision_1.1.pdf&ved=0ahUKEwip2ZmNwaTNAhXFFZoKHaKzAKsQFggmMAI&usg=AFQjCNG-2XI0jR0psuOaQc-LF2P3Un2_Lw&sig2=DHlJfyqzS96OHLEzfIePBA
Regards
Absolute maximum ratings for VDD_CPUX are 1300mV (for example: For H3 the datasheet claims that the absolute maximum is 1.5V but VDD_CPUX should not exceed 1400mV under normal conditions).
Based on that one could assume that getting close to 1200mV should be ok on A83T. But that’s just absurd since the SoC already starts to insanely overheat already when fed with 1000mV. Then it’s quite normal that you get tested/recommended values not from the datasheet but from comments in Allwinner’s BSP. In our case that means:
In other words: Allwinner says feeding just 1000mV should be ok up to 1800MHz and 1080mV should be used above :wink:
And now comes the interesting part: How to verify at which voltage / clockspeed combinations A83T works reliable? That’s easy up to 1600MHz since here you can test the whole thing under ‘worst case conditions’ that are necessary since otherwise you’re testing wrong. But exceeding these 1600MHz will be hard since when you do serious testing the SoC will either throttle down or you have to increase the trip points accordingly: Please keep in mind that throttling starts when the internal thermal sensor reaches just 65°C:
So to test higher clockspeeds, the trip points have to be increased a lot. Then to prevent throttling jumping in too early the dvfs operating points have to be decreased step by step until reliability is concerd (bit flips being reported). We (linux-sunxi community) went through this process for A83T’s siblings H3 and A64 already. And anyone interested in better performance with BPi M3 can do the same. But when you do testing seriously then you will waste a lot of time and will end up with the conclusion that A83T is a ‘1.6GHz SoC’ since higher clockspeeds would require liquid cooling or annoying fans.
And the most important thing to understand: Overclocking is a nice try when you want to do numbercrunching on an SBC (which is somewhat weird though) but it’s soooo useless when it’s about real world performance since there other settings and performance metrics matter way more. So by being focused on higher CPU clockspeeds instead of things like random IO performance, IRQ distribution accross different CPU cores, improved scheduler and kernel settings you simply gain nothing.
Good point and well stated.
I notice throttling during Geekbench testing. That seems normal in all SBC
Comparing with my Odroid XU4 which is based Samsung Exynos5422. A83T CPU speed is really not a big concern. But the LDDR3 speed is very slow in BPI-M3. it drags the whole benchmark down!
