Pi hole on BananaPi M1
Hello. I’m trying to get pi hole working but there are errors through process. For example, on Raspbian (found here: http://www.lemaker.org/product-bananapi-resource.html ) There’s error it doesn’t have root privilege so it can’t install. Also when I want update/upgrade (sudo apt-get update) there’s many errors showing many of the resources not found (404) etc. So I tried run official raspbian but with no luck. I thought it would be because of wrong kernel so I’m going to change kernel on boot partition. Do someone have it working? If yes, can you send step-by-step guide? Or OS link on which do you have it?
https://www.armbian.com/bananapi/
armbian-config
https://www.google.com/search?q=pi-hole+armbian
How did you make it working? On my Banana Pi it stuck on last screen of Pi hole installing “Installed lighttpd (armhf)” on 100% and waiting for user input. I don’t know how to access any menu of pi hole on armbian. I can’t even use “pihole” command, it seems like it’s not installed. I did whole setup on recommend settings but with no luck.
Armbian is Debian like OS which works. From there on, you have to see Pi-Hole manual … in case it doesn’t work the automated way.
Fixed by pre-installing lighttpd before Pi Hole.
