Problem with 10inch Lemaker Touch
(Anto) #1
following the guide at
http://wiki.lemaker.org/BananaPro/Pi:LCD_Module
I had enabled correctly the 10 inch monitor. Then, I’ve compiled the kernel enabling the gt9xx module for enabling touch, and after enable it on fex with this code:
[ctp_para]
ctp_used = 1
ctp_name = "gt9xx"
ctp_twi_id = 3
ctp_twi_addr = 0x5d
ctp_screen_max_x = 800
ctp_screen_max_y = 1280
ctp_revert_x_flag = 0
ctp_revert_y_flag = 0
ctp_exchange_x_y_flag = 1
ctp_firm = 1
ctp_int_port = port:PH09<6><default><default><default>
ctp_wakeup = port:PH07<1><default><default><1>
ctp_io_port = port:PH09<0><default><default><default>
[ctp_list_para]
ctp_det_used = 1
ft5x_ts = 0
gt82x = 0
gslX680 = 0
gt9xx_ts = 1
gt811 = 0`
the touch work only with drag action but not work with single tap.
Can someone help me, please?
Thanks in advance.
(bpi team) #2
we are not test lemaker screen :slight_smile:
