Not Connecting to WiFi
(john) #1
Hello, I am using the Banana Pi D1 with the official Banana Pi WiFi Module. I am able to boot the device and connect to it when it is broadcasting as an AP. From the wireless table I found my wifi network at saved my password. The instructions say that once this is saved to press the function key and it will switch to slave mode and the LED will blink. It does blink but only for a second and then goes back to solid and does nothing. I’ve been told you have to edit /etc/jffs2/camera.ini, block. I have not been able to connect over serial but either way the fact it isn’t working from the control panel seems like an issue. Any advice? I am using the latest 2.0 image. Please help. Thanks! I didn’t find the right solution from the Internet. References:https://github.com/Lamobo/lamobo-d1/issues/1
startup animation explainer
