New netfilter flow table based HNAT
Ok, I finally got it to work, this is the patch I made in nf_flow_table_core.c
int nf_flow_table_init(struct nf_flowtable *flowtable)
	int err;
	INIT_DEFERRABLE_WORK(&flowtable->gc_work, nf_flow_offload_work_gc);
	flow_block_init(&flowtable->flow_block);
	init_rwsem(&flowtable->flow_block_lock);
	err = rhashtable_init(&flowtable->rhashtable,
			      &nf_flow_offload_rhash_params);
	if (err < 0)
		return err;
	queue_delayed_work(system_power_efficient_wq,
			   &flowtable->gc_work, HZ);
	mutex_lock(&flowtable_lock);
	list_add(&flowtable->list, &flowtables);
	mutex_unlock(&flowtable_lock);
	+flowtable->flags = NF_FLOWTABLE_HW_OFFLOAD;
	return 0;
thanks but this always enables hw offload independed of config for each flowtable, right?
i still hang on native compilationā€¦i got ld-errors for libnftnl (have used default prefix for the lib while installā€¦). tried to build it like the bash-script there, but still got the ld-errors
https://www.spinics.net/lists/netfilter-devel/msg66323.html
Yes, this was only for testing new openwrt firewall based on nftables. nftables needs to support offload flag in future to configure it there.
Now to see if my ipv6 patch for mtk_ppe_offload works.
still have not got nft compiledā€¦this is my (crosscompile) way:
git clone https://git.netfilter.org/libmnl
git clone git://git.netfilter.org/libnftnl
git clone git://git.netfilter.org/nftables
#build libmnl for armhf
cd libmnl
sh autogen.sh
mkdir install
sh configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install
make
make install
#build libnftnl
cd ../libnftnl/
sh autogen.sh
mkdir install
./configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install LIBMNL_LIBS=../libmnl/install/lib LIBMNL_CFLAGS=../libmnl/include/
make
make install
#build nft
cd ../nftables/
sh autogen.sh
sh configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install PKG_CONFIG_PATH="../libnftnl/install/lib/pkgconfig:../libmnl/install/lib/pkgconfig" LIBMNL_LIBS=../libmnl/install/lib LIBMNL_CFLAGS=../libmnl/include/
still got:
checking for LIBMNL... yes
checking for LIBNFTNL... yes
checking for __gmpz_init in -lgmp... no
configure: error: No suitable version of libgmp found
seems like this is also an armhf-lib required, but have not found any repo to build itā€¦and cannot install it on x86_64 host seems like i can obtain source from here https://gmplib.org/#DOWNLOAD, but only mercurial repo and no gitā€¦download source-package (*.xz) is very slow
wget https://ftp.gnu.org/gnu/gmp/gmp-6.2.1.tar.xz
tar -xvf gmp-6.2.1.tar.xz
cd gmp-6.2.1/
make
make install
last step suggests make check, which fails :frowning:
FAIL: t-bswap
FAIL: t-constants
FAIL: t-count_zeros
FAIL: t-hightomask
FAIL: t-modlinv
FAIL: t-popc
FAIL: t-parity
FAIL: t-sub
netherless i tried to include it into nftables-config, but this does also fail
sh configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install PKG_CONFIG_PATH="../libnftnl/install/lib/pkgconfig:../libmnl/install/lib/pkgconfig:../gmp-6.2.1/install/lib/pkgconfig" LIBMNL_LIBS=../libmnl/install/lib LIBMNL_CFLAGS=../libmnl/include/ LIBGMP_LIBS=../libmnl/install/lib LIBGMP_CFLAGS=../gmp-6.2.1/include
but i got configure working with --with-mini-gmp --without-cli
without-cli disables readline libraryā€¦iā€™m not sure this is right as nft is a cli-tool
for make i had to use absolute names (instead of ā€¦/)
BASE="$(pwd)/../"; sh configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install PKG_CONFIG_PATH="$BASE/libnftnl/install/lib/pkgconfig:$BASE/libmnl/install/lib/pkgconfig" LIBMNL_LIBS=$BASE/libmnl/install/lib LIBMNL_CFLAGS=$BASE/libmnl/include/ --with-mini-gmp --without-cli
native-way still stops on ld-error
but now iā€™m on same state as native compile
  CCLD     nft
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_nest_start'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_bind'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_current'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_nest_end'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_put_u16'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_fprintf'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_put_u8'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_get_payload'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_get_u32'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_get_payload_len'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_is_empty'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_get_payload_offset'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_get_u16'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_get_payload_len'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_put_extra_header'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_next'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_get_u64'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_put_u64'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_get_payload_tail'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_next'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_setsockopt'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_stop'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_parse'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_put_header'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_get_portid'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_get_str'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_head'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_cb_run'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_put_strz'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_get_type'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_get_u8'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_start'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_validate'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_put_str'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_ok'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_sendto'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_recvfrom'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_nlmsg_size'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_put_u32'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_nlmsg_batch_size'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_cb_run2'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_open'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_get_payload'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: /media/data_nvme/git/nft/libnftnl/install/lib/libnftnl.so.11: undefined reference to `mnl_attr_parse_nested'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_put'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_get_fd'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_socket_close'
/usr/lib/gcc-cross/arm-linux-gnueabihf/9/../../../../arm-linux-gnueabihf/bin/ld: ./.libs/libnftables.so: undefined reference to `mnl_attr_type_valid'
i tried to pass the lib dirs with LDFLAGS,LD_LIBRARY_PATH and --libdir= to configureā€¦still get the linker-errors
tried also to configure libnftnl without relative paths
BASE="$(pwd)/..";
./configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install LIBMNL_LIBS=$BASE/libmnl/install/lib LIBMNL_CFLAGS=$BASE/libmnl/include/
make clean
make
make install
cd ../nftables
make clean
make
but still the same
My ipv6 patch works in nftables, it was not working in iptables + xt_flowoffload.
940 mbps over ipv6 (pppoe) at no CPU cost. Pretty impressinve.
Now itā€™s time to explore HWQoS.
Can you send it as follow up to the series from post #1?
Maybe your fix for flowtable to get a real configurable solution
I donā€™t know how to do that, never sent a patch before :grinning:. Feel free to do so.
Also Iā€™m not sure the mangle part is correct.
ipv6.patch (2.7 KB)
First i need to get it compiled :wink: mhm, seems to work if i leave the vars in the last configure step
BASE="$(pwd)/..";
./configure --host=arm-linux-gnueabihf --prefix=$(pwd)/install PKG_CONFIG_PATH="$BASE/libnftnl/install/lib/pkgconfig:$BASE/libmnl/install/lib/pkgconfig" --with-mini-gmp --without-cli
and on native compile seems like PKG_CONFIG_PATH was not set correctly (and needed to install libreadline-dev docbook-xsl xsltproc libxml2-utils)
For supporting flags in flowtable i guess we need token here similar to patch above: http://git.netfilter.org/nftables/tree/src/parser_bison.y?id=d42bd56cff1a22301703d2b9d6d6fc937ea7cfbd#n1886
I really do not understand bison,but it looks like here the token for devices is added. I guess flags can be next, of course this is only cli parser and needs to add functionality in code
got it working :wink:
root@bpi-r64:~# /home/frank/nftables/install/sbin/nft -f nft-nat-flowoffload.nft
root@bpi-r64:~# /home/frank/nftables/install/sbin/nft list ruleset
table ip filter {
        flowtable f {
                hook ingress priority filter + 1
                devices = { lan3, lan0, wan }
 flags offload; }
        chain input {
                type filter hook input priority filter; policy accept;
        chain output {
                type filter hook output priority filter; policy accept;
        chain forward {
                type filter hook forward priority filter; policy accept;
                ip protocol { tcp, udp } flow add @f
table ip nat {
        chain post {
                type nat hook postrouting priority filter; policy accept;
                oifname "wan" masquerade
        chain pre {
                type nat hook prerouting priority filter; policy accept;
root@bpi-r64:~# cat /sys/kernel/debug/mtk_ppe/entries
root@bpi-r64:~# echo 1 > /proc/sys/net/ipv4/ip_forward
0074e BND IPv4 5T orig=192.168.0.10:5201->192.168.0.18:36142 new=192.168.0.10:5201->192.168.80.122:36142 eth=36:c7:65:74:18:bc->00:13:77:b7:a7:62 etype=1000 vlan=0,0 ib1=21412f3e ib2=007ff020
00c00 UNB IPv6 5T orig=fe80:0000:0000:0000:6387:b15f:d347:b958:41038->ff12:0000:0000:0000:0000:0000:0000:8384:21027 eth=00:00:00:00:00:00->00:00:00:00:00:00 etype=0000 vlan=0,0 ib1=5a000039 ib2=00000000
012d6 UNB IPv4 5T orig=192.168.80.122:52327->192.168.80.1:5351 new=0.0.0.0:0->0.0.0.0:0 eth=00:00:00:00:00:00->00:00:00:00:00:00 etype=0000 vlan=0,0 ib1=5000003a ib2=00000000
01314 UNB IPv4 5T orig=192.168.0.21:33923->192.168.0.255:21027 new=0.0.0.0:0->0.0.0.0:0 eth=00:00:00:00:00:00->00:00:00:00:00:00 etype=0000 vlan=0,0 ib1=5000013c ib2=00000000
0171e BND IPv4 5T orig=192.168.80.122:36142->192.168.0.10:5201 new=192.168.0.18:36142->192.168.0.10:5201 eth=36:c7:65:74:18:bc->08:02:00:00:00:10 etype=0100 vlan=0,0 ib1=21412f3e ib2=007ff020
01722 BND IPv4 5T orig=192.168.80.122:36144->192.168.0.10:5201 new=192.168.0.18:36144->192.168.0.10:5201 eth=36:c7:65:74:18:bc->08:02:00:00:00:10 etype=0100 vlan=0,0 ib1=21412f42 ib2=007ff020
01772 BND IPv4 5T orig=192.168.0.10:5201->192.168.0.18:36144 new=192.168.0.10:5201->192.168.80.122:36144 eth=36:c7:65:74:18:bc->00:13:77:b7:a7:62 etype=1000 vlan=0,0 ib1=21412f42 ib2=007ff020
01722 BND IPv4 5T orig=192.168.80.122:36144->192.168.0.10:5201 new=192.168.0.18:36144->192.168.0.10:5201 eth=36:c7:65:74:18:bc->08:02:00:00:00:10 etype=0100 vlan=0,0 ib1=21412f46 ib2=007ff020
01772 BND IPv4 5T orig=192.168.0.10:5201->192.168.0.18:36144 new=192.168.0.10:5201->192.168.80.122:36144 eth=36:c7:65:74:18:bc->00:13:77:b7:a7:62 etype=1000 vlan=0,0 ib1=21412f46 ib2=007ff020
root@bpi-r64:~#
traffic increases, but not much (80Mbit/s->96Mbit/s) as my test-device if 100Mbit/s only, but i see that cpu is not limiting anymore :wink:
except the little printing-issue in ā€œlist rulesetā€ itā€™s working as expected
edit: printing-issue also fixed:
frank@bpi-r64:~/nftables$ sudo install/sbin/nft list ruleset
table ip filter {
        flowtable f {
                flags offload;
Send patch to mailinglistā€¦i hope it is right :slight_smile:
https://patchwork.ozlabs.org/project/netfilter-devel/patch/[email protected]/
one problem resides with cross-compiled version (i try it now on r2)ā€¦
i copied the content of install/lib of all crosscompiled libs folder to /usr/local/lib, ran ā€œ/sbin/ldconfig -vā€ and started my nft binary
root@bpi-r2:~# /home/frank/nft_install/sbin/nft
/home/frank/nft_install/sbin/nft: /usr/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_13' not found (required by /usr/local/lib/libnftables.so.1)
/home/frank/nft_install/sbin/nft: /usr/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_15' not found (required by /usr/local/lib/libnftables.so.1)
/home/frank/nft_install/sbin/nft: /usr/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_14' not found (required by /usr/local/lib/libnftables.so.1)
/home/frank/nft_install/sbin/nft: /usr/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_16' not found (required by /usr/local/lib/libnftables.so.1)
ldconfig shows the libs, but it seems they are not found
/usr/local/lib:
/sbin/ldconfig: /usr/local/lib/libmnl.so.0 is not a symbolic link
        libmnl.so.0 -> libmnl.so.0.2.0
/sbin/ldconfig: /usr/local/lib/libnftnl.so.11 is not a symbolic link
        libnftnl.so.11 -> libnftnl.so.11.5.0
/sbin/ldconfig: /usr/local/lib/libnftables.so.1 is not a symbolic link
        libnftables.so.1 -> libnftables.so.1.0.0
any idea?
seems system tries to load old libnftl
root@bpi-r2:~# ldd /home/frank/nft_install/sbin/nft
        linux-vdso.so.1 (0xbef7f000)
        libnftables.so.1 => /usr/local/lib/libnftables.so.1 (0xb6f08000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e0e000)
        /lib/ld-linux-armhf.so.3 (0xb6f98000)
        libmnl.so.0 => /lib/arm-linux-gnueabihf/libmnl.so.0 (0xb6df9000)
        libnftnl.so.11 => /usr/lib/arm-linux-gnueabihf/libnftnl.so.11 (0xb6dd1000)
how can i tell nft to use the libs from /usr/local/bin?
got it with a (dirty) hack:
root@bpi-r2:~# mv /usr/lib/arm-linux-gnueabihf/libnftnl.so.11{,.bak}
root@bpi-r2:~# ln -fs /usr/local/lib/libnftnl.so.11 /usr/lib/arm-linux-gnueabihf/libnftnl.so.11
/home/frank/nft_install/sbin/nft: no command specified
root@bpi-r2:~#
Hi Frank, please try to read man ld.so there is a description of library search order. I donā€™r remember details, but i hope this may help.
thx alexā€¦i know ld only for linking while compiling not as system-configurationā€¦but looked through the very large manpage :slight_smile:
found this:
For a native linker on an ELF system, if the file /etc/ld.so.conf exists, the list of directories found in that file.
/etc/ld.so.conf contains ā€œinclude /etc/ld.so.conf.d/*.confā€
where i have these files (donā€™t know which one comes first or which is taken) /etc/ld.so.conf.d/arm-linux-gnueabihf.conf /etc/ld.so.conf.d/fakeroot-arm-linux-gnueabihf.conf /etc/ld.so.conf.d/libc.conf
i guess /etc/ld.so.conf.d/arm-linux-gnueabihf.conf is used for my binary which contains these lines:
/usr/local/lib/arm-linux-gnueabihf
so maybe i should put my libs into /usr/local/lib/arm-linux-gnueabihf instead of /usr/local/lib/ directly :slight_smile:
As for me, the main thing is:
 If a shared object dependency does not contain a slash, then it is searched for in the following order:
       o  Using the directories specified in the DT_RPATH dynamic section attribute of the binary if present and DT_RUNPATH attribute does not exist.  Use of DT_RPATH is deprecated.
       o  Using the environment variable LD_LIBRARY_PATH, unless the executable is being run in secure-execution mode (see below), in which case this variable is ignored.
       o  Using the directories specified in the DT_RUNPATH dynamic section attribute of the binary if present.  Such directories are searched only to find those objects required by DT_NEEDED (direct dependencies)  entries  and  do
          not apply to those objects' children, which must themselves have their own DT_RUNPATH entries.  This is unlike DT_RPATH, which is applied to searches for all children in the dependency tree.
       o  From  the  cache  file  /etc/ld.so.cache,  which contains a compiled list of candidate shared objects previously found in the augmented library path.  If, however, the binary was linked with the -z nodeflib linker option,
          shared objects in the default paths are skipped.  Shared objects installed in hardware capability directories (see below) are preferred to other shared objects.
       o  In the default path /lib, and then /usr/lib.  (On some 64-bit architectures, the default paths for 64-bit shared objects are /lib64, and then /usr/lib64.)  If the binary was linked with the -z nodeflib linker option, this
          step is skipped.
So you still can place libs directly to one of these paths :slight_smile: , but you may also try ro replace/modify LD_LIBRARY_PATH and to set needed path, so it should be checked earlier than /etc/ld.so.cache
seems like thisā€¦but still error
root@bpi-r2:~# LD_LIBRARY_PATH=/usr/local/lib /home/frank/nft_install/sbin/nft
/home/frank/nft_install/sbin/nft: /usr/local/lib/libnftnl.so.11: version `LIBNFTNL_13' not found (required by /usr/local/lib/libnftables.so.1)
Zusammenfassung
seems this is only done for first iterationā€¦not for depency of loaded shared lib
root@bpi-r2:~# ls -l /usr/local/lib
total 14096
drwxr-xr-x 2 root root     4096 Mar 22 10:26 arm-linux-gnueabihf
-rwxr-xr-x 1 root root      946 Mar 22 09:33 libmnl.la
-rwxr-xr-x 1 root root    64200 Mar 22 09:33 libmnl.so
-rwxr-xr-x 1 root root    64200 Mar 22 09:33 libmnl.so.0
-rwxr-xr-x 1 root root    64200 Mar 22 09:33 libmnl.so.0.2.0
-rw-r--r-- 1 root root  3984680 Mar 22 09:28 libnftables.a
-rwxr-xr-x 1 root root     1197 Mar 22 09:28 libnftables.la
-rwxr-xr-x 1 root root  2669132 Mar 22 09:28 libnftables.so
-rwxr-xr-x 1 root root  2669132 Mar 22 09:28 libnftables.so.1
-rwxr-xr-x 1 root root  2669132 Mar 22 09:28 libnftables.so.1.0.0
-rwxr-xr-x 1 root root      964 Mar 22 09:29 libnftnl.la
-rwxr-xr-x 1 root root  1057580 Mar 22 09:29 libnftnl.so
-rwxr-xr-x 1 root root    97240 Mar 22 10:27 libnftnl.so.11
-rwxr-xr-x 1 root root  1057580 Mar 22 09:29 libnftnl.so.11.5.0
drwxrwsr-x 3 root staff    4096 Oct  2  2019 python3.7
put now the libs in the created folder /usr/local/lib/arm-linux-gnueabihf and run ldconfig -v
root@bpi-r2:~# ldconfig -v
ldconfig: Path `/lib/arm-linux-gnueabihf' given more than once
ldconfig: Path `/usr/lib/arm-linux-gnueabihf' given more than once
/usr/local/lib/arm-linux-gnueabihf:
ldconfig: /usr/local/lib/arm-linux-gnueabihf/libmnl.so.0 is not a symbolic link
ldconfig: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11 is not a symbolic link
ldconfig: /usr/local/lib/arm-linux-gnueabihf/libnftables.so.1 is not a symbolic link
/usr/local/lib:
and got same
/home/frank/nft_install/sbin/nft: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_13' not found (required by /usr/local/lib/arm-linux-gnueabihf/libnftables.so.1)
this is strange as the file exists and is the new version of the fileā€¦i guess again the older version is used
ldd shows right one
root@bpi-r2:~# ldd /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11
        linux-vdso.so.1 (0xbefcb000)
        libmnl.so.0 => /usr/local/lib/arm-linux-gnueabihf/libmnl.so.0 (0xb6f51000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6e57000)
        /lib/ld-linux-armhf.so.3 (0xb6f8d000)
root@bpi-r2:~# ldd /usr/local/lib/arm-linux-gnueabihf/libnftables.so.1
/usr/local/lib/arm-linux-gnueabihf/libnftables.so.1: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_13' not found (required by /usr/local/lib/arm-l
/usr/local/lib/arm-linux-gnueabihf/libnftables.so.1: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_15' not found (required by /usr/local/lib/arm-l
/usr/local/lib/arm-linux-gnueabihf/libnftables.so.1: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_14' not found (required by /usr/local/lib/arm-l
/usr/local/lib/arm-linux-gnueabihf/libnftables.so.1: /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11: version `LIBNFTNL_16' not found (required by /usr/local/lib/arm-l
        linux-vdso.so.1 (0xbec93000)
        libmnl.so.0 => /usr/local/lib/arm-linux-gnueabihf/libmnl.so.0 (0xb6e5d000)
        libnftnl.so.11 => /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11 (0xb6e35000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6d3b000)
        /lib/ld-linux-armhf.so.3 (0xb6eed000)
mhmā€¦version seems to be set to 1 not 13+
root@bpi-r2:~# readelf -h /usr/local/lib/arm-linux-gnueabihf/libnftnl.so.11
ELF Header:
  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
  Class:                             ELF32
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - System V
  ABI Version:                       0
  Type:                              DYN (Shared object file)
  Machine:                           ARM
  Version:                           0x1
recopied the libs to /usr/local/lib/arm-linux-gnueabihf/ followed by calling ldconfig -v and it seems to work
root@bpi-r2:~# mkdir -p /usr/local/lib/arm-linux-gnueabihf/
root@bpi-r2:~# cp /home/frank/libnftnl/install/lib/* /usr/local/lib/arm-linux-gnueabihf/
root@bpi-r2:~# cp /home/frank/nftables/install/lib/* /usr/local/lib/arm-linux-gnueabihf/
root@bpi-r2:~# /home/frank/nftables/install/sbin/nft
/home/frank/nftables/install/sbin/nft: no command specified
strange that my crosscompiled version still reports
nft-nat-flowoffload.nft:5:17-21: Error: syntax error, unexpected flags
                flags offload;
have recompiled it (after make clean) and copied againā€¦seems i need to replace libs (previous version was without my patch) too :slight_smile: now i can import the ruleset
and yes, it works for r2 too
root@bpi-r2:~# cat /sys/kernel/debug/mtk_ppe/entries
0016a UNB IPv4 5T orig=192.168.0.10:5201->192.168.0.12:50210 new=192.168.0.10:5201->192.168.90.122:50210 eth=46:fb:52:43:15:e2->00:13:77:b7:a7:62 etype=1000 vlan=0,0 ib1=10000092 ib2=007ff020
0111e BND IPv4 5T orig=192.168.90.122:50212->192.168.0.10:5201 new=192.168.0.12:50212->192.168.0.10:5201 eth=08:00:00:00:00:01->08:02:00:00:00:10 etype=0100 vlan=0,0 ib1=21412092 ib2=007ff020
root@bpi-r2:~#
@graphine sent out series with my and your Patch https://patchwork.kernel.org/project/linux-mediatek/list/?series=452805
uploaded compiled versions of nftables to my gdrive https://drive.google.com/drive/folders/1hajKvqQa96WRrAy52fQX90i59I1s0h-i?usp=sharing
Just unpack content of lib-folders to folder /usr/local/lib/arm-linux-gnueabihf on r2 (create first) or /usr/local/lib/aarch64-linux-gnu on r64 and nft binary to folder in PATH (/usr/local/sbin)
v2 of the series is merged to net-next (5.13):
https://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next.git/log/
nftables-Patch is also applied
http://git.netfilter.org/nftables/commit/?id=8e6cc9f373854ed580156ec6f01bcd97786fa9f7
ā€œmyā€ kernel-patches (mt7623 support and ipv6 offload) are still open
ipv6 offload seems not working:
  • 2 top most commits break ipv6-nat
  • without them ipv6 NAT works, but hw flow offload not working
this is my ipv6 ruleset:
flush ruleset
table ip6 filter {
    flowtable f {
        hook ingress priority 1
        flags offload;
    chain input {
        type filter hook input priority 0; policy accept;
    chain output {
        type filter hook output priority 0; policy accept;
    chain forward {
        type filter hook forward priority 0; policy accept;
        ip6 nexthdr { tcp, udp } flow add @f
table ip6 nat {
    chain post {
        type nat hook postrouting priority 0; policy accept;
    chain pre {
        type nat hook prerouting priority 0; policy accept;
Btw. I did backporting of hnat patches for 5.10 to have it working on last lts kernel:
https://github.com/frank-w/BPI-R2-4.14/tree/5.10-hnat
Maybe someone will try it too
Seems like graphine do only flow offloading and no ipv6 nat (like i try to test). Current patch for adding ipv6 mangle offload breaks ipv6 nat. Pablo means nat for ipv6 seems not to be supported by driver.
I know ā€œno one needs ipv6 nat at the momentā€ because it breaks end to end connectivity and is not really needed because there are enough adresses available. But maybe if anyone have only a /64 prefix and wants to use 2 subnets (maybe vlan or any other kind of subnetting) nat may be usefulā€¦
At least hw offloading should not break nat functionalityā€¦
This is currently the caseā€¦@ryder.lee can you address this to the hnat-specialists?
Pablo is the netfilter maintainer and leading member, so this is actually his call though unless you can convince him.
NAT was invented to solve the shortage of ipv4 address. I agree Pabloā€™s opinion that no need to support ipv6 NAT. In my opinion, It is more useful to suppprt MAP-E or MAP-T offload since some operators use those protocols in ipv4 to ipv6 transition stage.
What is the preferred way if someone has only a /64 ipv6 but wants more than 1 subnet? That was a possible usecase for nat in ipv6
The solution would be to delegate e.g. /80 to downstream network and use DHCPv6 instead of SLAAC, well, if Android would support that. Iā€™ve also used ND proxy for IPv6 and NAT for IPv4 in that situation, but then you still end up with a single /64. Actually most ISPs Iā€™ve seen until now hand out /56 if requesting that in first place (most of the time that implies having to use your own router handling that DHCPv6 request on the WAN interface as ISP supplied routers often donā€™t allow to configure the size of the prefix to be requested nor delegating sub-prefixes to multiple local networks)
