Raspbian Jessie 2017-05-25 for M2U with fixed instability bug
(Ievgen Rudyi) #1
Thanks for idea to facat: thread
Thanks to facat for prebuilt kernel, modules and uboot: gdrive
Fixed image -> gdrive
Tested: flashed onto microSD, booted on the M2U, run memtester - stable as rock!
Added on 16th of July, evening...
As I promised, below is the instructions how to upgrade the kernel and the uboot. I’ll provide the easiest way to do this: for microSD card and emmc via that card. All the below should be performed under Linux distro (except emmc steps - we’ll do this from Banana Pi itself)!
Upgrade your microSD card:
  1. Burn the image you need into microSD (I was working with Raspbian only but the procedure should be the same)
  2. Insert the microSD
  3. You’ll get on /dev something like mmcblk0, mmcblk0p1 mounted as BPI-BOOT and mmcblk0p2 mounted as BPI-ROOT
  4. Upgrade the uboot:
  1. Upgrade the BOOT partition:
  1. Upgrade the kernel:
  1. Copy all the tar files somewhere to the microSD to upgrade the emmc
  2. Sync the filesystem sync Done: simply boot from the microSD card.
Upgrade emmc:
  1. Boot from the microSD from the above (it’s stable, better boot from this card only!)
  2. Upgrade the uboot:
mkdir /tmp/emmc sudo mount /dev/mmcblk1p1 /tmp/emmc sudo tar -xf BPI-BOOT-bpi-m2u.tgz -C /tmp/emmc sync sudo umount /tmp/emmc 4. Upgrade the kernel:
sudo mount /dev/mmcblk1p1 /tmp/emmc sudo tar -xf 3.10.107-BPI-M2U-Kernel.tgz -C /tmp/emmc sync sudo umount /tmp/emmc
All done, just remove the microSD card and boot from emmc, use the microSD card as an emergency bootable media.
#2
Hi there, I have been discussing this also with facat on the other thread and I have just compiled dan-and’s kernel which also includes facet’s mods. It’s using linux 3.10.107 rather than 3.10.65 kernel so hopefully has some other improvements and security fixes.
I want to transfer the kernel directly onto the M2U while it is running. Is this possible? If so, how?
any help appreciated.
(Ievgen Rudyi) #3
Hi jata.
It’s pretty easy: boot from sd and copy/paste with overwrite the files onto internal emmc (don’t forget to mount the partitions), I think uboot can stay the same, only kernel files should be replaced.
In my opinion the only thing must be changed to fix the instability issue: uboot patch, that’s all.
Can you point me to that kernel files? Will try myself later.
#4
#5
I’m getting an error with a tar command. can see anything wrong with it. Can you?
sudo tar –xvf BPI-BOOT-bpi-m2u.tgz -C /mnt/BPI-BOOT
error is saying
tar: invalid option – ‘?’
(Ievgen Rudyi) #6
Pal, I’ve used Krusader with root privileges :wink:
Also can you provide prebuit kernel 107?
#7
I have just trashed my setup and can’t boot. I was stupid and didn’t transfer a copy of the kernel from the eMMC before rebooting. Ooops.
So, it’s not possible to provide a prebuilt kernel at the moment. I’d want to make sure it works before sharing anyway.
facat suggested contacting dan-and via GitHub so that might be worth a try
(facat) #8
Do your recompile Raspbian Jessie from source or you only replace files with prebuilt kernel, modules and uboot?
(Ievgen Rudyi) #9
Nope, simply patched the img file.
(facat) #10
That’s good.:slight_smile:
(Ievgen Rudyi) #11
Compilation of the whole Raspbian will take ages on my machine :joy:
(ROBIN) #12
wow great i will try it now.
(Ievgen Rudyi) #13
Guys, can you point me where to get the tars of the 3.10.107 kernel? I’ll patch the image with that kernel too. I found it some time ago but lost the link :sweat:
BPI-M2 Ultra Volumio open source project
(ROBIN) #14
may be you should check your browser story? :smiley:
(facat) #15
you mean this dan-and’s 3.10.107 kernel ?
(Ievgen Rudyi) #16
Exactly. But I don’t want to compile it. Will appreciate pre compiled binaries :slight_smile:
(Олександр Кузьменко) #17
#18
Thank you Олександр Кузьменко I will try your method and report back.
In your post, the install instructions - step 3 - do not look right.
  1. 3.10.106-BPI-M2U-Kernel.tgz
Extract BOOTLOADER-bpi-m2u.tgz to /lib/modules/
Should this be 3.10.106-BPI-M2U-Kernel.tgz that is extracted?
(Ievgen Rudyi) #19
Thanks pal :smile:
Updated my emergency microSD and built-in emmc with the kernel and modules you’ve provided.
Looks good.
#20
can you explain how you are doing this please? Are you using the instructions posted by Oleksandr_Kuzmenko or another method?
