Yeah, I’ve still got mt7615 compiled as a module. Here is my complete dmesg
output:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.9.0-bpi-r2-main (doug@Doug-PC) (arm-linux-gnueabihf-gcc (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04) 7.5.0, GNU ld (GNU Binutils for Ubuntu) 2.30) #1 SMP Tue Nov 24 15:45:06 CST 2020
[ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Bananapi BPI-R2
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] [WMT-CONSYS-HW][W]reserve_memory_consys_fn: name: consys-reserve-memory, base: 0xffe00000, size: 0x100000
[ 0.000000] OF: reserved mem: initialized node consys-reserve-memory, compatible id mediatek,consys-reserve-memory
[ 0.000000] cma: Reserved 64 MiB at 0xfb800000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x00000000a07fffff]
[ 0.000000] HighMem [mem 0x00000000a0800000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000ffdfffff]
[ 0.000000] node 0: [mem 0x00000000fff00000-0x00000000ffffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffefff]
[ 0.000000] On node 0 totalpages: 524031
[ 0.000000] Normal zone: 1170 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 133120 pages, LIFO batch:31
[ 0.000000] HighMem zone: 390911 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s51212 r8192 d22516 u81920
[ 0.000000] pcpu-alloc: s51212 r8192 d22516 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522861
[ 0.000000] Kernel command line: board=bpi-r2 earlyprintk console=ttyS0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait vmalloc=496M debug=7 initcall_debug=0 video=1920x1080 console=tty1 fbcon=map:0 drm.debug=0x7
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 1989880K/2096124K available (13312K kernel code, 1338K rwdata, 4804K rodata, 1024K init, 590K bss, 40708K reserved, 65536K cma-reserved, 1498108K highmem)
[ 0.000000] ftrace: allocating 42158 entries in 83 pages
[ 0.000000] ftrace: allocated 83 pages with 4 groups
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x384/0x538 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 13MHz, resolution 76ns, wraps every 4398046511101ns
[ 0.008061] Switching to timer-based delay loop, resolution 76ns
[ 0.014282] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 147020034397 ns
[ 0.023566] sched_clock: 32 bits at 13MHz, resolution 76ns, wraps every 165191050201ns
[ 0.032074] Console: colour dummy device 80x30
[ 0.036548] printk: console [tty1] enabled
[ 0.040673] printk: bootconsole [earlycon0] disabled
[ 0.045718] Calibrating delay loop (skipped), value calculated using timer frequency.. 26.00 BogoMIPS (lpj=130000)
[ 0.045742] pid_max: default: 32768 minimum: 301
[ 0.045941] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.045963] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.046909] CPU: Testing write buffer coherency: ok
[ 0.047252] CPU0: update cpu_capacity 1024
[ 0.047271] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.047933] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.048086] rcu: Hierarchical SRCU implementation.
[ 0.049529] smp: Bringing up secondary CPUs ...
[ 0.050147] CPU1: update cpu_capacity 1024
[ 0.050155] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.050885] CPU2: update cpu_capacity 1024
[ 0.050893] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.051576] CPU3: update cpu_capacity 1024
[ 0.051583] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.051700] smp: Brought up 1 node, 4 CPUs
[ 0.051769] SMP: Total of 4 processors activated (104.00 BogoMIPS).
[ 0.051782] CPU: All CPU(s) started in SVC mode.
[ 0.052587] devtmpfs: initialized
[ 0.060758] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[ 0.061317] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.061359] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.064105] xor: measuring software checksum speed
[ 0.155863] arm4regs : 1288.800 MB/sec
[ 0.255931] 8regs : 898.000 MB/sec
[ 0.355995] 32regs : 921.600 MB/sec
[ 0.456065] neon : 1300.800 MB/sec
[ 0.456080] xor: using function: neon (1300.800 MB/sec)
[ 0.456107] pinctrl core: initialized pinctrl subsystem
[ 0.457062] NET: Registered protocol family 16
[ 0.459183] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.460392] thermal_sys: Registered thermal governor 'step_wise'
[ 0.460975] No ATAGs?
[ 0.461159] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.461185] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.553168] gpiochip_find_base: found new base at 232
[ 0.553756] gpio gpiochip0: (1000b000.pinctrl): added GPIO chardev (254:0)
[ 0.553876] gpio gpiochip0: registered GPIOs 232 to 511 on 1000b000.pinctrl
[ 0.553904] gpio gpiochip0: (1000b000.pinctrl): created GPIO range 0->279 ==> 1000b000.pinctrl PIN 0->279
[ 0.746395] raid6: neonx8 gen() 806 MB/s
[ 0.916506] raid6: neonx8 xor() 598 MB/s
[ 1.086638] raid6: neonx4 gen() 870 MB/s
[ 1.256758] raid6: neonx4 xor() 638 MB/s
[ 1.426866] raid6: neonx2 gen() 939 MB/s
[ 1.596977] raid6: neonx2 xor() 672 MB/s
[ 1.767120] raid6: neonx1 gen() 842 MB/s
[ 1.937231] raid6: neonx1 xor() 582 MB/s
[ 2.107379] raid6: int32x8 gen() 250 MB/s
[ 2.277499] raid6: int32x8 xor() 156 MB/s
[ 2.447638] raid6: int32x4 gen() 259 MB/s
[ 2.617701] raid6: int32x4 xor() 187 MB/s
[ 2.787861] raid6: int32x2 gen() 331 MB/s
[ 2.957946] raid6: int32x2 xor() 191 MB/s
[ 3.128097] raid6: int32x1 gen() 324 MB/s
[ 3.298203] raid6: int32x1 xor() 177 MB/s
[ 3.298218] raid6: using algorithm neonx2 gen() 939 MB/s
[ 3.298232] raid6: .... xor() 672 MB/s, rmw enabled
[ 3.298247] raid6: using neon recovery algorithm
[ 3.298828] reg-fixed-voltage regulator-1p8v: GPIO lookup for consumer (null)
[ 3.298859] reg-fixed-voltage regulator-1p8v: using device tree for GPIO lookup
[ 3.298903] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-1p8v[0]'
[ 3.298937] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-1p8v[0]'
[ 3.298963] reg-fixed-voltage regulator-1p8v: using lookup tables for GPIO lookup
[ 3.298987] reg-fixed-voltage regulator-1p8v: No GPIO consumer (null) found
[ 3.299325] reg-fixed-voltage regulator-3p3v: GPIO lookup for consumer (null)
[ 3.299352] reg-fixed-voltage regulator-3p3v: using device tree for GPIO lookup
[ 3.299386] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-3p3v[0]'
[ 3.299419] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-3p3v[0]'
[ 3.299444] reg-fixed-voltage regulator-3p3v: using lookup tables for GPIO lookup
[ 3.299467] reg-fixed-voltage regulator-3p3v: No GPIO consumer (null) found
[ 3.299772] reg-fixed-voltage regulator-5v: GPIO lookup for consumer (null)
[ 3.299796] reg-fixed-voltage regulator-5v: using device tree for GPIO lookup
[ 3.299829] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/regulator-5v[0]'
[ 3.299863] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulator-5v[0]'
[ 3.299888] reg-fixed-voltage regulator-5v: using lookup tables for GPIO lookup
[ 3.299910] reg-fixed-voltage regulator-5v: No GPIO consumer (null) found
[ 3.300174] reg-fixed-voltage fixedregulator@0: GPIO lookup for consumer (null)
[ 3.300200] reg-fixed-voltage fixedregulator@0: using device tree for GPIO lookup
[ 3.300234] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator@0[0]'
[ 3.300267] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator@0[0]'
[ 3.300292] reg-fixed-voltage fixedregulator@0: using lookup tables for GPIO lookup
[ 3.300314] reg-fixed-voltage fixedregulator@0: No GPIO consumer (null) found
[ 3.300566] iommu: Default domain type: Translated
[ 3.301262] platform 15004000.jpegdec: Adding to iommu group 0
[ 3.301362] platform 14007000.ovl: Adding to iommu group 1
[ 3.301437] platform 14008000.rdma: Adding to iommu group 2
[ 3.301516] platform 14009000.wdma: Adding to iommu group 3
[ 3.301602] platform 14012000.rdma: Adding to iommu group 4
[ 3.305462] vgaarb: loaded
[ 3.305978] SCSI subsystem initialized
[ 3.306267] libata version 3.00 loaded.
[ 3.306529] usbcore: registered new interface driver usbfs
[ 3.306591] usbcore: registered new interface driver hub
[ 3.306677] usbcore: registered new device driver usb
[ 3.306782] mc: Linux media interface: v0.10
[ 3.306840] videodev: Linux video capture interface: v2.00
[ 3.307708] mediatek,efuse 10206000.efuse: GPIO lookup for consumer wp
[ 3.307739] mediatek,efuse 10206000.efuse: using device tree for GPIO lookup
[ 3.307780] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/efuse@10206000[0]'
[ 3.307815] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/efuse@10206000[0]'
[ 3.307844] mediatek,efuse 10206000.efuse: using lookup tables for GPIO lookup
[ 3.307867] mediatek,efuse 10206000.efuse: No GPIO consumer wp found
[ 3.308356] Advanced Linux Sound Architecture Driver Initialized.
[ 3.309061] Bluetooth: Core ver 2.22
[ 3.309139] NET: Registered protocol family 31
[ 3.309158] Bluetooth: HCI device and connection manager initialized
[ 3.309184] Bluetooth: HCI socket layer initialized
[ 3.309203] Bluetooth: L2CAP socket layer initialized
[ 3.309233] Bluetooth: SCO socket layer initialized
[ 3.310090] clocksource: Switched to clocksource arch_sys_counter
[ 4.283564] NET: Registered protocol family 2
[ 4.284429] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 4.284486] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 4.284547] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 4.284617] TCP: Hash tables configured (established 4096 bind 4096)
[ 4.284763] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 4.284814] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 4.285050] NET: Registered protocol family 1
[ 4.285726] RPC: Registered named UNIX socket transport module.
[ 4.285755] RPC: Registered udp transport module.
[ 4.285770] RPC: Registered tcp transport module.
[ 4.285783] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 4.286376] PCI: CLS 0 bytes, default 64
[ 4.287463] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 4.289296] Initialise system trusted keyrings
[ 4.289578] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 4.297254] NFS: Registering the id_resolver key type
[ 4.297315] Key type id_resolver registered
[ 4.297330] Key type id_legacy registered
[ 4.297465] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 4.403220] async_tx: api initialized (async)
[ 4.403261] Key type asymmetric registered
[ 4.403277] Asymmetric key parser 'x509' registered
[ 4.403362] bounce: pool size: 64 pages
[ 4.403426] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 4.403450] io scheduler mq-deadline registered
[ 4.403465] io scheduler kyber registered
[ 4.406334] mediatek-hdmi-phy 10209100.phy: Using default TX DRV impedance: 4.2k/36
[ 4.476075] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 4.478312] printk: console [ttyS0] disabled
[ 4.478362] mt6577-uart 11004000.serial: GPIO lookup for consumer rs485-term
[ 4.478383] mt6577-uart 11004000.serial: using device tree for GPIO lookup
[ 4.478427] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/serial@11004000[0]'
[ 4.478463] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/serial@11004000[0]'
[ 4.478493] mt6577-uart 11004000.serial: using lookup tables for GPIO lookup
[ 4.478514] mt6577-uart 11004000.serial: No GPIO consumer rs485-term found
[ 4.498699] 11004000.serial: ttyS0 at MMIO 0x11004000 (irq = 30, base_baud = 1625000) is a ST16650V2
[ 5.726505] printk: console [ttyS0] enabled
[ 5.732032] mt6577-uart 11002000.serial: GPIO lookup for consumer rs485-term
[ 5.739099] mt6577-uart 11002000.serial: using device tree for GPIO lookup
[ 5.746033] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/serial@11002000[0]'
[ 5.755828] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/serial@11002000[0]'
[ 5.765521] mt6577-uart 11002000.serial: using lookup tables for GPIO lookup
[ 5.772595] mt6577-uart 11002000.serial: No GPIO consumer rs485-term found
[ 5.799630] 11002000.serial: ttyS1 at MMIO 0x11002000 (irq = 31, base_baud = 1625000) is a ST16650V2
[ 5.810171] mt6577-uart 11003000.serial: GPIO lookup for consumer rs485-term
[ 5.817239] mt6577-uart 11003000.serial: using device tree for GPIO lookup
[ 5.824183] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/serial@11003000[0]'
[ 5.833961] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/serial@11003000[0]'
[ 5.843645] mt6577-uart 11003000.serial: using lookup tables for GPIO lookup
[ 5.850711] mt6577-uart 11003000.serial: No GPIO consumer rs485-term found
[ 5.877735] 11003000.serial: ttyS2 at MMIO 0x11003000 (irq = 32, base_baud = 1625000) is a ST16650V2
[ 5.888407] mtk_rng 1020f000.rng: registered RNG driver
[ 5.888548] random: fast init done
[ 5.894112] [drm:drm_core_init] Initialized
[ 5.897285] random: crng init done
[ 5.905855] mediatek-drm mediatek-drm.1.auto: Adding component match for /ovl@14007000
[ 5.913881] mediatek-drm mediatek-drm.1.auto: Adding component match for /rdma@14008000
[ 5.921990] mediatek-drm mediatek-drm.1.auto: Adding component match for /color@1400b000
[ 5.930173] mediatek-drm mediatek-drm.1.auto: Adding component match for /rdma@14012000
[ 5.938209] mediatek-drm mediatek-drm.1.auto: Adding component match for /dpi@14014000
[ 5.947062] mediatek-mipi-tx 10010000.mipi-dphy: can't get nvmem_cell_get, ignore it
[ 5.957576] [drm] hdmi-audio-codec driver bound to HDMI
[ 5.973120] loop: module loaded
[ 5.976505] [WMT-DETECT][I]wmt_detect_driver_init:driver(major 154) installed success
[ 5.984442] [SDIO-DETECT][I]sdio_detect_init:sdio_register_driver() ret=0
[ 5.991467] MTK-BTIF[E]hal_btif_clk_get_and_prepare(284):[CCF]clk_btif=cac0aab9
[ 5.998797] MTK-BTIF[E]hal_btif_clk_get_and_prepare(290):[CCF]clk_btif_apdma=ccc677d8
[ 6.010530] mt6323-regulator mt6323-regulator: Chip ID = 0x2023
[ 6.026367] Uniform Multi-Platform E-IDE driver
[ 6.031063] ide-gd driver 1.18
[ 6.035019] mdio_bus fixed-0: GPIO lookup for consumer reset
[ 6.040770] mdio_bus fixed-0: using lookup tables for GPIO lookup
[ 6.046871] mdio_bus fixed-0: No GPIO consumer reset found
[ 6.052411] libphy: Fixed MDIO Bus: probed
[ 6.079652] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mac@0/fixed-link[0]'
[ 6.090593] of_get_named_gpiod_flags: can't parse 'link-gpio' property of node '/ethernet@1b100000/mac@0/fixed-link[0]'
[ 6.102235] mdio_bus mdio-bus: GPIO lookup for consumer reset
[ 6.107994] mdio_bus mdio-bus: using device tree for GPIO lookup
[ 6.114067] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus[0]'
[ 6.124372] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ethernet@1b100000/mdio-bus[0]'
[ 6.134574] mdio_bus mdio-bus: using lookup tables for GPIO lookup
[ 6.140773] mdio_bus mdio-bus: No GPIO consumer reset found
[ 6.146348] libphy: mdio: probed
[ 6.150318] mt7530 mdio-bus:00: GPIO lookup for consumer reset
[ 6.156163] mt7530 mdio-bus:00: using device tree for GPIO lookup
[ 6.162352] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0[0]' - status (0)
[ 6.174152] gpio gpiochip0: Persistence not supported for GPIO 33
[ 6.181282] mtk_soc_eth 1b100000.ethernet eth0: mediatek frame engine at 0xe14c0000, irq 48
[ 6.191672] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[ 6.196975] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 1
[ 6.207932] xhci-mtk 1a1c0000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[ 6.217113] xhci-mtk 1a1c0000.usb: irq 45, io mem 0x1a1c0000
[ 6.223998] hub 1-0:1.0: USB hub found
[ 6.227821] hub 1-0:1.0: 1 port detected
[ 6.232282] xhci-mtk 1a1c0000.usb: xHCI Host Controller
[ 6.237533] xhci-mtk 1a1c0000.usb: new USB bus registered, assigned bus number 2
[ 6.244972] xhci-mtk 1a1c0000.usb: Host supports USB 3.0 SuperSpeed
[ 6.251363] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.260290] hub 2-0:1.0: USB hub found
[ 6.264106] hub 2-0:1.0: 1 port detected
[ 6.269811] xhci-mtk 1a240000.usb: xHCI Host Controller
[ 6.275106] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 3
[ 6.285921] xhci-mtk 1a240000.usb: hcc params 0x01401198 hci version 0x96 quirks 0x0000000000210010
[ 6.295099] xhci-mtk 1a240000.usb: irq 46, io mem 0x1a240000
[ 6.301948] hub 3-0:1.0: USB hub found
[ 6.305767] hub 3-0:1.0: 1 port detected
[ 6.310215] xhci-mtk 1a240000.usb: xHCI Host Controller
[ 6.315464] xhci-mtk 1a240000.usb: new USB bus registered, assigned bus number 4
[ 6.322919] xhci-mtk 1a240000.usb: Host supports USB 3.0 SuperSpeed
[ 6.329305] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.338220] hub 4-0:1.0: USB hub found
[ 6.342202] hub 4-0:1.0: 1 port detected
[ 6.347339] usbcore: registered new interface driver usb-storage
[ 6.353851] mousedev: PS/2 mouse device common for all mice
[ 6.361264] mt6397-rtc mt6323-rtc: registered as rtc0
[ 6.366398] mt6397-rtc mt6323-rtc: setting system clock to 2020-11-26T14:41:33 UTC (1606401693)
[ 6.377547] Registered IR keymap rc-empty
[ 6.381761] rc rc0: mtk_cir as /devices/platform/10013000.cir/rc/rc0
[ 6.388362] rc rc0: lirc_dev: driver mtk_cir registered at minor = 0, raw IR receiver, no transmitter
[ 6.397811] input: mtk_cir as /devices/platform/10013000.cir/rc/rc0/input0
[ 6.405225] mtk_cir 10013000.cir: Initialized MT7623 IR driver, sample period = 46us
[ 6.414183] mtk-jpeg 15004000.jpegdec: decoder device registered as /dev/video3 (81,0)
[ 6.423090] mtk-thermal 1100b000.thermal: Device not calibrated, using default calibration values
[ 6.433706] mtk-wdt 10007000.watchdog: Watchdog enabled (timeout=31 sec, nowayout=0)
[ 6.442624] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[ 6.451562] device-mapper: multipath round-robin: version 1.2.0 loaded
[ 6.458106] device-mapper: multipath queue-length: version 0.2.0 loaded
[ 6.464764] device-mapper: multipath service-time: version 0.3.0 loaded
[ 6.471454] device-mapper: raid: Loading target version 1.15.1
[ 6.477904] cpu cpu0: dummy supplies not allowed for exclusive requests
[ 6.487026] mtk-msdc 11240000.mmc: GPIO lookup for consumer cd
[ 6.492915] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[ 6.499313] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/mmc@11240000[0]' - status (0)
[ 6.508856] gpio gpiochip0: Persistence not supported for GPIO 261
[ 6.515079] mtk-msdc 11240000.mmc: Got CD GPIO
[ 6.519529] mtk-msdc 11240000.mmc: GPIO lookup for consumer wp
[ 6.525385] mtk-msdc 11240000.mmc: using device tree for GPIO lookup
[ 6.531773] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11240000[0]'
[ 6.540594] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11240000[0]'
[ 6.549305] mtk-msdc 11240000.mmc: using lookup tables for GPIO lookup
[ 6.555848] mtk-msdc 11240000.mmc: No GPIO consumer wp found
[ 6.589071] mtk-msdc 11230000.mmc: GPIO lookup for consumer wp
[ 6.594964] mtk-msdc 11230000.mmc: using device tree for GPIO lookup
[ 6.601377] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/mmc@11230000[0]'
[ 6.610204] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/mmc@11230000[0]'
[ 6.618916] mtk-msdc 11230000.mmc: using lookup tables for GPIO lookup
[ 6.625465] mtk-msdc 11230000.mmc: No GPIO consumer wp found
[ 6.658884] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/blue[0]' - status (0)
[ 6.668005] gpio gpiochip0: Persistence not supported for GPIO 240
[ 6.674247] gpio-472 (?): no flags found for gpios
[ 6.679231] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/green[0]' - status (0)
[ 6.688354] gpio gpiochip0: Persistence not supported for GPIO 241
[ 6.694568] gpio-473 (?): no flags found for gpios
[ 6.699533] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/red[0]' - status (0)
[ 6.708475] gpio gpiochip0: Persistence not supported for GPIO 239
[ 6.714708] gpio-471 (?): no flags found for gpios
[ 6.719534] mmc0: host does not support reading read-only switch, assuming write-enable
[ 6.725407] hid: raw HID events driver (C) Jiri Kosina
[ 6.732990] usbcore: registered new interface driver usbhid
[ 6.738589] usbhid: USB HID core driver
[ 6.742501] mmc0: new high speed SDHC card at address 59b4
[ 6.744451] mtk-iommu-v1 10205000.mmsys_iommu: bound 14010000.larb (ops mtk_smi_larb_component_ops)
[ 6.749391] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 6.757128] mtk-iommu-v1 10205000.mmsys_iommu: bound 16010000.larb (ops mtk_smi_larb_component_ops)
[ 6.770719] mtk-iommu-v1 10205000.mmsys_iommu: bound 15001000.larb (ops mtk_smi_larb_component_ops)
[ 6.783114] mmcblk0: p1 p2
[ 6.784039] drop_monitor: Initializing network drop monitor service
[ 6.793117] NET: Registered protocol family 10
[ 6.798818] Segment Routing with IPv6
[ 6.802629] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 6.809253] NET: Registered protocol family 17
[ 6.814498] NET: Registered protocol family 41
[ 6.819095] 8021q: 802.1Q VLAN Support v1.8
[ 6.823999] ThumbEE CPU extension supported.
[ 6.828288] Registering SWP/SWPB emulation handler
[ 6.833241] Loading compiled-in X.509 certificates
[ 6.860275] mtk-pcie 1a140000.pcie: host bridge /pcie@1a140000 ranges:
[ 6.866860] mtk-pcie 1a140000.pcie: IO 0x001a160000..0x001a16ffff -> 0x001a160000
[ 6.874927] mtk-pcie 1a140000.pcie: MEM 0x0060000000..0x006fffffff -> 0x0060000000
[ 6.935532] mmc1: new high speed MMC card at address 0001
[ 6.942282] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 6.947636] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 6.954414] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 6.960684] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB, chardev (245:0)
[ 6.970503] mmcblk1:
[ 6.997479] mtk-pcie 1a140000.pcie: PCI host bridge to bus 0000:00
[ 7.003725] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 7.009221] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x1a160000-0x1a16ffff])
[ 7.018738] pci_bus 0000:00: root bus resource [mem 0x60000000-0x6fffffff]
[ 7.025685] pci 0000:00:00.0: [14c3:0801] type 01 class 0x060400
[ 7.031737] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 7.038081] pci 0000:00:00.0: supports D1
[ 7.042113] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 7.048363] pci 0000:00:01.0: [14c3:0801] type 01 class 0x060400
[ 7.054441] pci 0000:00:01.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[ 7.060796] pci 0000:00:01.0: supports D1
[ 7.064812] pci 0000:00:01.0: PME# supported from D0 D1 D3hot
[ 7.073523] PCI: bus0: Fast back to back transfers disabled
[ 7.079116] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.087157] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 7.095404] pci 0000:01:00.0: [14c3:7615] type 00 class 0x000280
[ 7.101465] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x000fffff 64bit]
[ 7.132866] PCI: bus1: Fast back to back transfers disabled
[ 7.138461] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 7.145342] pci 0000:02:00.0: [1b21:0611] type 00 class 0x010185
[ 7.151408] pci 0000:02:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 7.158462] pci 0000:02:00.0: reg 0x10: [io size 0x0008]
[ 7.163890] pci 0000:02:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[ 7.170956] pci 0000:02:00.0: reg 0x14: [io size 0x0004]
[ 7.176365] pci 0000:02:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 7.183429] pci 0000:02:00.0: reg 0x18: [io size 0x0008]
[ 7.188838] pci 0000:02:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[ 7.195902] pci 0000:02:00.0: reg 0x1c: [io size 0x0004]
[ 7.201323] pci 0000:02:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[ 7.208376] pci 0000:02:00.0: reg 0x20: [io size 0x0010]
[ 7.213801] pci 0000:02:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 7.220093] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 7.252861] PCI: bus2: Fast back to back transfers disabled
[ 7.258457] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 7.265155] pci 0000:00:00.0: BAR 8: assigned [mem 0x60000000-0x600fffff]
[ 7.271976] pci 0000:00:01.0: BAR 8: assigned [mem 0x60100000-0x601fffff]
[ 7.278771] pci 0000:00:01.0: BAR 9: assigned [mem 0x60200000-0x602fffff pref]
[ 7.286017] pci 0000:00:00.0: BAR 1: assigned [mem 0x60300000-0x6030ffff]
[ 7.292827] pci 0000:00:01.0: BAR 1: assigned [mem 0x60310000-0x6031ffff]
[ 7.299622] pci 0000:00:01.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 7.305742] pci 0000:01:00.0: BAR 0: assigned [mem 0x60000000-0x600fffff 64bit]
[ 7.313085] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 7.318056] pci 0000:00:00.0: bridge window [mem 0x60000000-0x600fffff]
[ 7.324874] pci 0000:02:00.0: BAR 6: assigned [mem 0x60200000-0x6020ffff pref]
[ 7.332118] pci 0000:02:00.0: BAR 5: assigned [mem 0x60100000-0x601001ff]
[ 7.338915] pci 0000:02:00.0: BAR 4: assigned [io 0x1000-0x100f]
[ 7.345030] pci 0000:02:00.0: BAR 0: assigned [io 0x1010-0x1017]
[ 7.351145] pci 0000:02:00.0: BAR 2: assigned [io 0x1018-0x101f]
[ 7.357247] pci 0000:02:00.0: BAR 1: assigned [io 0x1020-0x1023]
[ 7.363361] pci 0000:02:00.0: BAR 3: assigned [io 0x1024-0x1027]
[ 7.369462] pci 0000:00:01.0: PCI bridge to [bus 02]
[ 7.374444] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 7.380557] pci 0000:00:01.0: bridge window [mem 0x60100000-0x601fffff]
[ 7.387350] pci 0000:00:01.0: bridge window [mem 0x60200000-0x602fffff pref]
[ 7.394818] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 7.401187] pcieport 0000:00:00.0: PME: Signaling with IRQ 250
[ 7.407404] pcieport 0000:00:01.0: enabling device (0140 -> 0143)
[ 7.413712] pcieport 0000:00:01.0: PME: Signaling with IRQ 75
[ 7.419926] ahci 0000:02:00.0: version 3.0
[ 7.424090] ahci 0000:02:00.0: enabling device (0140 -> 0143)
[ 7.429980] ahci 0000:02:00.0: SSS flag set, parallel bus scan disabled
[ 7.436680] ahci 0000:02:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl IDE mode
[ 7.444711] ahci 0000:02:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 7.454962] scsi host0: ahci
[ 7.458628] scsi host1: ahci
[ 7.461869] ata1: SATA max UDMA/133 abar m512@0x60100000 port 0x60100100 irq 75
[ 7.469193] ata2: SATA max UDMA/133 abar m512@0x60100000 port 0x60100180 irq 75
[ 7.477469] mediatek-dpi 14014000.dpi: Found bridge node: /hdmi@14015000
[ 7.484515] mediatek-drm mediatek-drm.1.auto: bound 14007000.ovl (ops mtk_disp_ovl_component_ops)
[ 7.493464] mediatek-drm mediatek-drm.1.auto: bound 14008000.rdma (ops mtk_disp_rdma_component_ops)
[ 7.502539] mediatek-drm mediatek-drm.1.auto: bound 1400b000.color (ops mtk_disp_color_component_ops)
[ 7.511797] mediatek-drm mediatek-drm.1.auto: bound 14012000.rdma (ops mtk_disp_rdma_component_ops)
[ 7.520902] [drm:drm_connector_init] cmdline mode for connector HDMI-A-1 1920x1080@60Hz
[ 7.529010] mediatek-drm mediatek-drm.1.auto: bound 14014000.dpi (ops mtk_dpi_component_ops)
[ 7.537552] mediatek-drm mediatek-drm.1.auto: Not creating crtc 1 because component 9 is disabled or missing
[ 7.547885] [drm:drm_minor_register]
[ 7.551619] [drm:drm_minor_register]
[ 7.555632] [drm:drm_minor_register] new minor registered 0
[ 7.561399] [drm:drm_sysfs_connector_add] adding "HDMI-A-1" to sysfs
[ 7.567823] [drm:drm_sysfs_hotplug_event] generating hotplug event
[ 7.574051] [drm] Initialized mediatek 1.0.0 20150513 for mediatek-drm.1.auto on minor 0
[ 7.582182] [drm:drm_client_modeset_probe]
[ 7.586374] [drm:drm_mode_object_get] OBJ ID: 32 (2)
[ 7.591361] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:32:HDMI-A-1]
[ 7.598859] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:32:HDMI-A-1] status updated from unknown to disconnected
[ 7.610186] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:32:HDMI-A-1] disconnected
[ 7.618813] [drm:drm_client_modeset_probe] No connectors reported connected with modes
[ 7.626753] [drm:drm_client_modeset_probe] connector 32 enabled? no
[ 7.633037] [drm:drm_client_modeset_probe] Not using firmware configuration
[ 7.640007] [drm:drm_client_modeset_probe] picking CRTCs for 4096x4096 config
[ 7.647164] [drm:drm_mode_object_put.part.0] OBJ ID: 32 (2)
[ 7.652759] mediatek-drm mediatek-drm.1.auto: [drm:__drm_fb_helper_initial_config_and_unlock] test CRTC 0 primary plane
[ 7.663563] mediatek-drm mediatek-drm.1.auto: [drm] Cannot find any crtc or sizes
[ 7.671729] mt7530 mdio-bus:00: GPIO lookup for consumer reset
[ 7.677577] mt7530 mdio-bus:00: using device tree for GPIO lookup
[ 7.683751] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0[0]' - status (0)
[ 7.695551] gpio gpiochip0: Persistence not supported for GPIO 33
[ 7.701802] [drm:drm_sysfs_hotplug_event] generating hotplug event
[ 7.708054] [drm:drm_client_modeset_probe]
[ 7.712306] [drm:drm_mode_object_get] OBJ ID: 32 (2)
[ 7.717288] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:32:HDMI-A-1]
[ 7.724811] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:32:HDMI-A-1] disconnected
[ 7.733455] [drm:drm_client_modeset_probe] No connectors reported connected with modes
[ 7.741399] [drm:drm_client_modeset_probe] connector 32 enabled? no
[ 7.747675] [drm:drm_client_modeset_probe] Not using firmware configuration
[ 7.754658] [drm:drm_client_modeset_probe] picking CRTCs for 4096x4096 config
[ 7.761817] [drm:drm_mode_object_put.part.0] OBJ ID: 32 (2)
[ 7.767403] mediatek-drm mediatek-drm.1.auto: [drm:__drm_fb_helper_initial_config_and_unlock] test CRTC 0 primary plane
[ 7.778218] mediatek-drm mediatek-drm.1.auto: [drm] Cannot find any crtc or sizes
[ 7.785727] mediatek-drm mediatek-drm.1.auto: [drm:drm_client_dev_hotplug] fbdev: ret=0
[ 7.801186] mdio_bus dsa-0.0: GPIO lookup for consumer reset
[ 7.801534] ata1: SATA link down (SStatus 0 SControl 300)
[ 7.806860] mdio_bus dsa-0.0: using lookup tables for GPIO lookup
[ 7.818413] mdio_bus dsa-0.0: No GPIO consumer reset found
[ 7.824601] mdio_bus dsa-0.0:00: GPIO lookup for consumer reset
[ 7.830570] mdio_bus dsa-0.0:00: using lookup tables for GPIO lookup
[ 7.836931] mdio_bus dsa-0.0:00: No GPIO consumer reset found
[ 7.843350] mdio_bus dsa-0.0:01: GPIO lookup for consumer reset
[ 7.849288] mdio_bus dsa-0.0:01: using lookup tables for GPIO lookup
[ 7.855678] mdio_bus dsa-0.0:01: No GPIO consumer reset found
[ 7.862052] mdio_bus dsa-0.0:02: GPIO lookup for consumer reset
[ 7.867990] mdio_bus dsa-0.0:02: using lookup tables for GPIO lookup
[ 7.874379] mdio_bus dsa-0.0:02: No GPIO consumer reset found
[ 7.880754] mdio_bus dsa-0.0:03: GPIO lookup for consumer reset
[ 7.886691] mdio_bus dsa-0.0:03: using lookup tables for GPIO lookup
[ 7.893082] mdio_bus dsa-0.0:03: No GPIO consumer reset found
[ 7.899411] mdio_bus dsa-0.0:04: GPIO lookup for consumer reset
[ 7.905372] mdio_bus dsa-0.0:04: using lookup tables for GPIO lookup
[ 7.911746] mdio_bus dsa-0.0:04: No GPIO consumer reset found
[ 7.917626] libphy: dsa slave smi: probed
[ 7.922545] mt7530 mdio-bus:00 wan (uninitialized): PHY [dsa-0.0:00] driver [Generic PHY] (irq=POLL)
[ 7.933074] mt7530 mdio-bus:00 lan0 (uninitialized): PHY [dsa-0.0:01] driver [Generic PHY] (irq=POLL)
[ 7.943631] mt7530 mdio-bus:00 lan1 (uninitialized): PHY [dsa-0.0:02] driver [Generic PHY] (irq=POLL)
[ 7.954194] mt7530 mdio-bus:00 lan2 (uninitialized): PHY [dsa-0.0:03] driver [Generic PHY] (irq=POLL)
[ 7.964776] mt7530 mdio-bus:00 lan3 (uninitialized): PHY [dsa-0.0:04] driver [Generic PHY] (irq=POLL)
[ 7.975336] of_get_named_gpiod_flags: can't parse 'link-gpios' property of node '/ethernet@1b100000/mdio-bus/switch@0/ports/port@6/fixed-link[0]'
[ 7.988452] of_get_named_gpiod_flags: can't parse 'link-gpio' property of node '/ethernet@1b100000/mdio-bus/switch@0/ports/port@6/fixed-link[0]'
[ 8.001658] mt7530 mdio-bus:00: configuring for fixed/trgmii link mode
[ 8.011371] mt7530 mdio-bus:00: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.019061] DSA: tree 0 setup
[ 8.022953] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.033970] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.041041] ALSA device list:
[ 8.044019] No soundcards found.
[ 8.047686] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 8.056352] cfg80211: failed to load regulatory.db
[ 8.151446] ata2: SATA link down (SStatus 0 SControl 300)
[ 8.156934] md: Waiting for all devices to be available before autodetect
[ 8.163752] md: If you don't use raid, use raid=noautodetect
[ 8.169413] md: Autodetecting RAID arrays.
[ 8.173521] md: autorun ...
[ 8.176313] md: ... autorun DONE.
[ 8.191687] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.199869] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 8.215030] devtmpfs: mounted
[ 8.221413] Freeing unused kernel memory: 1024K
[ 8.226282] Run /sbin/init as init process
[ 8.230422] with arguments:
[ 8.233392] /sbin/init
[ 8.236097] with environment:
[ 8.239236] HOME=/
[ 8.241622] TERM=linux
[ 8.244329] board=bpi-r2
[ 8.857892] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 8.883978] systemd[1]: Detected architecture arm.
[ 8.945368] systemd[1]: Set hostname to <bananapi>.
[ 9.627934] systemd[1]: Listening on Syslog Socket.
[ 9.634095] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.645036] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.652570] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.660140] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 9.668553] systemd[1]: Reached target Swap.
[ 9.673340] systemd[1]: Reached target Remote File Systems.
[ 9.990534] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
[ 10.335013] systemd-journald[164]: Received request to flush runtime journal from PID 1
[ 10.684164] input: mtk-pmic-keys as /devices/platform/1000d000.pwrap/1000d000.pwrap:mt6323/mtk-pmic-keys/input/input1
[ 10.907490] lima 13040000.gpu: mmu gpmmu dte write test fail
[ 10.920248] lima: probe of 13040000.gpu failed with error -5
[ 11.516333] mt7615e 0000:01:00.0: enabling device (0140 -> 0142)
[ 11.544679] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 11.596329] mt7615e 0000:01:00.0: Firmware is not ready for download
[ 11.748682] mt7615e 0000:01:00.0 wlp1s0: renamed from wlan0
[ 16.110764] mtk_soc_eth 1b100000.ethernet eth0: configuring for fixed/trgmii link mode
[ 16.119084] mtk_soc_eth 1b100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 16.128677] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.196354] mt7530 mdio-bus:00 lan0: configuring for phy/gmii link mode
[ 16.203606] 8021q: adding VLAN 0 to HW filter on device lan0
[ 16.261887] device eth0 entered promiscuous mode
[ 16.872263] [WMT-DETECT][I]wmt_detect_open:open major 154 minor 0 (pid 354)
[ 16.872292] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191037),arg(0)
[ 16.872355] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (1074034433),arg(30243)
[ 16.872360] set current consys chipid (0x7623)
[ 16.872368] [WMT-DETECT][I]wmt_detect_unlocked_ioctl:cmd (-2147191036),arg(30243)
[ 16.872373] [WMT-MOD-INIT][I]do_common_drv_init:start to do common driver init, chipid:0x00007623
[ 17.021682] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 17.021695] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 17.021703] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 17.024657] [WMT-MOD-INIT][I]do_common_drv_init:finish common driver init
[ 17.024674] [WCN-MOD-INIT][E]do_connectivity_driver_init(58):do common driver init failed, ret:-1
[ 17.024680] [WLAN-MOD-INIT][I]do_wlan_drv_init:start to do wlan module init 0x7623
[ 17.026400] [MTK-WIFI] WIFI_init: mtk_wmt_WIFI_chrdev driver(major 155) installed.
[ 17.026412] [WLAN-MOD-INIT][I]do_wlan_drv_init:WMT-WIFI char dev init, ret:0
[ 17.027318] [WLAN-MOD-INIT][I]do_wlan_drv_init:WLAN-GEN2 driver init, ret:0
[ 17.027326] [WLAN-MOD-INIT][I]do_wlan_drv_init:finish wlan module init
[ 17.028101] [WMT-DETECT][I]wmt_detect_close:close major 154 minor 0 (pid 354)
[ 20.224794] [WMT-CORE][E]opfunc_hif_conf(874):WMT-CORE: WMT HIF info added
[ 20.225101] vcn18: mode operation not allowed
[ 20.226926] [WMT-CONSYS-HW][E]mtk_wcn_consys_hw_reg_ctrl(290):Read CONSYS chipId(0xfffff093)
[ 20.320476] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6620.defAnt'.
[ 20.320489] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6628.defAnt'.
[ 20.320497] [WMT-CONF][E]wmt_conf_parse_pair(323):unknown field 'mt6630.defAnt'.
[ 20.340710] mt7530 mdio-bus:00 lan0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 20.340752] IPv6: ADDRCONF(NETDEV_CHANGE): lan0: link becomes ready
[ 21.000185] [STP] mtk_wcn_stp_psm_enable:[W] STP Not Ready, Dont do Sleep/Wakeup
[ 25.175463] [MTK-WIFI] WIFI_open: WIFI_open: major 155 minor 0 (pid 334)
[ 25.175542] [MTK-WIFI] WIFI_write: WIFI_write A
[ 25.229904] kalFirmwareImageMapping firmware size 225840
[ 26.296742] [MTK-WIFI] register_set_p2p_mode_handler: (pid 357) register set p2p mode handler 77efc4c4
[ 26.296917] [MTK-WIFI] WIFI_write: WMT turn on WIFI success!
[ 26.301904] [MTK-WIFI] WIFI_write: Set wlan mode 0 --> 1
[ 26.301969] [MTK-WIFI] WIFI_close: WIFI_close: major 155 minor 0 (pid 334)
[ 28.523669] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.524007] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.524277] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.524536] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.524826] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.525115] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.525412] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.525690] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.525966] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.526243] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.526526] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0x40000000
[ 28.526986] DEBUG: Passed mtk_p2p_cfg80211_update_mgmt_frame_register 1426 frame-filter:0xc0000000
[ 28.529212] IPv6: ADDRCONF(NETDEV_CHANGE): ap0: link becomes ready
[ 38.260201] vdd_fixed_vgpu: disabling
[ 38.260240] vusb: disabling
[ 38.260257] vmc: disabling
[ 38.260272] vmch: disabling
[ 38.260284] vgp1: disabling
[ 38.260314] vcamaf: disabling
Sorry about the excessive length…
I guess it doesn’t matter if the firmware is loaded at each boot, as long as it is loaded at power-on… Haven’t tested to see if I can connect to it yet, but I’m working on it…
BTW, I also enabled the on-board wifi…
