Hello.
So I can’t see the wireless interface on my device(I would like to connect to a wireless network and share it through the 4 wired ports)
# iwconfig
lan1 no wireless extensions.
lo no wireless extensions.
wan no wireless extensions.
lan3.60 no wireless extensions.
eth1 no wireless extensions.
br0 no wireless extensions.
lan3 no wireless extensions.
lan2 no wireless extensions.
lan0 no wireless extensions.
eth0 no wireless extensions.
I’m currently using Debian Stretch latest image(with all packages upgraded): deb_stretch_4.14.80_SD.img.gz Found here: https://drive.google.com/drive/folders/1oP7jy1KrrIOifvImo2nQ59wx3_9hHkgk
# uname -a
Linux bpi-r2 4.14.80-bpi-r2-main #177 SMP Sun Nov 11 10:03:58 CET 2018 armv7l GNU/Linux
# lsmod
Module Size Used by
bnep 20480 2
bridge 151552 0
mtk_thermal 16384 0
thermal_sys 61440 1 mtk_thermal
mt6577_auxadc 16384 0
spi_mt65xx 20480 0
pwm_mediatek 16384 0
rtc_mt6397 16384 1
nvmem_mtk_efuse 16384 0
mtk_pmic_keys 16384 0
ip_tables 24576 0
x_tables 28672 1 ip_tables
ipv6 409600 23 bridge
I’ve found the tutorial and a few mentions that I need to use some script to create/start the device (also found this kinda mentioned here: http://fw-web.de/dokuwiki/doku.php?id=en:bpi-r2:wlan#internal)
And when I run the script (I suppose it’s the wmt_loader) I get the following: # wmt_loader
init combo device
Opened combo device
get device id : 30243
set device id : 30243
do module init: 30243
failed to init module
/var/log/messages also has something to say:
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515831] set current consys chipid (0x7623)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515885] ------------[ cut here ]------------
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515903] WARNING: CPU: 2 PID: 1519 at lib/list_debug.c:25 __list_add_valid+0x64/0xc8
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515910] list_add corruption. next->prev should be prev (c1179ca8), but was (null). (next=c1244c8c).
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515913] Modules linked in: bnep bridge mtk_thermal thermal_sys mt6577_auxadc spi_mt65xx pwm_mediatek rtc_mt6397 nvmem_mtk_efuse mtk_pmic_keys ip_tables x_tables ipv6
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515950] CPU: 2 PID: 1519 Comm: wmt_loader Tainted: G W 4.14.80-bpi-r2-main #177
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515952] Hardware name: Mediatek Cortex-A7 (Device Tree)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515978] [<c0113358>] (unwind_backtrace) from [<c010d580>] (show_stack+0x20/0x24)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.515992] [<c010d580>] (show_stack) from [<c0aa70f8>] (dump_stack+0x94/0xa8)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516006] [<c0aa70f8>] (dump_stack) from [<c0125f40>] (__warn+0xf8/0x110)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516018] [<c0125f40>] (__warn) from [<c0125fa0>] (warn_slowpath_fmt+0x48/0x50)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516029] [<c0125fa0>] (warn_slowpath_fmt) from [<c048daec>] (__list_add_valid+0x64/0xc8)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516043] [<c048daec>] (__list_add_valid) from [<c05b3dec>] (wakeup_source_add+0x8c/0xd4)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516057] [<c05b3dec>] (wakeup_source_add) from [<c05e80bc>] (osal_wake_lock_init+0x2c/0x3c)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516069] [<c05e80bc>] (osal_wake_lock_init) from [<c05e20f4>] (stp_psm_init+0x11c/0x8d4)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516078] [<c05e20f4>] (stp_psm_init) from [<c05e399c>] (mtk_wcn_stp_init+0xbc/0x16c)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516089] [<c05e399c>] (mtk_wcn_stp_init) from [<c05ef8d0>] (stp_drv_init+0x58/0x70)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516100] [<c05ef8d0>] (stp_drv_init) from [<c05f3480>] (mtk_wcn_soc_common_drv_init+0x84/0x348)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516111] [<c05f3480>] (mtk_wcn_soc_common_drv_init) from [<c05faa34>] (do_common_drv_init+0x78/0x1bc)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516121] [<c05faa34>] (do_common_drv_init) from [<c05fa88c>] (do_connectivity_driver_init+0x1c/0x14c)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516129] [<c05fa88c>] (do_connectivity_driver_init) from [<c05f9d68>] (wmt_detect_unlocked_ioctl+0x158/0x1c8)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516141] [<c05f9d68>] (wmt_detect_unlocked_ioctl) from [<c02b30fc>] (do_vfs_ioctl+0xb0/0x8d0)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516151] [<c02b30fc>] (do_vfs_ioctl) from [<c02b3960>] (SyS_ioctl+0x44/0x68)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516164] [<c02b3960>] (SyS_ioctl) from [<c0108c80>] (ret_fast_syscall+0x0/0x54)
Aug 8 15:43:47 bpi-r2 kernel: [ 3273.516169] ---[ end trace b367c80dcfbee3eb ]---
If there is a need to recompile the kernel and apply patches, I’m open to changing to something else(raspbian, centos, ubuntu(eww)) that has out of the box working of ethernet, wifi(5g as a client, no ap needed), hdmi(preferably) and the ability to run linux software (squid, dnsmasq, etc).
Thanks in advance.
