andarius40
(andarius40)
Good morning,
I installed 2017-09-14-raspbian-stretch-preview-bpi-r2-sd-emmc.img.
After, I purge all package for graphical interface.
I want use all GE for a routeur ( for replace a BRI-R1)
I just see
I don’t know how delete bond0, and configure 5 gigabyte interfaces.
Thanks you for your help.
frank-w
(Frank W.)
2
your title says jessie
why do you want to delete bond0? maybe its defined in /etc/network/interfaces, so add # before that lines related to it
you cannot configure the 5 LAN-Ports separately, if vlans are supported,maybe you can set different vlans to the ports and configure that vlans
andarius40
(andarius40)
3
My issue that on /etc/network/interfaces, no information about bond0
I have installer vlan package.
But before use vlan. I want to see all interface.
frank-w
(Frank W.)
4
you see only the 2 physical NICs
you have to define the vlans like shown here for BPI-R1 (maybe different params): http://penguindreams.org/blog/using-the-banana-pi-bpi-r1-as-a-router-with-bananian/
I’ve found nothing about R2…maybe driver-support (mt7530 Switch) is not supported yet, so it’s currently a dump switch
BenB
(Benoit)
5
where do you found 2017-09-14-raspbian-stretch-preview-bpi-r2-sd-emmc.img?
Wifi with Ap mode is operational?
sunarowicz
(sunarowicz)
6
frank-w
(Frank W.)
7
gary says in another thread there is some code for AP-Mode, but it’s not working
waiting also for AP-Mode
frank-w
(Frank W.)
8
